Question about Samsung LNT5265F 52 in. LCD HDTV
No picture or sound/wont power up
"No picture" "No sound"..... as soon as i plug my tv to outlet i here a relay clicking sound in the unit that repeats over and over,The red power light flashes in sync with the relay sound. The blue light beneath the samsung logo works though. The tv is about 18 months old. Can this be something that i can fix myself, I'm pretty handy at fixing other electronic devices
  • jimmy sanchez May 30, 2009
    Hey castelll thanks alot for solution. would you happen to know where or who i would call to get mainboard? and what is the part#?
    Thank you very much for the quick reply. I'm going to do research now.
  • 187 Answers
Your mainboard is damaged, the mainboard is the one where you plug all the cables (component HDMI), it is really easy to replace, you only need to take special care with the screws.
1. remove all screws in the back.
2. unplugg all cables from mainboard.
3. remove all srews from mainboard and replace it.
4. put all screws back and then plug all cables again.
5. double check all mainboard cables are properly secured.
6. Test TV.
7. put the back cover and secure it with the screws.
8. Enjoy your TV again.
Posted on May 30, 2009
  • Carlos Figueroa May 30, 2009
    To order your mainboard you need your product code and TV model, both are located in the back of the TV next to serial number.
    You can order your part directly from your manufacturer or you can use Ebay, You may want to try also a web search with something like this "Samsung LNT5265f 52 mainboard"
Conia plasma.no buttons work on the tv and the picture does not appear when you turn it on.it shut of one day.the aerial works and the tv has power.
How long have you owned the television. What is the exact model of the television. Once I have more information I can help you further.
Thanks,
Lee
Aug 26, 2008 | Televison & Video
Akai model ws-p28ntf-sf-d-gb (s) tv/dvd combo
Disconnect it from power cable 30 mins, see if this reset works, for the rest sounds like you have a problem with the power unit.
Mar 28, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Laid tv face down on new rug to install legs,set back on table,sound,no picture.had picture 10 min prior
You should be seeing a validation that the TV is getting power. Like the lights are coming on, or you are hearing clicking when you plug in or power up the TV.
Make sure you have the TV’s power cord plug inserted all the way into the TV.
Also, make sure the TV's cord is plugged into a good power outlet. You may want to plug something else into the power outlet to be sure the outlet is good.
I don’t see how laying down the TV would cause this issue. Unless the TV was kind of dropped and or twisted to cause a board inside the TV to fracture/break.
I hope this information has helped you.
Good Luck.
May 23, 2010 | Sylvania 6842THG 42 in. Plasma HDTV
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
Relay clicks, but No sound, No picture.
Hello, just try this first.
Unplugged the unit the power outlet for about 60 sec.Then power it on again. If you have surge strip along the line. You should directly switch in on power outlet only. If this doesn't help.
As the relay is working you have power in standby mode. Check its supply voltages if its ok. Secondly you can check the the B+ supply it is in DC, If this is a crt type tv, check its horizontal output transistor, Check its flyback for short circuit. Capacitor near to it rated almost 800V, and deflection coil.
Just for input, hope it helps
Apr 19, 2009 | Daewoo Televison & Video
My Sanyo TV, 3 year old turns off with a click sound, as soon as it is turned On
Hi
your tv has defective power oscillation! the click sound that is relay power source. if the relay is click back you have defective small parts in power section! do you have experience in electronics?
Thanks!
Jun 22, 2008 | Televison & Video
Tv won't turn on
my funai 3216 was working ok it went off today and wont come back on iv changed the fuse in the plug with no luck iv taken the back off the tv what next please help
Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Dec 25, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Relay "Chatter" with good picture and sound
Sanyo Model AVM-1304 This TV has a loud mechanical "chatter" (or clicking)that appears to be coming from RL001 on the motherboard as soon as ther TV is turned on. I can feel the mechanical vibration on the component. The Picture and sound are very good. The chassis is G6Y-13040. Any ideas? This TV has a loud mechanical "chatter" (or clicking)that appears to be coming from RL001 on the motherboard as soon as ther TV is turned on replace relay as it is easily available or make it direct. .
Sep 11, 2007 | Televison & Video
Samsung LNT5265F 52 in. LCD HDTV Logo
617 people viewed this question
Henry  Thomas
Henry Thomas
