Question about Neovo AG AG-01 TV Tuner Picture Frame Retail ***Free 2nd Day*** Graphic Card
Zenith qf989637 when i turn the tv on i get a picture and sound then it gets a blank screen (black) sound stays on and i can see the picture around about 2 inches on the outside of the screen but a black square on the inside does this sound like it will cost alot to repair it seems that when i move the ant wires the screen will come back on for a minute then it will do the same thing
  • 88 Answers
Re: zenith qf989637
Either the cable or the port it plugs in to is defective, niether of which should be expensive to repair. Obviously the first thing to try is a replacement cable.
Hope this helps,
Posted on Mar 15, 2008
0 characters
3 Points
Black screen and no sound on my Hauppauge Colossus PCI Express Win 7 capture card. I have confermed that the signa is getting to the card, by plugging each the HDMI, S-Video and composite video cables into...
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in the safe mode then Scan your computer for viruses. Some viruses can cause a black Screen , especially ones that infect the master boot record (MBR) or boot sector.
Update drivers for your hardware. black Screens are hardware or driver related so updated drivers could fix the cause of the STOP error.
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen.
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
Aug 27, 2013 | Hauppauge Colossus PCI Express HD Video...
My asus notebook K42JC has a problem in video screen
hi i have a eepc asus notebook and the problem is i went to reboot the comp and it shows the windows logo before boot but.. the screen just stays lighted alittle then it's black i tryed booting in all modes and it wont even boot in safe it will get half way then stop i am thinking vid card but i dont know if i can get a vid card for the notebook can u pls tell me how to get around it i even went thru bios and it has no setting for on board vid i am seriously thinking of rebooting windows i have no cd rom to boot drivers it came with cd but no cd rom drive lol pls he
Sep 14, 2010 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
I have a fx5500 card and cannot get it to display on the tv whn i boot up both monitor and tv displsy theboot up but then my desktop shows ok on monitor but the tv is blank, it doesnt dectect the tv at all
well there is a problem with some cards that wont disply on TV and some do but the screen is black n white thats the way it is. its due to the driver, update the driver to latest and then give it a shot.
Dec 19, 2009 | Nvidia GeForce FX 5500 Video Card Graphic...
Turned my gateway mx3414 laptop off, when I turned it back on the screen was black, turned off and restarted several times always just a black screen.
You may have a faulty inverter or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
Dec 13, 2009 | Gateway Graphics Cards
I'm getting only a black screen ?
sounds like the monitor aint supporting the graphics card, do you see your boot menu when you turn on the pc, have you tried booting up in safe mode and removing drivers and restarting then installing drivers. try a differnt monitor, make sure your bios settings are corect for that card, hope these few things help
My x-box won't show a picture but it has sound. Has a black screen.
It might not be pluged into the tv or xbox proply
Jun 07, 2009 | Graphics Cards
304w hp wont load
Try pulling the plug from the back of the machine or the wall and then plug it back in and see if it will come up. It may be stuck in what I call a voltage loop. You can also try re-seating the card and memory and making sure the cable from the monitor is connected firmly.
If it doesn't do anything it is possible that either the video card is going bad, the power supply is failing, memory is bad or possibly the motherboard is shot.
Let me know if I can help any further.
Dec 29, 2008 | Graphics Cards
Sound but no picture
Hello Dabizot,
With the price of the new tv's, I would recommend getting a new tv. It's only a 19" and you can get a flat panel 19" for less than $ 200.00 It may cost you $ 100 plus to get it repaired along with any new parts. If you want to spend less money try looking at the yard sales, people are always selling used TV's for cheap.
Nov 16, 2008 | Neovo AG AG-01 TV Tuner Picture Frame...
Need help with black screen
Try looking at the back of the TV and ensuring that the incoming cable is in the correct input. If you have audio and video cables make sure they are placed in the same input. What type of cable do you have directv or comcast?
Oct 20, 2008 | Neovo AG AG-01 TV Tuner Picture Frame...
I have a blank screen
Glad you got it fixed. Next time something like this occurs, try searching the forum of your distro (or the Ubuntu forums as they seem to have just about every error ever listed in there) as you will usually find the answer faster.
Mar 19, 2008 | PNY Verto GeForce FX 5200, Graphic Card
Graphics Cards Logo
54 people viewed this question
Top Neovo Graphics Cards Experts
phoenix chi
phoenix chi
Are you a Neovo Graphics Card Expert? Answer questions, earn points and help others
