Question about Microsoft Windows XP Professional for PC
Error 1706 can i solve error 1706 manualy i.e without using CD if i will reinstall my broadband connection will get deleted
  • 23 Answers
Try to use the Registry cleaner software e.g.
Registry Cleaner or RegCure
these two softwares should help you to remove the unwanted registry entry which are raising the problem of "Error 1706"
Posted on May 30, 2009
How to stop Microsoft Powerpoint error 1706?
Causes of Error 1706 ·Corrupt download or incomplete installation of Microsoft Powerpoint software.
·Corruption in Windows registry from a recent Microsoft Powerpoint-related software change (install or uninstall).
·Virus or malware infection that has corrupted Windows system files or Microsoft Powerpoint-related program files.
·Another program maliciously or mistakenly deleted Microsoft Powerpoint-related files.
Runtime Errors such as "Error 1706" can be caused by a variety of factors, so it is important that you troubleshoot each of the possible causes to prevent it from recurring.
If you are still experiencing the issue you can try PowerPoint Fix Toolbox https://www.fixtoolbox.com/powerpointfix.html
Jul 26, 2015 | Microsoft PowerPoint for PC
Icannot get rid of the folliowing: Error 1706 Win DVD.
hi there,
May you provide the complete details of your player like the maker model..
`jack
May 23, 2008 | HP Televison & Video
KODAK ESP 3200 SERIES WILL NOT SCAN
I had the same problems; missing Icon and 100-2105.
This solution on the Kodak web site solved my problem.
http://support.en.kodak.com/app/answers/detail/a_id/1276/kw/ERROR:%20100-2105/selected/true
From your computer desktop, select Start > Run.
Type %windir%, then click OK.
Double-click the twain_32 folder.
Right-click the kodak folder, then select Delete.
Insert the KODAK All-in-One Printer Software CD into the CD drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
Double-click aioscannr.msi, then follow the instructions to remove it.
Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
Start Home Center Software.
Select Scan Documents and Pictures.
Scan a document.
If the error continues using a Wi-Fi connection, make sure you select the correct printer in Home Center Software.
If the error continues using a USB connection, see the following section to reinstall the printer.
Jan 13, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a Dell inspiron 537 sesktop pc and the lan adapter is not recognizing the ethernet lan connection. I reinstalled the drivers etc but it still show " not connected ". Is there anyway to...
To connect to the Internet, certain hardware and services are needed, which are listed below. Without any one of these items, connection to the Internet is not possible.
  • Broadband Internet Service (also known as Internet Service Providers or ISP) - Telephone companies (also known as DSL, which uses a telephone line) and cable TV companies usually offer Internet service.
  • Broadband Modem - Normally, a broadband modem can be rented or purchased from the ISP.
  • Computer with a Network Adapter - This is usually a device located inside the computer.
  • Broadband Router - A router is used to connect all of your computers to the network (but is not needed for a single computer). The router also provides a way to connect to the Internet through the Broadband Modem.
Oct 12, 2011 | Dell Inspiron 537 (DDCWQA1_7) PC Desktop
When boot up my computer and my XP operating system, I get a pop up window which reads: ERROR 1706 VALIDATE SOURCE CANNOT BE FOUND FOR PRODUCT DAO The WINDOW INSTALLER continues to try to install...
Error 1706 is usually displayed at run time when a program is installed using Install Shield. You can fix it or install the files by accessing the bios setup.. On the boot section choose the drive where the file to be installed is located to be the first one to boot. If it is on the CD drive choose Cd drive then save and exit setup.
Jul 14, 2011 | Computers & Internet
I cannot use my MS office 2007 and here is the error showed MS Office Enterprise 2007 Error 1706. Setup can't find the the required files. See SETUP.CHM
hello friend first of all you nedd a fresh copy of ms office and if you are using original one you can go for a call to the microsoft office personals or windows helpline number 18001021100
the will exactly solve your problem
Jan 25, 2011 | Microsoft Office 2007 Full Version...
When trying to uninstall a program I get the error message--intallation log not found. What does this mean and how do I fix it??
just go and manualy delete the program and then manualy delete the shortcut files on your desktop, also you can right click on you program list under the start menu to get the option of "Explore" then you can delete the start menu --> Program Files/ (program you want to delete) and shortcuts inside.
OR
You can also try reinstalling them and then uninstalling them through add remove programs or what ever built in method supported by that program.
Oct 22, 2009 | Microsoft Windows Vista Home Premium with...
Displays error 1706 every time i use nmy computer
error_x.jpg What Causes Error 1706 Error 1706 is a critical Windows error and is caused by a corrupt registry entry that should be repaired immediately to prevent further corruption in other applications and/or hardware. Risks include hardware failure, blue screen errors and fatal crashes. I found this on the internet by typeing in Error 1706 at google. If you have Norton Tools you need to runit or some other Registery Repair software.
Mar 06, 2009 | HP Office Equipment & Supplies
Error 1706
Just get another install disk. Borrow one from a friend.
Then all you will need is your serial number.
Reinstall and try that.
Michael
Nov 30, 2008 | Corel WordPerfect Office 12 Standard...
NETWORK ADAPTER
Reinstall the network adapter from the dell driver cd and reboot the system with the nic pluged in.
Jul 21, 2008 | Dell Dimension 4600 PC Desktop
Microsoft Windows XP Professional for PC Logo
163 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
