Question about Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Auto Focus not working for Canon EFS 18-55mm lens
Hello, We have a Canon EOS Rebel xti & the Canon EFS 18-55mm that originally came with the camera.  We have been using the camera with no problem for about 1.5 yrs when one day the Auto focus stopped working.   I tried moving the auto focus switch to manual and back, with no such luck.  I have successfully taken manual photos in the past and the Auto focus did work afterwards. Additionally, the auto focus does work with our telephoto lens.  I suspect that there is something wrong with  the Canon EFS 18-55mm lens, but wonder if I'm simply overlooking something.   I haven't taken the lens apart, trying to avoid that, but not afraid to try if needed. I appreciate the help. Tom My EFS 18-55 IS can autofocus in 1 direction only after about 18 months. I think this is a design fault about a broken flexible printed board. If you can read chinese, you may check the following link (WARNING---DON'T do it yourself, unless you really know what you are doing): http://www.mobile01.com/newsdetail.php?id=7554 Anyway, there are some interesting photos of the lens.
I see this same problem occuring all over the internet on Canon lenses. Autofocus not working any longer. For some stupid reason the lense will lock up and quit autofocus while other lenses will work fine. A light pull on the lense focus ring away from the camera body will give a noticable pop or click which unlocks the jammed lense. Try it if you are having troubles with your autofocus. This is a very common problem and worth giving it a try.
Posted on Dec 20, 2010
I have the same issue with the 18-55mm auto-focus not working. Opened up the lens and found a broken flexible cable.
From the looks of design and location, this cable moves with the zoom lens, so it WILL break eventually if you zoom in and out a lot. Once it snaps, the auto-focus will not receive any info from the zoom position and cease to work as a result.
Highly suspect its a design fault. Hence the relatively low price of the lens. Replacement cable if same design WILL break eventually as well.
Posted on Mar 17, 2011
    New Friend:
Http://www.ebay.com/itm/New-Replacement-Lens-Focus-Aperture-Flex-Cable-For-Canon-18-55mm-EF-S-/180879022297
clockwise autofocus ok but counterclockwise autofocus not working. i opened to lens. i found that above linked item is broken (Focus-Aperture-Flex-Cable-For-Canon-18-55mm-EF-S). it is a cheap part but i think i couldnt chaged it :) must be go to repair shop.
Posted on Feb 16, 2013
    New Friend:
Common problem here is indeed a broken flat cable. Via Aliexpress a new flatcable can be ordered for ca Eur 4,- for 2 cables. Youtube shows several videos how to open the lens and replace the broken cable. I managed to repair my wife's canon efs 18 55 IS lens. Important advise 1; you will need very small Phillips 00 and 000 screwdrivers! Advise 2: When re-installing the gearbox make sure the gearbox shaft is properly connected to the focus shaft inside the lens! Advise 3: take your time to accurately glue the flatcable in the lens. Advise 4: It is not necessary to remove the outside rubber focus ring and additional screws as shown in some videos. There is enough room to replace the flatcable while using the right pincers.
It is great fun to notice that the autofocus is doing fine after this action for only a few Euros. Good luck!
Posted on Apr 08, 2017
  • 25 Answers
Yes this is a very common problem. I have got one lens repaired by Cannon repair center and I got back the old parts when they returned the lens. I have examined the cable. The came as my friend said does bend while focusing. But this same type of arrangement is used in many devices (ex. printer head connection to mother board). and they don't break in their life time. But this cable looks a little different. part of the fixed end has a stiff material attached to it, so this part of the cable isn';t allowed to bend, but portion immediately next to it bends. This in my opinion is the reason breakage exactly at the same point. I fee Cannon can examine the issue and find a solution easily by eliminating the stiff part on one end. A lot of customers who trust Cannon are put to difficulty on this account. I see no reason why cannon should not make this repair free of cost as it is obviously a design issue. There is no guaranty that replaced cable will not eventually break.
Purushotham
Posted on Jun 30, 2014
Canon rebel auto focus has stopped working
It may be the lens try a different lens at your nearest photography shop as the auto focus is usually a lens problem. other wise try resetting your cam remove all batts including the lithium one and the CF card wait about 20mins then replace if prob still persists then try again without any lens and see if it trys to focus and make sure the shutter is working if its ok so far then u need to try a new lens at local shop and then if it works the body is ok if not then it needs a service!
Jun 02, 2014 | Canon EOS 400D / Rebel XTi Digital Camera
Canon rebel xti focus issues
this does not seem to be like a problem in settings
please use a different lens and try the same
Aug 15, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
New Canon EFS 18-135mm IS lens failed to auto focus on EOS Rebel XTI and shutter won't release to take photo. Lens over a few months has worked without a problem. What is the problem?
Make sure both the lens and the camera are switched to af (auto focus). If that doesn't work remove the lens and replace it to make sure it is mounted properly. You can also check the camera with a different lens to make sure it isn't a problem with the settings on the camera. If all of that fails take it to a camera or electronics store that does service work to make sure it hasn't been damaged.
Jul 30, 2011 | Canon Cameras
Hello, We have a Canon EOS Rebel xti & the Canon EFS 18-55mm that originally came with the camera. We have been using the camera with no problem for about 2 yrs when one day the Auto focus stopped...
I've seen that before and in my experience it's usually due to the autofocus motor going. Your best bet would be to contact the Canon Imaging in your country and see what they suggest you do.
May 05, 2011 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Need Help, the auto focus of my canon 400D won't work.(I can still shot with manual focus)
Try cleaning the contacts on the camera body and the lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Oct 14, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
Autofocus gives erratic results
Are you using this indoors, in low light perhaps? This would be the most common reason for this happening. The only way to get around that is to use a "faster" lens, such as f2.8 / f1.8 / f1.4 etc.
If not, try cleaning the lens and camea contacts with a plastic eraser, make sure no debris falls in the camera body (hold upside down for this).
Jun 02, 2009 | Canon EOS Digital Rebel XTI Digital Camera
I think it might be a lens issue.
make sure you change the macro option. the macro must be activated if you are taking a picture of something which is close to the camera. if it's not activated, the picture will not be focused.
The same will happen if the item is far and the macro is ON.
Aug 14, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EFS Lens question- please help!!
Make sure that the switch on the lens is set to AF. If that doesn't work, you may have a faulty lens. The EFS 18-55 is not a high quality lens.
Mar 10, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Tamron lens for Xti?
if it is an auto focus lens that works on one eos camera, it should work on almost all of them. the only known exception is that some high end extenders will not fit the eos1dmarkII as it protrudes into the opening too far.
but a good rule is that if it fits without any obstruction issues, it should work. try cleaning contacts on the lens and camera body. if that doesn't fix it, talk to Tamron. you can use it manually, but will not be as easy and you would get less predictable results.
my suggestion is to always go with lens from camera maker.
sounds like there is an issue with the tamron lens. not the camera.
good luck
mark
Dec 16, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon EF-S 18-55mm f/3.5-5.6 USN Lens Logo
4,843 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
