Question about Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Natural Gas
Laars Teledyne Pool heater flames on for 2 seconds, shuts off
I have a Laars Teledyne Pool heater. It's about 10 years old. LLD 400 line. When I switch it on, I get flames for 2 seconds and then it shuts off. I tested the rollout and the pressure switches on front, and they are ok. Is it the ignition system that's failing. It uses a Fenwal Ignition System 05-339011-003. Any help please!! i have the same problem but my unit is a bit newer model #ld250n
    Problem Solver:
  • 9 Answers
You have no flame rectification.....LLD series heaters check for a signal through the flame to ground; if the module does not detect this signal, it go through two more trials for ignition and then lock out the module. There should be a flame rod and it may need cleaning. I use steel wool.
Posted on Jun 28, 2009
Heater runs about 40 min then shuts down . replaced water temp sensor and it still shuts down
make sure it is a propane heater propane burns hotter than gas if not correct heater it will overheat if ok check gas pressure if not enough heater will overheat you also might have too small gas line and are emptying it
Oct 10, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne laars dr-400 cycles on and off
if only runs 7 seconds then turns off need new flame sensor or clean it up
May 26, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a larrs lite lld 400 n it heats up but it doesnt get hot enough
if you have a bypass made of plumbing only open 1/2 way if you don't have one put one in if you slow the water down it will heat more per pass
Sep 18, 2010 | Teledyne Laars Laars Lx Pool Heater /...
I have a Teledyne Laars Lite pool heater Model LLD 250N. When I turn the heater on it will run for 10 minutes and turn off. If I turn the power switch off and right back on it will run agin for 10 minutes...
It sounds like your pool heater might have a defective controller (the part, not you). Check the controller and replace if necessary. It could also be that you need to cycle the ignition sequence until the air is out of the gas line. It could also possibly be that your gas valve needs to be replaced.
May 30, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars LD250 Propane Pool heater cycles on and back off
Do you replace the thermopile or check the milivolts?
Check the Pressure gas
You need replace all of them terminals and check again the milivolts at the gas valve
Apr 01, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
I replaced the ignition transformer in my Teledyne Laars epc325 pool heater and cleaned everything. When I switch the heater on the burners all work fine but they only cycle on for about 10 seconds then...
This is probally your ignition wire is bad and not reading flame at the pilot or your pilot is bent or something so that when the pilot lights the flame isn't hitting the sensor probe at the pilot. When looking under the heater use a mirror so if you get roll out of the flame you don't get burned. Good luck and be careful.
Feb 26, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Burner cycles on and off within 2-5 seconds. What could the problem be? Model Teledyne Laars LLD250N
Sounds like the flame sensor. If the sensor doesn't see a flame, it shuts off. Good luck...Lee
Oct 31, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
pull out flame sensor and clean with sand paper or emmoring cloth then try again should work (small black wire with sensor sitting above burners)
May 05, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Natural Gas  Logo
1,007 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Jay Finke
Jay Finke
Bill Jordan
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
