Question about Electronics - Others
Reading 4Gb Compact Flash
The photos show fine on the Olympus E500 camera review screen. However the computer says that the disc is corupted. Is there any way I can get the photos off as they are of a friends wedding
  • steve1online Oct 30, 2007
    Gotover the problem. I took another picture using the camera which appears to have reset the card so it is readable via the USB cable.
  • 661 Answers
Download the pictures from the camera direct using the appopriate USB cable, you should have no problem then..
I had exactly the same issue, with my freinds camera, turned out that my card reader just didn't like the card, I got an external reader and that worked fine.
Posted on Oct 29, 2007
Internal flash not working on olympus e500
The Xenon flash tube in modern strobes rarely 'burns out'. I would guess that a switch that is activated when the flash pops up is not working properly. More info can be found here: http://forums.steves-digicams.com/olympus-dslr/159660-e-500-built-flash-not-working.html
Dec 08, 2009 | Olympus EVOLT E-500 Digital Camera
My Fuji E500 shows a white screen when any photo taken outside
is it on shuter speed priority setting?
like manual over ride? if so put it back on auto setting
Oct 27, 2009 | Fuji FinePix E500 Digital Camera
E500 + fl50
you don't have to see the flash on the screen.
if the flash is on tll than he adjust itself to the camera setting
Aug 09, 2009 | Olympus E-520 Digital Camera with 14-42mm...
Memory card will not show up on my computer.
Verbatim compact flash card has over 200 photos corrupted files. I volunteered to take photos for local senior anniversary I was the main camera now, I have lost the content. Files are Dcim--JPO, POG and worse coded files not JPEGs and I even with trial acdsee repair I am unable to rename and restore these photo files. CVS photo was able to open some of the files with their program but advised we would need to find the proper recovery program to restore some of the files.HELP
Jul 20, 2009 | PNY 4GB Secure Digital High Capacity...
What size compact flash card can i use in a olympues e500 can i use a 8GB CF card
You should be fine using an 8g card, but do however make sure it is a type I or II and although you asked about compact flash I might add that the XD M type cards are cheap BUT extremely slow so be careful what you go with. Where ever you get the card from check their return policy just in case there is an issue with it. Also might want to enusre your firmware is up to date before you try newer cards.
Jul 19, 2009 | Olympus EVOLT E-500 Digital Camera
Camera not properly reading memory card
The problem stems from deleting some of the images from the PC. You need to copy all the files onto the PC, and delete all of them from the card on the camera. Then reformat the card on the camera. Then take 1 picture on the camera.
After you have just 1 new photo on the card, try copying the older files back onto the card in the same directory as the 1 new photo. This may work.
If it doesn't work, the problem may be with missing hidden thumbnail files. In that case you may not be able to get the photos to display on the camera again.
Dec 26, 2008 | Olympus Camedia C-160 Digital Camera
Photos on camera review but not memory card
before unplugging any usb device from the computer... it is best to safely remove before unplugging the device...
i used to just unplug before i lost over 200 pics. was able to recover using recovery software but the whole process took about 3 hours to do. since using safe remove.. not a single loss
some pros suggest formatting the card on regular basis to also clean the card of file fragments... but once card is formatted, the pics are not recoverable... be careful
Nov 15, 2008 | Olympus EVOLT E-500 Digital Camera
Olympus e500 internal flash not working
try resetting the camera back to factory defaults by putting camera in P mode, menu, custom reset
Jun 08, 2008 | Olympus EVOLT E-500 Digital Camera
No power?????
Not sure if this will help, but it seemed to fix my issue......I used a freshly charged battery. Removed both xD and Compact Flash memory from the camera. Powered on. You will see the menu flash and read that there is no card inserted. Power down. Place memory back in the camera. I can't explain my issue. The camera may have gone into a stand-by mode until the battery died and it just needed a reset? Anyway, hope this can be of use to someone. =0)
Mar 30, 2008 | Olympus EVOLT E-500 Digital Camera
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
