Question about Microsoft Office Professional 2007 Full Version for PC
ADDING SOUNDS IN EXCELL
AFTER CALCULATING USING EXCEL FORMULA,
CAN I GET A SOUND ALLERTING ME IF THE VALUE
IS MORE THAN A CETAIN NUMBER,SAY 100 ?
  • aamanzar May 30, 2009
    Thanks for quick response.
    I have tried every which way to write the formula ,without success.
    Perhaps you would be good enough to rewrite the formula so that I can copy
    and paste.
    Thanks.
    Azmanz
    President:
  • 1,383 Answers
No there is not any settigns that allert of sound on condition base.
Posted on May 30, 2009
    President:
  • 2,923 Answers
Here's the formula:
if range("A1").value > 100 then
BEEP
end if
and you might want to loop the BEEP so that it's louder/longer :
for x = 1 to 10
BEEP
next x
HERE'S ANOTHER ONE:
you can stick this code inside a Worksheet_Change event :
Private Sub Worksheet_Change(ByVal Target As Range)
If Range("A1").Value > 100 Then
For x = 1 To 10
Beep
Next x
End If
End Sub
I calculated percentage on excel using a formula but still it shows #value?. what do i have do to fix this? please help.
Right Click on cell with mouse and select format cells
then select number . If formula was for example percentage of cell a2 calculated from b2 calculated in c2 then in c2 you put =a2/b2
Then you can use percentage in the number format
or you can go =(a2/b2)*100
Also make the cell width more if a problem.
https://www.youtube.com/watch?v=UlD6vUKx2KE
Apr 08, 2017 | Excel Computers & Internet
In Excel adding positive and negative numbers
Yes,
  1. Select the column. (click on top of the column it will select)
  2. Right Click and select Format Cells.
  3. Select Currency in Category then press OK
b6298df.gif Now just type your Numbers i.e. 571 for $571 and -650 for -$650 and sum using the normal way.
That is Select the Cells which you want to SUM and Press Alt+=
This will bring the total just below the selected cells.
Thanks
Iqbal
Apr 02, 2008 | Computers & Internet
What is formula to find percentage of females in my workplace?
      To get around this, you can calculate your numbers as percentages first. For example, if you type the formula =10/100 in cell A2, Excel will display the result as 0.1. If you then format that decimal as a percentage, the number will be displayed as 10%, as you 'd expect.Aug 2, 2011
      How to do percentages in Excel - Office Blogs
      https://blogs.office.com/2011/08/02/how-to-do-percentages-in-excel/
    Feedback
    How to Calculate Percentages in Excel
    www.excelfunctions.net > Excel-Formulas
    Two Percentage Calculation Types. Calculate a Percentage as a Proportion.Calculate Percentage Change. Displaying Percentages in Excel Cells ...
    Excel formula: Get percentage of total ' Exceljet
    https://exceljet.net/formula/get-percentage-of-total
    Excel simply divides the values in column C by the total in C11. For the formula shown, the result is the decimal number .63. Because the Percentage number format is applied to cell E6, Excel displays .63 as 63%.
Jan 19, 2016 | Computers & Internet
How do i calculate a difference in a percent?
If the value in A1 is 100, and the value of A2 is 120, then the formula =(A2/A1)-1 will return 0.2. If the cell containing the formula is then formatted to display as percentage it will show as 20%.
Dec 13, 2013 | Microsoft Excel for PC
Insert a calculated field named % Change in Value to determine the percent change in values by type in Excel?
If field A1 is the old value and A2 is the new value, then the formula for A3 (% change) is:=(A2-A1)/A1*100You can remove the *100 if you want to format the field to the Percent type.
Sep 30, 2011 | Microsoft Excel 2010
What are the formulas in grading the grades uisng microsoft excel
Formulas are used to specify calculations based on values in designated cells. Excel supports basic calculations as well as statistical, trigonometric and other specialized functions.
Formulas used in Excel must follow a certain syntax.
  1. All formulas begin with an equals sign (=).
  2. Some formulas use operands such as +,-, *,/ for addition, subtraction, multiplication or division.
    For example, the formula =A1+A2+A3 would add the contents of cells A1, A2 and A3.
  3. Other formulas refer to different functions such as SUM, AVERAGE and others.
    For example, the formula =SUM(A1:A3) would add the contents for the range A1 through A3.
  4. Formulas can be combined with operands.
    For example, the formula =10*SUM(A1:A3) would add the contents cells A1 through A3 and multiply them by 10.
  5. Functions can be nested within each other.
    For example, the formula =SQRT(10*SUM(A1:A3)) would take the square root of ten times the sum of cells A1 through A3. When functions are nested, it is important that the number of left parentheses match the number of right parentheses.
Aug 19, 2011 | Microsoft EXCEL 2004 for Mac
Sometimes when I use a formula in Excel 2003 it will not calculate - it is as if the formula does not exist. an additional problem is that when the formula works it will not calculate several columns if...
Make sure, when you entr a formula that you hit the ENTER key instead of just moving to tyour next cell. To have all numbers added or moved, use the"Special" application, or change the value. Such as -if you are working in text mode and you enter numbers, they are only numbers in text mode. They don't have a value. Correct the cells to reflect numbers. Right click, format cell - select what you want.
Nov 05, 2009 | Microsoft Office Excel 2003 for PC
Steps to figure out formulas in excel
Hello this is Baris,
If you forget about the numbers and start naming your cells you can figure out your own formulas... Example :)
You buy apples, and you pay $2 per piece
in this case you have 2 numbers to find out how much you will pay.
price per apple
quantity
you have 3 apples you pay 6 dollars very simple right. 2 times 3.
Same thing in excel but this time you will just say price times quantity and excel will do the calculation for you.
Lets name your cells
Type in A1 Price
Type in B1 Quantity
Type in C1 Cost
Now, Column C is your calculation area.
Type in A2 2 (price for apples)
Type in B2 3 (quantity of apples)
Type in C2 =A2*C2 (price times quantity)
Now on, you don't have to calculate anything. You can change you price and quantity, cost will change by itself. Because the value in that cell is now related to other values in A2 and B2. I hope this gives you a starting point.
Sep 30, 2009 | Microsoft Excel for PC
FORMULA PROBLEM IN MS EXCEL
The cells you are trying to sum are probably text and not numeric values. Format them as number or convert them to numbers.
Apr 18, 2009 | Microsoft Office Excel 2003 for PC
Help with simple excel calculations
Hello.
For cell B1 you can use this (without the quotes) "=A1"
Then for cell A2 and down you don't need a formula, but for B2 you can use this formula. "=(B1+A2)" Then click on that cell and drag the mouse down for as many cells as you want this formula to include and press Control and F keys to fill the formula down the column.
For your second formula, you would type 100 into D1 and in D2 you would use the formula "=D1-E1" (again, no quotes).
Feel free to let me know if you need any more clarification or if I missed something!
Jun 10, 2008 | Microsoft Excel for PC
Microsoft Office Professional 2007 Full Version for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
