Question about Sony KP-43HT20 43" Rear Projection HDTV-Ready Television
Picture stretching with Red, Green, and Blue Image Overlays
Hi. A friend recently gave me this TV as they know I am thinking about getting into TV repair and I really want to fix it. It powers on fine and there are a couple problems with the way the picture displays.
The first problem I need to fix is image stretching. The best way i can describe it is to say that neither the top nor bottom of the screen travel in a straight horizontal line. The top of the picture appears to be pinned fine in the corners, but curves downward toward the middle. I guess to provide some imagery as to what I mean, the picture has the appearance of a cardboard box with weight on top that begins sag in the middle. Does anyone know what the problem is or how can i fix it? How much would it cost?
I'd appreciate any help. Thanks.
    Problem Solver:
  • 12 Answers
Assuming that you have adjusted the convergence and this had no effect. you might have some blown convergence chips and/or resistors. these make the 3 color line up with each other.. my 55 in phillips did the same thing and the more i used it the worst it got. first it was the blue and the red and finally the green., replaced chips and resistors and the problem went away... good luck.. a lot of soldering involved. but the chips are only like 11.00 each and the resistors are like ten for all three.
Posted on May 30, 2009
Convergence adjustment aligns red and blue picture tubes to align with fixed green tube. Green image appears to skewed (possibly out of focus) in one direction making it impossible to get red and blue...
Ur tv convergence are dead.U know how to solders?Must replaced the 2 STK convergence ICS,some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 04, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Signals to the tv from other sources and the image is P and G
Soon as though you have your wiring mixed up. Those leads, colors you describe are for Compnent Video signal....Red Green Blue. Now  the Others  are for Audio Visual signal , Yellow, Red, White... They are NOT compatable. IE: You cannot mix them. Check in your manual as to what  types of lead is needed how to wire it up..
Feb 01, 2010 | Televison & Video
53 inch projection tv...seems like the color red and color blue have shifted giving me a picture with red and blue shadows
For CRT projection TV's, this indicates that the Green picture tube is burned (warn out). The less green that strikes the screen, the more redish the image will look. You will need to find an old school TV repair shop that knows how to replace picture tubes.
In the case of a DLP style TV, the color wheel needs replacing.
Dec 29, 2009 | Hitachi Televison & Video
Picture is red
If you are running component video, make sure the blue is plugged in and in the right spot. Component video works like this: the green is a black and white image, the red and blue are cover overlays to make the image display properly. So if everything looks plugged in right, then try plugging in a composite video (Yellow) or S-video cable switching to the appropriate input, and see if the image is still red. If so, go to the set up and set the set to factory defaults, and see if that fixes the color issue, It's possible that the color settings on the TV are messed up, with the S-video plugged in go through the set up menu and see if you can correct the color issue IF THE IMAGE IS STILL RED WITH THE S-VIDEO OR COMPOSITE VIDEO, otherwise the issue is a problem with the component video cable.
Oct 01, 2009 | Philips 60P8342 60" Rear Projection...
Only red tube shows picture, but green & blue are on, just no pic
More likely the problem is the blue and green fluid in the tubes is so cloudy that its distorting the image. Get a fluid kit from www.tvrepairkits.com
Jul 29, 2009 | Philips Magnavox 9P6034C 60" Rear...
PT-L735 U projectors. Green screen and stretched
The green is the result of the blue device failing. Happens about 4000 hours or so. LCDs can't handle the heat. Check the scaling of the image of the second projector. 16x9 vs 4x3.
good luck
Jun 25, 2009 | Panasonic PT L735U Multimedia Projector
Panasonic rear projection tv convergence problem
Check the regulator and convergences ICs....accordianman
Feb 26, 2008 | Televison & Video
Sony KP-51WS500
does it have blue video image?
Sep 29, 2007 | Sony KP-51WS500 51" Rear Projection...
Red lamp issue
the color which you see has problem i think you might be seeing white slanting lines also with this. it mainly due to 1 supply to green video supply 2 loose cuntact in g.video section 3 green tr. defective 4 ckt from ic to green input is defective 5 chroma ic defective if supply is ok. regards
Sep 14, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Sony KP-43HT20 43" Rear Projection HDTV-Ready Television Logo
211 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
