TDK ded 840g
Bougth this unit from a guy and never been used but books , cd /, etc.
are gone need help.
Thanks pinrod
    Brigadier General:
  • 10,406 Answers
Look at the "back" of the device.
You'll see 40 pins (2 rows of 20 pins), 6 pins (2 rows of 3 pins), and 1 row of 4 pins.
The 40-pins is the "data" connection -- note that there is a "notch" centered in the plastic above the pins -- to ensure that the ribbon-cable can only be connected the _correct_ way.
The 4-pins is the "power" connection, note that 2 corners are beveled, again to ensure that the power-connector only fits in the _correct_ way.
The 6-pins are labelled: MA(ster) & SL(ave) & C(able)S(elect).
Move the small jumper to the 2 'CS' pins.
With the computer turned-off, connect the "data" and "power" cables.
Windows should "detect" this "new hardware", without needing a CD, and fully install the device.
Posted on Aug 23, 2010
Need driver for tdk external cd/dvd writer model ded+880N
external writers are plug and play , they do not need a driver. the disk i think your referring to will only contain writing programs but there are many free writing programs on google search. just plug the writer into any usb port and windows will find it and install the drivers automatically
Jan 24, 2013 | TDK (DED+880) DVD±RW Burner
what sort of problems are you having? Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jul 05, 2011 | TDK 840G indiDVD Internal DVD/CD Burner...
The Disk Tray will not open (TDK DED 440 DVD driver)
The lubrication inside your device may be insufficient or some mechanical problem has occurred inside preventing the device to open. Now, look at a very "small hole" near the Tray's front cover. If you see it, get a very small pin or even a needle to fit to that small hole. Now, press the "open" button in your device and then push that pin or needle in the hole at the same time to help the device to open.
Dec 29, 2009 | TDK (ded+440n) DVD±RW Burner
Same problem, no power cord
Try They sell replacement power adapters for almost everything under the sun. Hope this helps.
Aug 05, 2009 | TDK (ded+440n) DVD±RW Burner
Can a TDK (ded+440) Burner burn Dual layer disks?
In a word, NO.
call at 1-800-285-2783 or send an e-mail to
This burner has a history of problems. Originally made in 2003, it may be time for a new one.
Jun 30, 2009 | Computers & Internet
Tdk da 5700 not recording
Cleaning will not help if it plays fine and does not record.
The previous owner was right, those can only record on "Music CD-R or Audio CD-R" . If it does not have that printed on the disc, it willnot record with it. many people think that a CD-R they use in the computer will work, but they won't. So make sure you are not using a CD-R meant for a computer.
Try using Sony, they work good for me on most all recorders I repair.
If that does not work, you may just need it to be serviced, or take it back to the guy you bought it from and get your money back. He sold you a bad recorder. They are very exspensive to repair most of the time.
Sorry I did not have better news, good luck and let me know if you need any more help.
Jun 29, 2008 | TDK DA-3826 2-Disc CD Recorder
Instuction manual
Do you still need this? I have it. I could copy it for you.
Mar 25, 2008 | TDK (ded+440n) DVD±RW Burner
I cannot produce a finalized music cd able to be hear on regular cd player
the .wav file has to be converted to .mp3 or .cda prior to burning in order to hear it in a regular cd player. Those applications have the ability to turn .mp3, and .wma to .cda format, which is what normal cd players read but they lack the ability to convert .wav to .cda
Mar 01, 2008 | TDK DED+840 DVD±RW Burner
Just bought this CDR 570 and not use yet.
Reading the instruction manual - yes, life experience has taught me some really useful stuff! -
Under 'Discs for recording' on page 7 it says at end of section
To ensure proper working of the set we recommend the use of PHILIPS audio CDR and audio CDRW discs only'
Roughly translated I read this to me - 'don't blame us if the set don't work using other (non-compatible) discs' !!
Oct 02, 2007 | Philips CDR570 CD Recorder
Open Questions:
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
