Question about Garden
My Mower won't stay started after it uses the gas that has been pushing into the mower via the primer bulb
My Mower won't start for more than 8 sec. I changed the spark plug, gas, oil, etc. I cleaned it inside and out including the carb. left in rain for 5 min accedentaly, cleaned, na da. Help. Thanks Craftsman sears eager-1 lawn mower model# 131.90261 I prime my mower and it runs long enough to use the gas I pushed into it via the primer. 5 pumps on the primer, 5 seconds it runs, 10 pumps on the primer, 10 seconds it runs. It ran fine the first time I used it this year but quit as I was finishing the yard and now won't stay started.
  • KEN LaPOINT
    KEN LaPOINT May 11, 2010
    Have you cleaned the jets/holes in the carb with spray carb cleaner?
  • 3 Answers
Either the magneto or the governor is damaged check them
Posted on May 30, 2009
Try using a non ethanol gas
Posted on Aug 03, 2012
Lawn mower won't run. Cannot start it.
sometimes the primer bulb gets cracked and wont properly pump fuel into the carb. replacement of the bulb should fix the problem.
Jun 15, 2013 | Garden
New primer bulb but engine won't prime
remove and clean the carby. clean out the main jet. ensure that there is nothing stopping the primer circuit from working. There are two valves under the primer bulb and a spring. when you push in the bulb fuel is squirted into the manifold When you take your finger off the bulb the spring pushes it out and new fuel is drawn past a valve to fill under the bulb. Pushing in again closes that valve and opens a second valve which allows the fuel into the manifold again
Apr 26, 2013 | Garden
Where is the primer ball
It may not have a primer ball. If it does, it would be attached to the carberator. If it starts, but won't stay running, that could mean your carberator needs to be cleaned/serviced.
May 29, 2012 | Mtd 22" Yard Machine Push Mower
Can you run your lawn boy mowers without the primer button being used?
Yes you can. The only reason small engines have the primer button/bulb is to get gas to the carburator to make it easier to start it. If your mower starts OK without using the primer bulb you will not harm the mower.
Apr 14, 2011 | Tecumseh Lawn Boy Push Mowers Insight...
I have a Craftsman Gold 6.0 mulching mower with a B&S engine on it that has been idle for about 10 years. It was only lightly used before that and I ran the gas tank dry before putting it away. Today...
Sounds like the primer bulb dry rotted from sitting &/or the float is stuck in carb. If gas is indeed leaking from bulb. It will need to be replaced. While it is apart, clean carb inside & out with spray carb cleaner.
Sep 06, 2010 | Craftsman 675 Torque 190cc 21" RearBag...
Lawn mower starts and stops right away
take bowl off bottom of carb....clean and reassemble
Nov 16, 2009 | Garden
Won;t start
I got a new air filter for mine today, plus cleaned out the metal fuel canister under the carburator and the little brass bolt and my mower started right up. I was having hte same problems getting my mower to run and stay running. Glad I checked this site!
Sep 09, 2009 | Mtd 22" Yard Machine Push Mower
Wont start and primer button stay`s in when pushed
try loosening the gas cap, if the primer bulb still stays in when pressed replace the fuel filter.
Aug 11, 2009 | Electric Lawn Mower
Push mower runs then quits!!
My toro mower starts and will run for ablut 15 minutes and starts to cut out and eventually stop running. What could be the problem
Apr 01, 2009 | Craftsman Garden
Garden Logo
2,041 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
