Question about Acer Aspire 4720 Notebook
Not functioning. can i downgrade vista home premium to xp
My laptop appears pxe-e61: media test failure check cable.what does it means?
  • 70 Answers
This means that there is a problem with the cable connecting your harddisk and motherboard either their might be loose connection or the cable must have gone bad in that case it has to be replaced with a new one.
Posted on May 30, 2009
Pxe-e61: media test failure, check cable
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Next - to check if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an USB mass storage device and you cannot open the various folders and files on this drive, then this confirms the hard drive is faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 22, 2012 | HP Compaq Presario R4000 Notebook
Pxe E61 Media Test Failure Check Cable
my server ph prolite doesn't start gives an error essage "PXE-E61: Media test failure, check cable" the reboots after 5 seconds
Apr 22, 2012 | HP ProLiant DL180 G5 Server
When I turn on the Mini laptop, what does this mean: Realtex RTL8101E/8102E PCI-E Ethernet Controller v1.08 PXE-E61: Media Test Failure, check cable PXE -M0F: Exiting PXE ROM Operating System not...
media test failure like above while
booting means that the problem already solved as long as you can get
into Vista/win7/xp as usual. PXE shown in the massage is
the Ethernet network boot option which you’re not using. There are 4 options you can use for boot up the laptop:
1. Network
2. DVD/CD
3. USB Storage
4. HDD
That was better to use HDD unless you are connected to a LAN then you need to change it to Network
Aug 31, 2010 | Dell Inspiron Mini 10 Notebook
When I turn my laptop on a black screen appears with: PXE-E61: Media test faliure, check cable PXE-M0F: Exiting Broadcom PXE ROM. No bootable device -- insert boot disk and press any key I do this and...
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. Please click on this link and follow my instructions :- http://www.fixya.com/support/r4377704-pxe_e61_error
May 29, 2010 | Acer Aspire 5720-6661 Notebook PC
Operating System not found
Vista OS is corrupt...you may need to re-install the OS....
some or many of the required files to load the OS is corrupt or missing...
the solution: Re-install Vista OS or Win7 or XP....
if your have your HD partitiond and have only OS and re-instalable programs in C: / and keep your critical data in say D: or E:..drive.....then you just need to format only C: and install the OS again....
May 04, 2010 | Microsoft Windows Vista Home Premium with...
PXE-E61: media test failure check cable
"PXE-E61 Media Test Failure, System won't boot"
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration(F10)
This Will Solve this problem
May 25, 2009 | Compaq Presario-Notebook 700 Series, 2500...
PXE-E61:Media Test Failure
you got that error message because your harddrive isnot detected so it try to boot from network and you don't have OS in the network.
Most of the time is your hdd is dead. In some cases the motherboard is dead.
You can replace your hdd.
for OS (vista vs XP), if you have enough rams and high cpu, you should install vista, but for me, I prefer XP.
for the price, you should call microsoft seller.
Jul 05, 2008 | Acer Aspire 5050-3242 Notebook
PXE-E61 Media test Failure
hy i have your solution.its simple. the problem is remote network data entry that start in the bios systems, produce by a virus call downloader.trojan or bootable Tj.exe, normally the bios has to read it and it gives the error " media test faliurecheck cables",ir you dont repaired quickly your laptop or desktop eventually will not boot the windows att all, this have to be kill before that happens, First of all clean your pc with Trojan Remover and then do just a simple task restart your desktop or laptop and do not let it initiate windows just press F2 at the bios and go to the Bios program and then go to the tab name Bios and press F9 that means "default bios systems" and everything will change in your bios and when your desktop or pc restart it will never show that message again and your bios will initiate with no problems and the virus that put that into your pc will no longer control your bios system.
May 11, 2008 | Computers & Internet
PXE-E61: media test failure, check cable.
Save your self a lot of reading, do this first.
Check in BIOS rom for start up sequence and check if there is an asterist (!) in front of the hdd. If there is, it’s disabled. Select the hdd and press shift key plus “1′ This removes the ! and you can then use the hdd to re-format or….
Dec 15, 2007 | Toshiba Satellite A105-S4004 Notebook
Acer Aspire 4720 Notebook Logo
54 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
