Question about SanDisk Sansa Fuze MP3 Player
My computer does not see my device in mtp mode...
When i plug in my device,my computer does not see it.the screen says connected but it does not charge.i can't download or practically do anything with my device. I'm having a similar problem, but this doesn't work. When i have it in MTP mode or auto detect, i just get a message that the device i've connected has malfunctioned... and then nothing. When I connect it in MSC mode, it recognizes it, and i can put stuff on my micro sd card, and presumably the players memory, however it doesn't recognize what i already have on there. It works just fine on my friends vista pc, i'm using XP SP2.
  • Mike Matkovic May 11, 2010
    I assume you are running Windows XP on your computer? Do you or have you installed the drivers on the CD that came with the device ?
  • 20 Answers
Http://www.fixya.com/support/t1629467-computer_wont_recognize_sansa_fuze, solution is here
Posted on May 30, 2009
I have mitone mp4 player (MITMP26) 4 GB . I have a problem. USB device don't see my computer. Windows 7 64 bit. Please help me.
Hi, player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Sansa player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
SOLUTION 3 - Connect using MSC mode
Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the mitone mp4 player firmware
NOTE: mitone mp4 player Express and mitone mp4 player Connect do not have MSC mode. For mitone mp4 player Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes:
If you have replaced the mitone mp4 player Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting.
- Try connecting on another computer.
- Try using a different USB cable
- Try connecting to the back USB ports which may supply better power.
- If only MTP mode is not working, try reinstalling Windows Media Player
For Windows XP try also download and install the MTP Porting Kit.
Hope that helped And please don't forget to rate me..
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
Tip
My Computer won't recognize my MP3 player...
For Windows XP users: verify the following operating system requirements are met.- Windows XP SP2 or higher- Windows Media Player 10 or higher
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.- Download the hotfix from http://support.microsoft.com/kb/939211.- Run the hotfix.
Next:-- Refresh the drivers. Connect the MP3 player to the PC. The screen on your player should turn on, show 'Connected' and indicate the battery is charging or full. - If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.NOTE: - If there is nothing showing on the screen and the player does show up as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed.
Next - Check under Device Manager1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane.
NOTE: Most MP3 Players can connect to your computer in MSC or MTP mode. There are exceptions which only use MTP mode. MTP mode is the recommended and default method for some MP3 players. Some players will show up on Device Manager's right pane as:1. USB Mass Storage device (if the player is set to MSC)2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, refresh the drivers. To refresh the drivers1. Right-click the error mark, select Uninstall.2. On the top menu, click Action then select Scan for hardware changes.
Next: - Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player.
The USB Mode setting can be enabled on some players after updating to the latest firmware. If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the firmware.
on May 31, 2010 | Audio Players & Recorders
Sansa e250 MP3 Player: The computer won't acknowledge that my Sansa E250 ...
Hope this helps. See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher Download and install the latest Windows Media Player if it's not installed. If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix. Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit ......
May 16, 2010 | SanDisk Sansa e250 MP3 Player
Sansa e250 MP3 Player: won't play any music or change to any other format...
Hope this helps. See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher Download and install the latest Windows Media Player if it's not installed. If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix. Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit ........
My Red Sansa Clip 4GB will not show on any computer i plug it into, It only charges and i have tried the auto detect, mtp, and msc settings. Any Suggestions?
May 17, 2010 | SanDisk Sansa Clip MP3 Player
On my mp3 i had washed it on accident but the battery was dead when i did i tried to plug it into the computer it did nothing; i dried it it finally worked with my computer reading it and all; i instantly...
Try and reset the player. Reset the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Then try this Connect the player to your computer. The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the players screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. <<<<< BUT TRY THIS FIRST >>>>>
Check the Device Manager 1. Right-click My Computer, and select -- > Manage.
Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS.
*** See This Tip Posted here **** --> http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <--
Copy this address into a new window.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. >>>> BUT TRY THIS <<<<<<< Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Verifying and changing the USB mode of the device to MSC or MTP From the Main Menu, select Settings > USB Mode.
Feb 23, 2010 | SanDisk Sansa E280 MP3 Player
I'm having trouble charging my mp3 it won't stay connected how do i fix that?
Refresh the driver
Solve your MP3 Player Connection Problem.
Refresh the drivers
Feb 22, 2010 | SanDisk Sansa Clip MP3 Player
MTP Mode Doesnt Work
Try uninstalling MTP Mode in the Windows Device Manager, and replugging the player - set the menu setting in the Sansa itself to "auto" for USB Mode before replugging. Let me know how it works.
Jun 13, 2008 | SanDisk Sansa e260 MP3 Player
Deleting demo songs
For Windows XPTM users, you are connecting the device in MTP mode to the computer by default. You will need to set the device to MSC mode, so go to the device menu\Settings\Advanced\Protocol = > Press Play/Pause key to select MSC mode which will appear as such on the screen. Reconnect the device to the computer, and you can now see those files and delete them.
DO NOT forget to set the device back to MTP mode when finished, so go to device menu\Setting\Advanced = > Select MTP mode.
Apr 20, 2008 | RCA S1000 MP3 Player
Deleing songs
Feb 10, 2008 | RCA S1000 MP3 Player
SanDisk Sansa Fuze MP3 Player Logo
260 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
