Question about Sony PlayStation 2 (PS2) Console
PS2 Memory Card Read Error
The system doesn't recognize memory card in slot. If I hold it in REAL firmly we may be able to save a game on occasion ummm my memory card is a 64 GB and it can only read certain games but my friend just gave me a tna impact game for my birthday but it cant read it
    Sergeant:
  • 233 Answers
I must assume that the card you are talking about is not a Sony brand memory card. Sony Playstations are very picky with memory cards and can cause strange malfunctions even permanent damage if they are not Sony brand or Sony approved memory cards. Sorry that doesn't fix it, but my brother lost his by using a non Sony memory card. It fried the machine.
Posted on May 30, 2009
Hi. My new H61iCafe board should be able to recognize 16 GB (4 memory slots). I have bought 2 8-GB-Kits (each consisting of 2x4GB): Kingston KVR1333D3N9K2/8G After inserting 2 modules, 8 GB are...
Number of Memory Slots: 4-240pin
Note:
1. Before you install memory module on this motherboard, please read below message to avoid any improper installation: - Due to chipset limitation, if you plan to install three or four memory modules on this motherboard, please install only single-sided memory modules.To install two memory modules on this motherboard, please install them on DDR3_A1 and DDR3_B1 DIMM sockets.
2. For the detailed installation information, please refer to the user manual or quick installation guide. - Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows 32-bit OS. For Windows 64-bit OS with 64-bit CPU, there is no such limitation.
Memory Standard: DDR3 1333/1066
Aug 12, 2011 | Asrock H61ICAFE LGA 1155 Intel H61 HDMI...
I installed 5G memory cards to my Gateway GT5238 PC, 1024 MB DDR2, Intel core 2 Duo E6300, 9-in-1 memory card reader, Non EEC, 4 slots, max memory 8192MB (8GB), PC2-6400, 8500, 5300, RAM DDR2. It had 1G to...
  • You Gateway only supports up to 8 GB. memory. Hence it will not see your 5 GB. dimms
  • tops: 8129 MB (8 GB.). 4- 2GB. Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
  • Specs:
  • Installed: 1024 MB DDR2 (PC4200), 533 MHz memory (two 512 MB modules)
  • Expandable to: 8 GB (4 memory slots)
  • How much memory your Windows OS will recognize depends on which version of Windows you are running. 32-bit versions of Windows will see (and utilize) only 3GB or 3.5GB. To utilize more memory, install a 64-bit version of your OS. More information about OS memory maximums can be found at http://www.crucial.com/kb/answer.aspx?qid=4251.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
    Thanks, Joe
    Dec 02, 2010 | Gateway Computers & Internet
    How do you erase memory from the memory pak
  • Plug an N64 controller into the "Player 1" port on the Nintendo 64.
  • 2 Place the N64 Controller Pack into the memory card slot on the Nintendo 64 controller.
  • 3 Insert a Nintendo 64 game into the cartridge slot on the N64.
  • 4 Hold down "Start" on the N64 controller.
  • 5 Turn the Nintendo 64 on via the "Power" switch on the device. After the console loads, the Controller Pack menu will appear on the screen.
  • 6 Release the "Start" button on the N64 controller.
  • 7 Browse through the saves listed, using the N64 controller's directional pad.
  • 8 Highlight the game you want to erase.
  • 9 Select the "Delete" option. The pages that were occupied by the game save will be erased from the Controller Pack.
  • 10 Repeat Steps 7 though 9 until you're finished erasing pages on the Controller Pak. Restart the N64 if you wish to play the game that was inserted into the device, or turn the Nintendo 64 off if you are done using the console.
  • Read more: How to Erase Pages on an N64 Controller Pack ' eHow.com http://www.ehow.com/how_6566153_erase-pages-n64-controller-pack.html#ixzz15ZouU9Pe
    Nov 17, 2010 | Nintendo 64 Console
    Breath of fire 3 on PSP gives a insufficient memory to save error with an essentially empty 4 GB duo memory card - why?
    I had the same problem, solved by downloading a save game in gamefaqs and putting the save in the memory card, then just overwrite the save in the game.
    The game does not recognize memory card above 2GB.
    Hope that helps.
    Mar 12, 2010 | Capcom Breath Of Fire III for PSP
    RAM Upgrade
    Not only is there a maximum amount of memory that your computer motherboard can accept, there is also a maximum amount of memory that your operating system (OS) can accept. For instance, when you install 4GB of memory in a 32-bit Windows system (the most common version; 64-bit systems are typically used by high-end users), your system reports only 3GB or 3.5GB.
    First , we can assure you, there isn't a problem with the memory. While Windows allows for 4GB of memory to be addressed, it does not equate to 4GB of physical memory. Some of the memory (regardless of how much you have installed) is reserved for use by the devices that you are using, such as a graphics card, PCI card, integrated network connections, etc, meaning it is unavailable for use as normal main memory. Upon startup, your system calculates the amount of memory needed for these devices; if you haven't maxxed out the memory in your system, it's invisible to you, and all your physical memory (the installed RAM) is available for use. However if you've maxxed out the DRAM in your system, this amount will be deducted from your physical memory, so you can't use 100% of your DRAM. The maximum memory limitation varies by operating system, For instance, the 4GB memory limitation doesn't exist in 64-bit versions of Windows.
    Click on this link or copy and paste the complete link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Jun 06, 2009 | IBM PC 350 PC Desktop
    PS2 memory card (64 bit) says it is corrupted. Help! What do I do?
    Well... Go into the Memory Manager, select your (corrupted, of course. ;D) and format it. That of course will make you lose all your saved games, ouch. You need to turn on your system with no games in etc and your memory card in its slot that way you can go to the memory manager.
    Dec 21, 2008 | Sony PlayStation 2 (PS2) Console
    Medion ram upgrade
    I'm not a guru, but your predicament is pretty simple.
    Depending on your OS (XP 32 bit, XP 64 bit, Vista), the OS will be able to recognize a certain amount of RAM. XP 64 Bit will be able to recognize up to 6GB of RAM. Vista, I have no Idea. 32 Bit, what you're seeing right now.
    Sorry for wasting a bit of money on that last stick.
    Nov 30, 2008 | Medion MD 7317 17" Flat Panel LCD Monitor
    4GB memory not being recognized
    To recognize more than 3.5GB RAM you must use a 64 bit operating system
    ordinary 32 bit O/S only recognize max of 3.25 to 3.5GB ram
    Oct 31, 2008 | ASUS A8N-SLI Premium Motherboard
    Have you tried cleaning the open connections?
    Apr 08, 2008 | Sony PlayStation 2 (PS2) Console
    my system keeps saying the memory card has been removed and i even try holding it in or switching slots but it doesnt work???? I HATE MY PS2
    Dec 05, 2007 | Sony PlayStation 2 (PS2) Console
    Sony PlayStation 2 (PS2) Console Logo
    132 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
