Question about Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television
Changed bulb and still no picture or sound
I replace the bulb with a new one. The fan in the back fires up and the red LED light is solid and the Green blinks ten times and the tv restarts itself it has done it 8 times like the books says and still no sound or pic same problem
  • Toshiba Master
  • 1,525 Answers
Hello i think when you put a new bulb in you have reset the bulb counter good luck
shaun
Posted on May 30, 2009
My brother has a 60" Sony xbr1 year 2006 and the red light blinks when you turn on but no picture or sound. Has a brand new bulb, that's not the issue.
Could be a cooling fan. Sometimes they don't start because of dust buildup. Could be worn out also. I had to replace mine once. Can order via internet.
Nov 14, 2014 | Sony XBR-60LX900 BRAVIA LX900 Series 60 3D...
Mitsibushi WD-60638 , just replaced the lamp now tv flickers and shuts off with a solid red led light , can anyone help me fix this ?
not sure but check internal fan is functioning correctly...I had same problem with a hitachi
Feb 23, 2013 | Televison & Video
No sound or picture. red timer light on. wd60735
This model as 3 LED indicator lights:
1) Power/Timer 2) Status 3) Lamp
If "STATUS" LED is blinking RED:
1) Internal Fan has stopped. These tv's require fans, to prevent overheating and causing damage.
If "STATUS" LED is solid RED:
1) Circuit failure (short)
2) Disconnected DVI cable, chassis to engine
3) No LAMP-EN signal from Engine to turn the lamp On.
4) Ballast UART communication problem.
If "LAMP" LED is solid RED:
1) Lamp Failure - Lamp failed to turn On.
2) Lamp is broken (e.g. burst or blown)
3) Lamp turns Off during P-ON
There is no data relating to TIMER LED being solid RED.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Mitsubishi Televison & Video
Sharp projector Bulb replaced but still won't work?
check the ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Nov 08, 2012 | Sharp Projector Lamp For Xv-z90 Xv-z90e...
I put in a new light engine and a new bulb and no picture
U check the ballast?Replaced it might solved ur problems.
Apr 04, 2010 | Toshiba 62HM95 62" HDTV
Hitachi ED-S3170 Projector problem
If the bulb is under warranty then take it back.
Jan 26, 2010 | Hitachi ED-S3170 Multimedia Projector
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
Mitsubishi WD-52525, replaced bulb but still not working
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
this is what we at the shop check first. it is quite common. on the power supply board look for swelled up capacitors
Dec 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Replaced bulb in Mitsubishi WD-52525 and it still does not work
Press the input/device button and the menu button at the same time. Green LED will blink a two digit code blink 1st digit short pause blink 2nd digit longer pause and repeat. Any number of problems can cause this same symptom.
If the red LED your refering to is the Status LED and not the Lamp LED then you have big problems. A red Status LED indicates no communication from the Format board to the DMD board (light engine). 1/2 the time caps on the format board itself the other 1/2 must send entire electronics package to Mitsubishi.
Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television Logo
362 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
