Question about Bosch Washing Machines
Error message 3h
Bosch logixx front load washer WAS28440 error message shows 3h
fanny
  • 146 Answers
SOURCE: Neff V4380X0 Front Load All-in-One Washer... error e06
Check the drain pump and any associated hoses to and from the pump. There may be a blockage, restriction or the drain pump could be jammed or seized.
Posted on Nov 04, 2007
canbruce75
  • 1776 Answers
SOURCE: My Asko W6441 front load washer F3 message
Hello. You said that you checked the drain line for obstructions, but did you check the pump? I would remove the hoses from the pump and using a flashlight, look into the suction port on the pump. Check the pump for any obstructions (like the occasional stray sock) and check the pump impellers. Look for broken/missing blades and ensure that the impeller spins freely. If there are missing/broken blades or if you cannot get the impeller to spin freely, the pump is defective. You may have already done this, and if so I apologize. Anyway, hope this helped and best wishes.
Posted on Aug 28, 2009
  • 35 Answers
SOURCE: e17 error code
Hi shawn833,
F17 Turn the tap on fully, check that the supply hose is not kinked/jammed; clean filter. Also check water pressure is not too low If all these test ok you need to run a load with no clothes with 1 cup of white vinegar this will solve your issue.
Regards
R.K.
Posted on Oct 21, 2009
SOURCE: Bosch washing machine logixx 8 front loader error
Det er for koldt i rommet, eller vandrør har frosset til.Sett opp temperatur i rommet eller tine rør
Posted on Jan 15, 2010
  • 414 Answers
SOURCE: f:23 code logixx edition75
Usually means there is water in the base pan and the flood safety has been activated. If you tip the unit forward a touch you will most likely find that water is expelled from the bottom front. The machine should work but obviously the source of the leak has to be found. Check door gasket for tears etc, water valves and drain hoses.
Hope this helps.
Posted on Jul 07, 2010
My Bosch Logixx 8 sensitive won't work and shows the code: F:43
Bosch Logix with error code F43 has "a motor fault".
You can reset the error code by the follow steps:
1. Turn the appliance knob to the off or reset position, 12 o'clock.
2. Turn the knob to the 6 o'clock position.
3. Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position. Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off
When your turn it back on it should have cleared the error code
Check motor connector block
Check wiring
Check motor carbon brushes
Check tacho connections
Check motor
Apr 03, 2014 | Bosch Logixx WFT 2806 Front Load...
Bosch logixx 8 E57
Circut board of the motor is demeged.if you take out the board witch is next to the moyoryou will see on the electronic print
The demeg.
Nov 20, 2013 | Bosch Logixx WAS2446 Front Load Washer
Error f57 siemens WM14S794GB Front Load Washer
Bosch Logixx 8 Only 4 years old. Inverter Print burned out creating error F57.
Jul 27, 2013 | Washing Machines
Bosch logix8 comming up with the code nro
Bosch Logixx 8 error code nr0 means - The childproof lock has been activated.
Just deactivate the childproof lock.
Apr 10, 2012 | Bosch Logixx WFT 2806 Front Load...
F:23 code logixx edition75
Hope this helps.
Jul 07, 2010 | Bosch Logixx WFT 2806 Front Load...
I have a bosch WFR 2460 washer. Er:15 error code.
You need to check and clean pump filter, normally located behind a removeable plastic cover at bottom front of washer right hand side.
If no filter found there remove rear panel of washer, and clean pump from rear of washer.
Please rate my solution.
Thanks.
Nov 11, 2009 | Bosch Logixx WFT 2806 Front Load...
My Bosch washing machine (logixx 8) shows error code F37 and beeps
F37 is because of operating the unit below specified temperatures.
Pressing the temperature button twice shows a snowflake and sets a defrost function.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 06, 2009 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
211 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
