Have full luminence from back lite but no video from any source screen is dark
    Scholar:
  • 191 Answers
Hello Carl,
To isolate the issue get back to me with the following information.
  1. When did you experience this issue?
  2. Did you hear any noise coming from your Television?
  3. Are you able to see menu options on your Television?
  4. What is the make and model of your television?
  5. Please ensure that the power supply is sufficient and as given in the product specifications.
Please answer to my questions to isolate the exact cause and to assist you further.
Posted on May 30, 2009
Black spot on screen
all ps vita model has black
spots...panels also have defects known as
clouding (or less commonly
mura), which describes the
uneven patches of changes in
luminance. It is most visible in
dark or black areas of displayed
scenes. So you are not alone!
Mar 29, 2013 | Video Game Consoles & Games
When I stream something to watch even when I let it buffer.It works fine but when I switch to full screen it lags behind and behind and behind that the picture does not match the sound.Is it my graphics...
Try using a different player or CODEC. A couple of very good ones are K-Lite Full and VLC
VLC is probably the easiest to install and will work "right out of the box" so to speak. K-Lite is a CODEC pack that installs a number different audio and video COder / DECoder (hence the term "CODEC"), and can player a larger variety of audio / video sources. Most people will have very good luck with VLC or K-Lite Full versions.
I hope this helps & good luck!
Jan 30, 2013 | Computers & Internet
Nintendo DS Lite went dark
send it in and have it repaired
Jan 05, 2010 | Nintendo DS Lite
Really bright luminous colors
If you have Nvidia card, you may see rainbow colors over multiple objects and you need to switch the following settings off:
VIDEO->ADVANCED SETTINGS->PIXEL PER LIGHTING OFF.
VIDEO->ADVANCED SETTINGS->VOLUMETRIC SHADOWS OFF
VIDEO->ADVANCED SETTINGS->FULL SCREEN POST PROCESSING OFF.
Aug 04, 2009 | Eidos Interactive Conflict: Global Storm
MY SCREEN KEEP popping to black?it annoys me?
so is your screen like fading to black and back to bright when u do something? If it fading in and out try adjusting the monitor settings on the monitor itself. Whats happening is your monitor is trying to save energy so it dims. The setting is Luminance on most monitors
And by the way u cant reach a video capacity cause the memory dumps the info when it needs space to process more video.
May 23, 2009 | Intel Motherboard
My daughters ds lite power is on it's a green light
Hi there!
Pop the battery out, it's underneath under a screwed on cover then put it back in. Worked for me. Alan.
Jan 03, 2009 | Nintendo DS Lite Console
RE:nintendo DS lite power light comes on but both screens stay dark?solution
Wotterz.
This is a problem with the cpu on the systemboard. I've seen this problem many times if the DS Lite is felt to the ground. The contacts of the cpu are very fragile. The DS Lite turns on, green led available, even charche is working bot nothing else. Repair of this problem is almost impossible. The only thing you can do is send it to Nintendo.
You can test if it is the cpu by removing the bottom of the DS Lite and put the battery on te contacts.
Press firmly on slot 1 (the aluminium cover) and turn the DS Lite on. If you got a picture on the screens then you know it for sure. The cpu is located under slot 1 and by pressing on de top of the slot you are pressing possible loose contacts back on de systemboard.
If it is not working then the cpu is to musch damaged.
Let us know what you've found with this solution.
Sep 20, 2008 | Nintendo DS Lite Console
How is a flashlight both luminous and nonluminous at the same time?
At first light it DOES sound a bit confusing.
First, the definition of the term 'NON-LUMINOUS'; 'Not capable of PRODUCING light but can be capable of REFLECTING light from another source'.
For instance, our MOON is NON-LUMINOUS as it REFLECTS light from the Sun. The SUN is LUMINOUS as it produces light that is REFLECTED off the surface of the moon. And so, LUMINOUS means capable of PRODUCING light.
Now closely examine your flashlight.
The BATTERIES produce electrical energy which is transferred to the BULB which emits light, thus LUMINOUS. The tiny little BULB emits quite a lot of light for its small size. However, the bulb is contained within a concave silvered cone which REFLECTS,(NON-LUMINOUS) gathers and channels the emitted light from the BULB (LUMINOUS) into a BEAM which ILLUMINATES whatever you are pointing the flashlight at.
Our cameras would be just paperweights if there were no NON-LUMINOUS surfaces for the light to REFLECT off of, back into the camera lens, onto the 'plate' thus etching the image. For example, take a photograph in the dark without the flash and what do you get. No LUMINOUS, no NON-LUMINOUS.
And so there we have LUMINOUS and NON-LUMINOUS, ILLUMINATING our lives. Enjoy! :)
Jul 21, 2008 | Vector Power On Board High Intensity...
JVC 27" TV
Adjustable Color Temp. The Adjustable Color Temperature feature lets you adjust the color balance on your TV, depending on the type of light in the room, such as direct sunlight or artificial lighting. On your remote control there should be a button that lets you change the picture mode, IE. Rich, Personnal, Cinema, Sport etc...
Feb 21, 2008 | JVC AV-27D305 27" TV
Screen too dark even with all brightness settings set to max
The picture is very dark it is mostly due to 1 power supply output is low. 2 voltage on crt g2 pin is low. 3 video output supply is low. 4 some components in luminance section might be defective or loose. 5 finally crt getting weak is set is old. good luck
Sep 21, 2007 | JVC AV-27430 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
