Question about Okidata 591 Printer
Ribbon Slips Off Okidata ML 395
The ribbon keeps slipping off of our Okidata Microline 395.
I've removed the head to clean out any built up "gunk", but it appears to not be taking up the slack well enough as the printhead moves back and forth.
After printing a few lines, the ribbon will slip out over the capstans.
It was printing just fine until I did this as I replaced a ribbon that had gotten "chewed up" at the end of its life.
When this happened in the past we were able to send it in for repair and the repair people said the printhead was not seated properly, but did not elaborate further.  I have a working ML 393 right next to it, and as far as I can tell, both print heads are seated exactly the same.
What am I missing?
Thanks,
James
P.S.  You have no product category for this printer.
  • Fastserv Oct 22, 2007
    I'll now answer my own question so it will be available for people in the future:
    The problem is with removing (and incorrectly re-installing) the printhead.  As I alluded to in my question, the head was not re-installed correctly.  When the printhead is put back on the printer, it absolutely MUST be held so that it's pulled as far back away from the roller as possible while still being seated in its recess before tightening the screws which hold it on.  If this is not done, it causes drag against the ribbon and the ribbon does not advance as fast as it should be when printing.
    I found this out by reviewing a service manual I'd downloaded.
    I suppose the reason this elaboration was not shared by the repair facility previously was because it's an easy buck for them to make if it happens again.
    - James
    Habit-Forming:
  • 40 Answers
Your printhead is in correctly but not aligned, Please loosen the 2 screws that holds the printhead.Remove ribbon(all this while the printer is powered off) Now look on the right side there is a lever that makes the printer go closer to the ribbon ,move the lever to number 9 and move the head over to the left side of the printer.push the head forward slightly towards the black roller and tighten the 2 screws again ,install the ribbon and move the blue lever to 1 and try printing again.
Hope this helps.Dezzi
Posted on Nov 29, 2008
My Okidata 320 microline print cartridge is leaking ink. What does this mean?
The Okidata Microline 320 uses a ribbon. If it smears, just back the tension lever off until it goes away. Smearing will happen with multi-part forms unless you back off the printhead.
Jul 25, 2011 | Matrix Okidata Microline 320 Printer
Problem with new installed printhead
If I remember the 320, there is a head-gap adjustment that is normally moved for replacement of the head and must be reset again. Check your manual for that term; 'Head gap adjustment'
Aug 18, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
ML 490 Print smudge
Cleaning the surface of the print head with a
lint free damp towel may cure the problem
or for our free technician support call us at our toll free no 18884276640
Jun 23, 2009 | OKI MICROLINE 490 Matrix Printer
How do you replace an okidata microline 521 printhead?
turn the printer off
remove the ribbon
on the right side of the head you will see a silver lever/tab lift up on that it is hinged on the left side
lift head straight out
reinstall in reverse order
Feb 02, 2009 | OKI MICROLINE 520 Matrix Printer
Microline 320Turbo 9pin
The problem your having is with the carriage assembly. You'll need to remove the ribbon and printhead. It's the black piece under them. Here's a link to a replacement part for $38.95.
http://www.str-s.com/okidata-turbo-carriage-assembly-p-716.html?manufacturers_id=6&osCsid=8849c8b4
Hope that helps you. :o)
Oct 14, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata Microline 420
This would be the print head pins not moving forward or the ribbon bunched up at the top.
Sep 23, 2008 | OKI MicroLine 420 Matrix Printer
Alarm light flashing
Is the front cover on the printer(ifs its not the alarm light will keep flashing as there is a sensor that will trigger the alarm if the cover is not on or not on properly.Hope this helps?
Dezzi
Jul 16, 2008 | OKI MICROLINE ML-395 Matrix Printer
Alarm red light flashing when I switch on the printer
HI ,
Is the front cover on ? becuase this printer cannot work with the cover off ?If the cover is on remove the ribbon and power the printer on if it works the ribbon could be the problem.
Dezzi
May 13, 2008 | OKI MICROLINE ML-395 Matrix Printer
Printer not printing the top of the characters
Yes quite possible pin broke on head, check ribbon is fitted correctly and has plastic sheild on front of it intact
Jan 18, 2008 | OKI MICROLINE ML-395 Matrix Printer
Okidata 591 Printer Logo
555 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
