Question about HP Computers & Internet
Windows Vista, my keyboard stopped operating. I changed the old keyboard with a different keyboard that was working on another computer. Now that keyboard will not work on either computer. HP was NO h
On a Compaq desktop with Windows Vista, my keyboard stopped operating. I changed the old keyboard with a different keyboard that was working on another computer. Now that keyboard will not work on either computer. HP was NO help.
    President:
  • HP Master
  • 2,923 Answers
What type of keyboard are you using? Is it a PS/2 or USB type of keyboard? If it's a PS/2 keyboard (with round purple connector), you may need to restart the computer after connecting it to the computer. But if it's a USB keyboard, there's no need to restart the computer because USB is just a Plug-n-Play device.
You need to isolate the problem. If you're using a USB keyboard, try connecting the keyboard into different USB port of thecomputer. Or try different computer to see if the keyboard is still functioning or not.
If you got the same problem after pertorming some test, it's better to consult the computer manufacturer for second opinion.
Posted on May 30, 2009
Why have ive lost the function to use the at key
Hi Diane Andrews
You stated as you have lost the @ function on your keyboard . And by looking at your DP i suppose its a laptop . Well then if so you might need to reset the keyboard layout settings for your laptop . Different OS has its different settings . You might have changed your language settings which may or might have caused it . Steps on how to its here . But if you have lost the @ key itself then ... you might need to get it change at your nearest computer repair shop or bring it to the vendor . Or maybe for time being you can use the on screen keyboard
CLick start - under the search - type On screen Keyboard and select it to use it .
Basic .. Fix an external keyboard and try if it works on that keyboard . If it does then your laptop keyboard might be at fault or need to change the settings .
Method 1 of 3: Changing the Language Settings (Windows)
If your keyboard is not displaying the correct characters when you press keys, your language settings may have gotten changed. If you have the incorrect region selected, your keyboard will act differently. To change it back, open the Control Panel.
You can access the Control Panel from the Start menu. Windows 8 users can right-click on the Windows button and select Control Panel from the menu
Open the Language settings. How you access this depends on which version of Windows you are using.
Windows 8 - If you are in Category mode, select "Change input methods" under the "Clock, Language, and Region" section. If you are in Icon mode, select "Languages".
Windows Vista and 7 - If you are in Category mode, select "Change keyboards and other input methods" under the "Clock, Language, and Region" section. If you are in Icon mode, select "Region and Language" and then click the "Keyboards and Languages" tab. Click the Change keyboards... button.
Windows XP - select "Regional and Language Options", click the Languages tab, and then click Details..
Select your language. Use the menu to select the default input language you want to use. In Windows Vista and 7, select your preferred language from the "Default input language" drop-down menu. In Windows 8, move your preferred input language to the top of the list.
Sep 15, 2014 | Acer C7 Chromebook
I have a VAIO SVE15114FXS. I believe this is a hardware problem, as it seems to be OS independent. Tested in Windows 8.1, Ubuntu (several versions). Do these systems share drivers? Unsure if it would...
The drivers for Windows 8.1 possibly not being installed can cause these problems. The drivers for each type of Operating System are different. When you install an operating system generic drivers are used and some of these will cause unusual problems. The Windows drivers are known to cause problems. Ubuntu drivers are usually installed with the Operating System. Drivers from the computer manufacturers can be downloaded for each Operating System.
Oct 22, 2013 | Sony VAIO Computers & Internet
I have two problems with my HP compaq 6830s running VIsta business SP2 1) My inbuilt web cam stopped to work, and i have tried to uninstall and reinstall drivers with no luck. 2)The wireless card,...
If you upgrade your operating system like from windows xp to windows vista, you need to install new hardware driver for your computer like for LAN, webcam, WAN and others because the old driver is only compatible with the old operating system and not with VISTA operating system. Solution would are, download webcam and WAN driver for Windows Vista and install it into your computer. Don't just upgrade your computer because the configuration is not the same with the old operating system. If problem still exist, just upgrade the service pack from 2 to 3. There is available install for upgrading the service pack of each operating system. and surely all your hardwares will function.
Dec 29, 2010 | HP Compaq 6830s Laptop
I took a hardrive from an HP Pavilion 743c tower and put it in an HP Pavilion a1648x, computer turns on and loads, my problem is that the mouse and keyboard don't work. not sure if they are not being...
I think you really need to boot from a boot disk (windows xp - vista - 7) for your operating system - and attempt a repair from there. Your computers have different motherboards and parts.. windows installed drivers for them are not close enough.
I have had success in xp by doing this: before removing drive from old computer - you go into device manager and remove everything - drives, video card, mother board last and leave keyboard and mouse .. so you can shut it down .. then install into new machine and it finds most everything and then you install your drivers there.
Good luck,
Bill
Nov 29, 2010 | Computers & Internet
Wireless keyboard stopped working tried changing batteries and resetting but no joy
Does it use bluetooth? If so you need to make sure your bluetooth is turned to ON on your computer.
Jul 04, 2010 | Microsoft Windows Vista Home Premium with...
Keyboard stops working after password has been entered in Vista
Please follow steps below to reset your Windows Vista Password in 10 minutes.
Steps :
1. Insert the Windows Vista DVD into the DVD drive and then restart the computer.
2. Change Boot Options 1st Priority to Optical Drive.
3. When system booting up, if the message “Press any key to boot from cd” appears, immediately press Enter.
4. On Language Settings, Time and Currency and Keyboard Layout screen, just choose the correct settings then click Next.
5. On Install Now screen, click Repair. Note: Click No just in case you get the message: Windows found problems with your computer’s startup options.
6. On the System Recovery Options screen, under Operating System, click Windows Vista then click Next. Then select Command Prompt.
7. At the command prompt windows, type the following command then press Enter after typing each command:
c:
cd windows\system32
echo ~takeown /f %1 /r /d y > TakeControlOf.cmd
echo ~icacls %1 /grant administrators:F /t
ren Magnify.exe Magnify.old
ren cmd.exe Magnify.exe
8. Restart the computer.
9. On the Welcome Screen, click the Ease button.
10. Check Make items on the screen larger then click OK.
11. At the prompt, type the command then press Enter.
net user Administrator /active:yes
exit
12. Restart the computer.
Sep 27, 2009 | HP Compaq Presario CQ50-110US Laptop
Keyboard stops responding after a powersave on laptop ACER 5715Z
The issue is that several of the Acer software products don't support Vista. You need to remove these programs.
Follow the instructions in this link
http://global.acer.com/support/winvista/t-faq.htm
Due to architectural changes to Windows Vista®,some Acer applications are not supported anymore. Below is a summary ofthese applications. Uninstall these applications before the upgrade.
Acer eRecovery Management The new version of Acer eRecovery Management, which is compatible with Windows Vista®,requires repartitioning your hard disk drive, causing data loss. As aresult, the Wizard will not reinstall the new version of eRecovery onyour computer under Windows Vista®. However, you will be able to find similar features in the built-in Backup Utility of Windows Vista®, including full system volume backup to a HDD or CD/DVD. Acer eAcoustics Management Windows Vista® supports similar functions of eAcoustics so Acer will no longer provide this utility for Windows Vista®. Acer ePresentation Management You can easily manage your external monitor settings via Windows Vista® Mobility Center. As a result, we do not support an upgrade to Acer ePresentation Management. Acer ePower Management Due to architectural changes to Windows Vista®,Acer ePower Management cannot be upgraded for some models. However, youcan easily manage your power settings via Windows Vista® Mobility Center instead. Acer ePerformance Management For notebooks only. Since Windows Vista® provides similar resource management functionalities, we will no longer provide this for notebook models with Windows Vista®. Acer Arcade™ Deluxe 3.x
Acer eNet Management 1.x
Acer eDataSecurity Management 1.x Due to architectural changes to Windows Vista®, these applications cannot be upgraded.
Alternately (not recommended) you can change your settings with the following method. I would recommend removing all the Acer software though as keeping them might cause problems.
Check under Advanced Power Options-> Multimedia Setting -> When Sharing Media. By default onBattery and Plugged is set to "Allow the computer to enter AwayMode" Changing this setting to "Allow Computer to sleep" should solve theproblem. On Battery the Away Mode "does" allow the computer to sleepproperly.
Jan 27, 2009 | Computers & Internet
Windows Vista won't start after sleep mode
Please concider avoidind using leep mode.
Just disable it and use power saving instead.
(start - settings - control panel - power options - click on 'change plan settings and change sleep to never)
Thank you for using agadycom.
Nov 21, 2008 | Microsoft Windows Vista Home Premium with...
Windows vista
Windows Vista is the new operative system distributed from Microsoft, following the previous release of Windows XP.
An operative system is the interface between the user (you ) and the computer, that allows you to manage computer hardware resources and peripheral, and manage processes (software) running on your computer.
From the user point of view The operative syste is the environment where you run applications, manage connected devices, storing files and starting and stopping programs.
Vista is the latest OS released from Microsoft. It has a powerful interface, but it can be slow running on old computers. On vista you can also have some compatibility problem when you try to install old devices built for XP, such as printers, scanners etc.
See here
Windows Vista home page
Sep 11, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
364 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
