Question about Goodman CKL24AR24 Air Conditioner
Odor coming from furnace when running a/c
A burning like smell coming from inside furnace when running a/c. A/C unit is only a year old
    President:
  • 2,559 Answers
Sounds like your heating elements are coming on with the A/C This can be from an improperly wire thermostat or furnace.
Posted on May 30, 2009
Burning plastic smell when cold out run heater and fan inside car and out
Are you loosing radiator fluid. sometimes the heater core will rupture and you will smell burn odor. also check for strange rubbing sounds or screeching coming from the blower fan motor. or engine exhaust manifolds are hot when car is on, make sure nothing is leaning on them which will cause a burn odor. Any odor coming from outside will find it's way inside through the fresh air vents.
Feb 13, 2016 | Cars & Trucks
Gas appliances emitting odor
Sounds extreme but give your local Fire Station a call. They will be happy to break the monotony of the day at the fire house and come to your house with a sniffer machine. It will tell what the odor is? Then get a furnace engineer to check over and service your appliances.
It sounds to me like you might have a blocked flue, and that will cause carbon monoxide poisoning.
Let me know how you get on.
Feb 03, 2016 | Heating & Cooling
When furnace ignites making weird noise and i checked outside piping odore when running not the same as usuall once the blower kicks in furnce sounds ok but doent seam as warm as normal
needs a tune up. flame is probably yellow which means it is burning too much fuel and therefore not getting as hot and it would smell different also.
Mar 10, 2015 | Miscellaneous
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
This will be our third winter in our home, and for some reason this years when we run the heater it smells. The smell is similar to a stinky bathroom odor (that's the best way I can describe it). I...
Contact your Gas company tell them you have a foul smell coming in when you turn on the heater. They typically wont charge for a technician to come out and inspect the heater for you.
Nov 15, 2010 | Heating & Cooling
Burning smell and icing
Sounds like your blower motor in your furnace or air handler has burned up. shut the unit down and replace the motor. make sure the ice is melted and the unit is dry before you turn it back on.
Jul 17, 2009 | Sharp CV-P09FX Air Conditioner
Smell when unit comes on with heat
Hi!!!remember everytime you turn on yout furnace you will have a strange odor thats all the dirt that is burning from the heating element if your using the emergency heta if not the what you are smelling is your fan motor replace it and you should be fine..Good luck..
Jan 19, 2009 | Ruud Matching Split Air Conditioner
3 ton goodman heat pump package unit, odor coming from vents
I ran upon this a few years agoafter 20+ years in the industry it is actually called "DIRTY SOCK". In the winter the drain pan and trap dry out and all the junk left behind when the summer rolls around mix with the condensateand cause the odor. "Home owner fix" pour a cup of bleach down the drain and in the pan let sit for about an hour then pour a gallon of hot water, that usually takes care of it.
Nov 19, 2008 | Goodman CLQ36AR49 Air Conditioner
Burning smell from AC Unit
http://www.hannabery.com/faq14.shtml
"Odor problems can be as serious as a gas leak or as simple as a dirty air filter. But remember, a good mechanic doesn't just use his hands. He uses his ears and nose. Unusual odors could indicate a serious problem and should not be ignored.
We will go through each of the five categories and list the possible causes and things to check.
1. Electrical odor - Electrical odors are usually caused by parts overheating. Indoor blower motors are a common example. If there is a mechanical failure such as the bearings seizing up, the motor over-heats and the insulation on the wires and the motor windings themselves start to melt, causing the odor.
Sometimes loose electrical connections cause wires or plastic relays to overheat causing electrical odors.
It is possible for a very dirty air filter to cause the odor. If the airflow is restricted enough, it could cause electric resistance heaters to overheat, even burn-out.
If you smell an electrical odor, check your air filter. If it is not blocked, shut off equipment at the breaker if possible and call for service.
2. Burning odor - This is similar to an electrical odor only worse. It is also sometimes accompanied by smoke. Once again, this can be caused by parts or wiring burning-up.
It can also be debri such as plastic getting into the ductwork and melting on the electric resistance heaters or heat exchanger.
If you smell a burning odor, check your air filter. If it is not blocked, shut off equipment at the breaker if possible and call for service.
3. Gas odor - First of all, if you really smell gas and suspect a gas leak, you should open the windows, get out of the house, then call the gas company.
Now excluding that "worse-case" scenario, if you notice an odor that smells like gas and it seems to be coming out of the supply vents, it usually isn't gas. Sometimes dust that settles on the heat exchanger during the summer months burns off at the beginning of each heating season and it smell just like gas.
If the odor doesn't seem to be coming from the vents, try to pinpoint where the smell is coming from. Use your nose. If it is gas, it usually would be from a leak in a pipe fitting or at the equipment itself.
Gas odor is the one that causes the most fear. People think of gas explosions or carbon-monoxide poisoning. Well, gas explosions are very rare and carbon-monoxide for the most part is odorless.
Having said that though, don't take a gas odor lightly. If you can't locate the source of the odor and you are worried you have a gas leak, remember, open the windows, get out of the house, then call the gas company.
4. Oil odor - Oil odors are usually caused by one of two things. An oil leak/drip or an oil burner that is not working properly.
The oil leak is usually easy to spot. Just look for oil. Check the burner itself, the oil tank, filter and oil line. Sometimes it is just a matter of tightening a fitting. If there are no signs of an oil leak then it is most likely a burner problem.
This can be caused by many things, too many to list. It could be a minor adjustment to the burner to a faulty or blocked chimney. From a bad fuel pump to a plugged oil nozzle. Listen for any unusual rumbling or banging sounds or smoke or soot while the burner is running. If you notice any of these things and/or you have an oil odor, you should call for service immediately.
One other common problem today is that new houses are insulated so well and are built so tight that they run out of combustion air, causing odor problems. In this case it is just a matter of bringing in a fresh air for the burner. Call your local Heating Company to assist in a proper diagnosis.
5. Damp and musty odor - This is more common in the air conditioning mode. Sometimes attic units or very damp basements have this problem. Check for air leaks in the return ducts. Check for water damage to the ducts or air handler itself. Possibly consider having your ducts cleaned. Run a dehumidifier and see if the odor goes away.
But this odor problem is almost never due to a problem with your equipment.
Final Tips:
Keep in mind that almost all heating systems cause an odor the first time they are fired-up. And the first few times at the beginning of each heating season. Brand new furnaces are coated with oil to keep the heat exchangers from rusting. This burns off, creating a bad odor - even smoke. But it usually only lasts for about 20 minutes. Opening the windows usually solves the problem. And the first few times the backup heat on a heat pump kicks on, it smells like an electrical smell. This might last for a few days but isn't that bad. If you are worried, call for service.
Remember to check for a clean air filter and that your vents are opened. Check to see if the fan is working which mean your motor hasn't burned-up.
Check for air leaks in damp areas, oil stains or rumbling sounds, strong gas odors - these all indicate problems. Do not ignore them.
Hope this helps, remember - these are just rough guidelines and not all possible situations are covered."
Jul 28, 2008 | Sharp CV-P09FX Air Conditioner
Burning plastic smell INSIDE refrigerator
look for a door/light switch, and depress it do the lights go out?? bad switch will keep the lights on and melt plastic lens covers.. could also be nothing and you happened to open open the door right as a defrost cycle was completing( there is a heating elemnt in your freezer) watch your dairy, ice cream nad milk are real good indicators of refrigeration issues. as far as runnig all the time no real" time limit" as to how long it should be running.
Mar 03, 2008 | Refrigerators
Goodman CKL24AR24 Air Conditioner Logo
266 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
