Question about Toshiba 61A61 61" Rear Projection Television
61A61 TV IS WILL ONLY PICK UP ONE CHANNEL #66 AND NOT CABLE INPUT
HOOKED CABLE TO IT LIKE ALWAYS HAVE AND IT ONLY SHOW CHANNEL 66 FUZZY. TRIED TO RESET THE LOCKS ETC. AND NOTHING DOING. ALSO TRIED INPUTTING VIDEO TO FRONT PANEL AND HAD SOUND BUT NO PICTURE.
  • ROLYAHS69 May 30, 2009
    FLORIDA PANHANDLE, MILTON FLORIDA. MEDIACOM CABLE COMPANY. NEVER HAD A PROBLEM TIL WE HAD TV UNHOOKED FOR A FEW MONTHS AND SWITCHED FROM DIRECTV BACK TO CABLE TV
  • Mike Matkovic May 11, 2010
    Where do you live and what service provider are you using ?
    Scholar:
  • 125 Answers
Cable companies are slowly but surely reducing the channels you can get without a digital box, which they will supply. You will need to cantact them and rent a HD cable box or converter from them that will work with your displays built-in tuner. However, if your display is HD compatible, then I would just asked your cable company for and non-DVR HD cabe box and connect it to your display with component cables....
Posted on May 30, 2009
Why are my channels fuzzy?
Hi Virginia,
I have the manual link for you for your TV, basically your issue falls into INPUT issue. Kindly check if the INPUT of your TV is correct. Steps below:
- INPUT SELECT button- Press to select
TV or the external input (VIDEO1,
VIDEO2) mode.
(See USING AUDIO/VIDEO INPUT JACKS.
- AUDIO (INPUT) L/R jacks- Connect to
the left/right channel audio output jacks of
a video camera or VCR.
Note: The AUDIO (INPUT)L jack is for
mono input. The sound is heard from both
speakers. Use this jack for monaural audio
equipment to be hooked up.
These steps is in page 2 of the manual. Hope it helps.
Emerson EWF2004 Owner Manual Page 2 Table Of Contents
May 05, 2014 | Emerson EWF2004 20" TV
I have a RCA LCD TV model no. RLC3708A and when hooking it up when I took it out of box, I got to
I think you are confusing the channel on the tv and the channel of the cable company that is not something that you can pick up with the scan tv, scan tv is good for picking up local channel meaning air channel that we get with a antenna only not the cable chanel
Jun 24, 2012 | RCA Televison & Video
Can't get "no signal" off
Hey cthaemar, it sounds like it may have been switched off the correct channel. If it is hooked up with a Coaxial cable it will be on channel 3 or 4, and if it is hooked up with an AV cable then it would be on one of the inputs.
If it's channel 3 or 4 try pressing the gray TV button on the remote and changing the channel. If that doesn't work you may need to use the TV's remote or the TV itself.
If it's on an input press the same gray TV button and then try pressing Input. With this you can also try the TV remote or the TV itself to change those if our remote doesn't change it.
Let me know if you have any other questions or concerns!
Tommy Faust
DISH Network
Jul 12, 2011 | DISH Network 322 DTV Receiver
Can anyone replace a cable tuner
I bought a 42" Akai TV that really was just a monitor because it didn't have a built in tuner. I dug up an old vcr hooked my cable up to it and plugged rca cables to the composite out on the vcr to the composite in on the tv and set the input on my TV to run off that input.I was able to change channels through the vcr it worked like a cable box. Thats just an idea that could save some bucks. Oh yeah, if you do this make sure you get an older vcr that has a tuner in it.
Mar 04, 2010 | Sony KDF-42WE655 Television
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
Can't get dvd player to work on this tv!!!
im guessing that you cant go to av mode because you dont have a remote, am I right? if thats the case you need to go to walmart and buy an RF converter. You can plug you dvd into the converter, then run a coax cable from the converter to your tv coax inout aka anteanna input, then depending on your converter switch your tv to either channel 3 or 4 and presto. it will hook up just like vcr's and onld nintendos use to. You can pick up an RF converter cheap at walmart or check e-bay, couple bucks and your watching dvds.
Jun 23, 2009 | RCA F36649 36" TV
Hitatchi 42HDF52 only receives channel 5 and 6 on analog RF input
If you have tried autoprogramming and have found nothing it may be a bad tuner. Is your VCR is hooked up via coax or into a video input? If it is hooked up via video and is working but the coax connection direct isnt it will be a bad TV tuner. Easiest cheapest fix is to use you VCR to change channels or get a Digital Cable Terminal from you cable provider and hook it into video or compnent.
Jan 29, 2009 | Hitachi 42HDF52 Television
Cannot get the television to get out of fuzzy screen
  • hit the channel return button on the remote
  • hit the tv/video button on the remote
  • perform a channel scan through the remote menu
  • unplug unit for over an hour and plug back in, complete initial setup by following instruction on the tv.
Jun 25, 2008 | Philips Magnavox 27MS343S 27" TV
Toshiba 61A61 61" Rear Projection Television Logo
107 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
