Question about Dual Car Audio & Video
Dual XDMA7715 faceplates
I have a Dual XDMA7715 head unit. the dual motorized face-plates. have had it for about a year and it's been 2 days now when you hit the open or eject button they both go to slide down then seperate as normal but they dont, they slide down juss a tad to show the slot to insert a cd then both plates slide back up in the closed position where you cant see the display faceplate in the rear, all you can see is the control faceplate. what can i do to fix this? it's irritating and can't use cds
Jexx
  • 148 Answers
SOURCE: Screen behind faceplate stopped illuminating/working
The ribbon cable has gone bad. A new one can be ordered direct from pioneer at parts.pioneerelectronics.com Good luck!
Posted on Nov 05, 2006
SOURCE: detaching faceplate on dual stereo XD 7500
if u read the booklet u would know take the deck out of the dash board turn unit upside down their are to small screws take them out then install it again
Posted on Oct 04, 2007
c renner
  • 43 Answers
SOURCE: Kenwood KDC-519 Faceplate Problem
Detach the faceplate and look at the electrical contacts on the back of it for damage/dirt - you can spray it with electrical contact cleaner. Do the same to the contacts on the head unit - it sounds to me like one or more of them are a bit loose or otherwise not working properly.
Posted on Feb 24, 2008
  • 3 Answers
SOURCE: Kenwood KRC -X858 Faceplate/Power Problem
I have the exact same problem. I called the tech line and the tech reported that the ribbon cable is probably broke. It is the flex cable between the head unit and the rotating face plate. He said it's not an expensive fix but we would need to mail it to a service center if you're like me and not near one. I just replaced mine with a new unit. It was about time anyways.
Posted on Dec 06, 2009
kenw392
  • 2226 Answers
SOURCE: Just installed Dual XDMA6330 has no power no lights no sound
the red wire needs to go to a switced power source. unless both the red and yellow wires are getting power, the deck will not turn on.
Posted on Mar 12, 2010
How do you take off he faceplate of a DUAL XDMA7650 CAR RADIO?
Two small screws hold the faceplates on a lot of the Dual drop down units Open the drop down face and remove the screws. Apply side ways pressure and slightly up from one side of Player. It should release
Jun 11, 2014 | Dual XDMR-7700 CD Player
XHDR6435 radio was working fine yesterday, now it will not turn on. the red led behind the faceplate flashed when i turn on the car, and cds will load and eject but the radio will not power up. i habe...
I just Spoke to tech support. This is what they said:
1. Key in the on position and the red power button lit, remove the face plate.
2. On the left bottom side press and hold the reset button, with a pen, for 10 seconds and let go. The red led on the right should flash.
3. Reinstall the face plate.
4. Push power. The unit should come back on.
Mine worked, and i was about to tear it out and return it. So try this first or even call tech support for Dual 1-866-382-5476.
Jun 14, 2011 | Dual Electronics XHDR6435
How do i remove my Dual xdma7715 from my dash? I find it nearly impossible to remove it, the previous owner of my car installed it.
Every aftermarket deck that is put in a vehicle slides into a metal sleeve into the dash. This metal sleeve serves two purposes 1.) To secure the deck inside the dash 2.) Serves as a theft deterrent
First thing you want to do is remove the faceplate. Second there will be a bezel (plastic ring that goes around the faceplate. This will be attatched to the deck and not the faceplate. It just snaps in all you have to do is apply pressure with one of your fingers to the edge and it should just come off. Now if you get this far you should be able to see the metal sleeve I spoke of earlier on the outside edge. The way the sleeve is designed it has perforations that act as little clips when the deck is initially installed. There are tools that are sold to apply pressure to these clips to disengage the deck. In the past I have done it simply with two butter-knives. You insert one on each side preferably in the center, this is where the clips will most likely will be. Both sides will have to be disengaged, at this point with them inserted you should just be able to pull it right out of the dash. Oh before you even get to the deck be sure to remove any dash pieces that are going to obstruct your movement. If you need anymore help then let me know
May 22, 2011 | Dual Electronics XDMA7715 Car CD/ MP3...
How do you detach the face plate on a dual xd 7600 audio and how do u use the iplug?
tab at bottom of faceplate is visible when open in the middle of face push in carefully and pull down. supposed to be able to plug into it and comes up on screen.
Aug 17, 2010 | Dual XD7600 CD Player
Missing face plate
What part is missing? Is it just the faceplate, or the gear mechanism as well?
I have one of these that the ribbon cable is bad and can't seem to find a replacement. I am debating just buying a new stereo. If i do, I could sell you the faceplate. email me at rad73082 (at) yahoo
Sep 12, 2009 | Dual XDMR-7700 CD Player
Stereo issues
I'm assuming that you installed the head-unit new and that the faceplate did (at one time) previously slide down the way it was intended to work - is this assumption correct?
Is the molding around the head faceplate (mounting ring) damaged?
Are you sure you're not using the semi-permanent mounting configuration??
(see page 6 of the manual)
This particular unit has the option for a semi-permanent mounting of the face plate. If the two screws are inserted into the sides, it will lock the face plate in to the head unit (have you done that?) - if so, removing the screws will allow the face plate to be removed.
May 29, 2008 | Dual Electronics BDS692 Coaxial Car...
DUAL XD7500 CD PLAYER PROBLEM
This is what the manual says:
With the unit off, press OPEN to allow the front panel to slide
down. Gently squeeze the release tab located on the bottom
center underside and pull faceplate down and away from unit
to remove. To install, insert left side faceplate first, then push
right side to secure.
Tried it and couldn't get it out.
Sep 05, 2007 | Pioneer DEH-P44 CD Player
Bad face plate!
It may be the flexible connector link connecting to the drop down faceplate.
Aug 14, 2007 | Dual XDMR-7700 CD Player
Dual XD7600 Head Unit Problems
Sounds like the flexible connector that connects to the drop-down front panel is bad, broken pattern lead.
Aug 07, 2007 | Dual XD7600 CD Player
Car Audio & Video Logo
504 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
