Question about Haier Mechanical Air Conditioner HWF05XC7
Strange straining sound
Air conditioner makes straining sound when you turn up thermostat and compressor kicks in. Sort of a WHIRRR..WHIRR..WHIRR but if you back the t'stat down the compressor goes off and the sound goes away!
    President:
  • 1,902 Answers
Either compressor is going bad or the fan is rubbing. There is a condensor fan that comes on only when the compressor starts. So check the fan out first to make sure that it is not rubbing or moving around. If that is not then check the compressor by letting it run for about 5 minutes then touch the top of the compressor. BE careful as it can be extremly hot that will show you one of two things either bad compressor or condensor is dirty and a garden hose with a jet blast of water will solve the problem. If that doesnt work either compressor is bad and will either need to be replaced for about 250 dollars or unit will need to be replaced
Posted on May 30, 2009
Auto/On set to ON. Fan runs.
Sounds like the thermostat, the way to verify is to unplug indoor unit, remove thermostat, take pic of wiring with phone or label the wires as to the terminals. Carefully twist the yellow,(Y) Red (R) and the green (G) together. Plug the furnace back in, if the unit operates normally, replace the thermostat. I am basing this on the fact that the blower speed is changing. This could also be an anomaly within the circuit board in the furnace section, not likely though as the outside unit (condenser) is not controlled n by the indoor board unless this is a heat pump. hope this helps. D
Jul 21, 2015 | Dometic Rooftop RV Air Conditioner
I have the air conditioner in full blast and it sounds like it's only in fan mode and it doesn't have the heavy sound and my room doesn't get as cold as it used to
Hi!!
It seems the compressor is not kicking in, this could be due to:
Thermostat settings,
Faulty thermostat
Low on R-22 freon gas
Faulty compressor or Relay.
Faulty wiring
Don't forget to rate this post!! Good luck!!
Jul 29, 2010 | Whirlpool ACQ062XJ Air Conditioner
Rooftop RV Air Conditioner: temp outside 90 or above. compressor kicks off ....
It sounds like maybe an overload for the compressor is tripping and resetting once the compressor cools. Possibly due to a low charge.
May 03, 2010 | Heating & Cooling
I noticed some straining noise coming from my a/c unit today. The fan on top of the condenser runs fine but as soon as the compressor tries to kick on the fan stops for a split second and you get a kind of...
You amy ahave a bvad capacitor on the outside unit. It starts the fan and the compressor. You can change this yourself. Open the outside panel and you will see a silver canister with terminals out the top. Replace this and I think your problem will go away. On the cap. it will say something like 30uf 5uf 370 ot 440 Just get these numbers and get a new one. Russ
Aug 14, 2009 | Goodman CKL24AR24 Air Conditioner
Sometimes compressor does not kick on
It sounds like the coolant charge is marginal. There are sensors that can monitor the pressure levels and can disable the compressor to prevent damage to it. You need a tech to check the system before you lose it completely. Figure on $100-120 cost for check and recharge if needed.
Aug 06, 2009 | Dometic Rooftop RV Air Conditioner
Ac starts kicks on and off every couple mins
Sounds like the compressor is the one making the "NOISE". If the sound sounds like something trying to start, then kicking off, its probably the compressor and not the fan. Hence no cool air.
Jul 26, 2009 | Dometic Rooftop RV Air Conditioner
Carrier air conditioner cycles on and off
The compressor/condenser is being called all the time. The reason it goes off is because the evaporator (indoors) freezes up when the fan is told to turn off by the thermostat. This further cooling lowers the low side pressure below the low limit switch point turning off the compressor unit.
Solution: Make sure the thermostat is wired correctly. Green wire is usually the compressor wire but maybe not.
Jun 17, 2009 | Carrier 38BRC036 Air Conditioner
A/C runs but Compressor Does not Kick-In
Sounds to me like the contacts that are humming. Check your fuses or breaker.
Feb 26, 2009 | Dometic Rooftop RV Air Conditioner
Haier Mechanical Air Conditioner HWF05XC7 Logo
208 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
