Question about Jabra BT125 Headset
How to pair my Jabra BT125...
I have lost the instructions on how to pair my headset with my Sony Ericsson. The blue light flashes in all sorts of sequences and I just can't get it to pair up...? it wont go into pairing mode while connected to my PS3. plus i dont have the instruction manual
    Sergeant:
  • 233 Answers
Here is a link to a page with links to your instruction manual.
http://www.jabra.com/Sites/Jabra/na-us/Headsetsupport/Pages/JabraBT125.aspx
Posted on May 30, 2009
How to connet to cell phone?
Hi,this is a detailed description of how you pair your jabra headset to your phone;
Pairing Instructions:
1. Please ensure that the Headset is OFF, i.e the blue light is not flashing.
2. Press and hold the answer/end button until you see a solid blue light (approximately 8 seconds), then release.
3. Set your phone to “discover” the headset by following your phone's instruction guide. Typically, the steps involved going to a “setup”, “connect”, or “Bluetooth” menu on your phone and then selecting the option to “discover” a Bluetooth device.
4. When your phone finds the “Jabra BT125”, it asks if you want to pair with it. Confirm this by selecting “yes” or “ok”.
5. When your phone asks for a passkey, enter “0000” (4 zeros) from your keypad and then press “yes” or “ok”.
(Note: Pairing must be done every time the Headset establishes a link with a different mobile phone or other Bluetooth compatible device)
Thanks and take care
Apr 27, 2010 | Jabra BT125 Headset
How do i program my jabra bt125 headset to my cell phone
taken from the manual found at
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT125%20Black/Documents/User%20manual/BT125_UM_NA_EN_471.pdf
1. Put the headset in pairing mode
• Make sure the headset is off .
• Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT125
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 3).
3. Your phone will find the Jabra BT125
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Dec 04, 2009 | Jabra BT125 Headset
I cant pair my jabra bt125 with my nokia n97
This is one of the mistake commonly done by many people. First you need to pair. Let me walk you through. First, the headset has to be switched to pairing mode which is done by holding the on button for a while even after the headset is switched on. Then the bluetooth headset light will remain on. You switch on the phone bluetooth, search new device. Then select it and press the option for pairing. Read the instructions which come on the phone display and select accordingly. It will ask for passcode which is usually four zeros. Then it will get paired ask you whether to connect. You select connect and you are done.
Sep 02, 2009 | Jabra BT125 Headset
Can i pair jabra bt125 with samsung blackjack ??
Mine is a Blackjack II, but i did get it to connect. Hold the clear button down on the Jabra until it lights solid blue, keep holding it with one hand while you use the other hand to operate your Blackjack. I went to Settings, then Connections, then Bluetooth, then "Add new device". As long as my Jabra was lit solid blue, the phone found the headset. Then it will ask you for the pin code, which i found by accident (0000 - four zero's).
Jul 11, 2009 | Jabra BT125 Headset
I lost the instructions. I want to pair my Jabra bt125 with my motorola razr
1. I have the Jabra 125. You can get the manual at www.jabra.com if you have a different one.
2. Turn off your phone. Power off. The order of powering on devices is the key.
3. Press and hold your Jabra power button until it's glowing blue (not flashing blue light--but constantly on)
4. Then turn on your phone...and look for wireless devices in your phone menu.
5. Make sure you have bluetooth turned on.
6. the phone will find the Jabra, and then will ask to pair with it. passcode is 0000.
7. That's it.
Again, the key is the order of turning on devices.
Thanks.
Jun 05, 2009 | Jabra BT125 Headset
Cant par my jabra bt125
First make sure your bluetooth and your phone are fully charged. Next press the on - off button in the middle of your bluetooth until it is a solid blue color. If it is flashing it is not in the pair mode. Just hold it down until it is a solid blue light.
Then set your phone to the pairing mode following your phones set up bluetooth instructions. Select the discover, search, or add function on your phone. Your phone should find the bluetooth device and ask "do you want to pair with it?" Accept by pressing yes or ok on the phone and entering the passkey or pin # of 0000 or 4 zeros.
Your phone should confirm when pairing is complete.
I discovered that I was not holding the on-off button down long enough for my bluetooth to reach the pairing mode and give me a solid blue light.
I hope this helps as I know how frustrating this can be.
Jan 15, 2009 | Jabra BT125 Headset
Unable to set pairing between jabra bt 125 and bluetooth device
You simply need to hold the button down for a long time, it will flicker blue at first, don't let go of the button, and it'll turn blue for pairing.
Feb 03, 2008 | Jabra BT125 Headset
Instructions for the Jabra BT125 Bluetooth
For people who are having problems pairing their cell phone with their Jabra BR125 Bluetooth, here are a few simple steps:
First, make sure that the Jabra BT is off (the light should be off). If it's on, hold the flashing button until it goes off.
Second, turn your Jabra BT on. Continue holding your Jabra button (EVEN AFTER IT STARTS FLASHING). Hold onto it UNTIL YOU GET A SOLID LIGHT.
Third, as soon as you get a solid light try pairing up with your cell phone.
Fourth add your Jabra to your cell phone's Bluetooth list by having it search for the Jabra.
Fifth, the cell will ask for a passcode. The default passcode is 0000.
Aug 17, 2007 | Jabra BT125 Headset
Bluetooth Connection
on the jabra head set press and hold the button for about 3 seconds and then the blue light on the headset should stay illuminated. Then go to your phone and search devices, when your phone finds the jabra, you may have to put in a pairing code normally four noughts,zeros (0000), when inputed the headset blue light should change from a solid light to a intermittent flashing light, showing on your phone that the connection is succesful.
Aug 13, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Jabra BT125 Headset Logo
659 people viewed this question
Top Jabra Radio Communications Experts
Michael Vincent Cruz
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
