Question about HP (212489-6B0) (2124896B0) CD-ROM Drive
Content will not load from cd's in my drive
I just got the new computer. When I put a disc in the drive it usually will load nothing. The last time i tried I got the message of drag items here to write to cd but it should have already been full I have an HP DV2000T laptop. The CD/DVD Rom stopped reading cd's. Its always worked fine in the the past and for no reason it just stopped. CD's will spin, and the eject tray seems to work. But my pc doesn't seem to recognize the drive. In properties>device manager: I can't find the device listed. I've flashed the bios thinking that may be a solution but that didn't work. Any help would be appreciated.
    Scholar:
  • 106 Answers
Make sure you have the correct drivers, in most cases one must renew the drivers or should I say update the drivers.
Here is a link to get them just click on the proper Windows you are running:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3177435&lc=en&cc=us&dlc=en&submit.y=7&submit.x=4&lang=en&cc=us
Hope this helped
Good Luck =)
Posted on May 30, 2009
  • 700 Answers
Your cd drive cannot be detected. Check if it is detected in bios. If not two things, 1. its defective 2. loose contact. Your options reseat the cd drive for the first step, if still not detected then replace.
Since it is new, I assume it is covered by a warranty. Then ask the seller where you bought it. They have to replace or check that for free.
Hope this helps.
I hav e Zoo Empire for Scholastic on disc, when I try to load it the computer does nothing. Why will it not autplay?
It seems that you have Autoplay disabled on your computer, OR the disk is damaged OR the disk don't have "autoplay.inf" file on his root.
The best solution is to put your disk into the drive and try to access it via FileManager: Double Left-Click on MyComputer icon on desktop -> locate the CD drive and make Right-Click on the CD icon followed by the "Explore" option selection. A new window appears which shows the CD content.
Locate a file called "setup.exe" or "install.exe" or similar, and make double left-click on it! That's it!
Jun 27, 2011 | Computers & Internet
PC s/n = 0029975695: The tray will not eject. When
The usual problem with disc drives is a little belt that drives the loading tray. It stretches with age and slips, so the motor turns but the belt doesn't. If you want to take the time to try finding one, the belt is replaceable.
On the other hand, new DVD/CD burners are only around $30, so it's usually not worth trying to repair the drive. It's faster and easier to put in a new one.
Hope this helps. Thanks for using Fixya!
Mar 01, 2010 | Gateway (5502134) CD-RW/DVD-ROM (Combo)...
Disc shows loading then error on all dvd disc
Put a cd in the dvd player if it is marked that it plays cds... if it plays the cd your dvd laser is shot... cheaper to get a new unit. if it doesn't play a cd try cleaning the laser. and last but not the last thing try unplugging it for a short time then plug it back in... if nothing works get the one tool that fixs most everything...... take it to office depot and they can recycle the stuff inside and help keep the earth green...then onto wally world.
Nov 26, 2009 | Philips DVP5140 DVD Player
How do i transfer files from a disc to my computer. I have put the cd disc into the cd tray but nothing came up on the monitor
Depends on your your operating system but assuming you are using a version of windows you need to find My computer. This will open a window where you can see your hard drives & CD/DVD drives. Right click the CD drive you want to access and then click "Explore" or "Open" depending on your version of windows. Provided the disc is not damage this will allow you to view the content of the disc & drag it to a folder on your PC.
Sep 07, 2009 | Microsoft Windows XP Media Center Edition...
Error Loading Operating System
Do you still have the original recovery disc for the PC? If so, put that into the disc drive then boot the computer. It can help you either save the installed operating system or create a new one if there is a serious problem.
This could also be due to a hard disk drive failure, in which case you'd be needing to get a new hard disk. Most of the time however, just a file allocation table messes up during a power down, or some other random problem happened and just caused a simple error on the drive. I'd definitely find that recovery disc. If nothing else, you can use google to search for recovery boot disks that you can download and burn to a CD using a different computer. They can help as well.
Sep 10, 2008 | Acer Aspire 3050-1733 Notebook
Transferring pics to computer
Check the 'My Computer' for an unfamiliar drive; if as most PCs, you have a C:, D:, E: listed, these are the basics; C: & D: are the hard drive (partitioned), E: is whatever optical drive you have. You may have others such as several named drives for a digital card drive may be present too. Depending on how your camera's memory is recognized, you should have a drive you didn't before. Open the last named drive to see what (if anything) it shows for folders and files. If it brings up an error message about having nothing to read, work your way forward in the alphabet and check each. Customarily, Win will add any new drives at the end of the series of named drives.
If you find folders on a drive later in the alphabet, open them to look at the content. If you find a bunch of .jpg files, you are there.
If you find nothing, you may have to download an additional driver since the Praktica is not a real common camera, Vista may not have provided a default driver for it.
Sep 07, 2008 | Praktica DCZ3.2S Digital Camera
Vostro laptop dvd/cd player not seen by system.
Try to get into the bios settings to make sure the device is enabled there.
Aug 02, 2008 | Acer Aspire 5610-4648 Notebook
My Computer Wont Read DvD's or CDs!
Is the CD drive display in my computer? yes
then clean up your CD/DVD rom for there is dust in it, specially on the lazer lens that let the rom read the CD/DVD.
If no, then; Fix some cable connection towards your CD/DVD rom for it was lessen.
If not fix the problem verify the disc if it is readble by your Rom. Please try another disc in your Rom.
if same happen, then maybe its time for a new CD/DVD ROM.
one last try:
try your new purcahse disc in another computer that is compatible with your disc.
hope this help, melnavz
Feb 05, 2008 | Dell Dimension 3100 PC Desktop
PRINTER INSTALLATION PROBLEMS
Please check If your CD drive is detected on BIOS, if yes then Put a Windows XP bootale CD (checkout for the Service Pack) and choose boot from CD in the BIOS and go for "repair option" after the Agreement "I Agree-press F8" session. complete the installation then try installing the printer.
Oct 09, 2007 | Computers & Internet
HP (212489-6B0) (2124896B0) CD-ROM Drive Logo
176 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
