Question about Hayward H Series Induced Draft Abg 100,000 Heater
Hayward pool heater h series
Brand new heater. Worked fine for first 6 hours, brought pool temp from 45 to 70. Now it cycles, lights then shuts down. Fan continues to run but won't stay lit....any ideas?
  • sundeen_fort May 31, 2009
    15x30 54" above ground....14,000 gal approx
  • 640 Answers
It could be that your gas connection has a blockage that is preventing adequate fuel for from getting to the heater. If that is not the case, try consulting your owners manual for these pool heaters. There is an online copy at the link below.
http://www.backyardcitypools.com/images/Hayward/H100-Manual.pdf
Posted on Dec 07, 2010
I called 1-908-355-7995 and a tech had me check voltage at red and white wires on control module, it will be at 120v when unit fires, if voltage drops after initial start up it is the air pressure switch, or hose to air pressure switch, my problem was the hose had a pinhole in it,I cut off the bad part, reinstalled hose, and it runs fine. Good luck.
Posted on Jun 08, 2009
    President:
  • 1,902 Answers
What size pool are you heating?
Posted on May 30, 2009
  • Jeremy Reddick
    Jeremy Reddick May 31, 2009
    How many gallons per minute does this pool heater do? Do you have the model and serial number? This almost sounds like a deffective unit
I have a Hayward H400 that shuts off at 88 degrees. What could this be?
Is this heater standalone, or is it hooked up to an external controller? If it is standalone, it sounds like you need a water temp sensor for the heater. If its hooked up to an external controller, you likely need a 10k temp sensor. What error code does the heater display when it shuts down? And what temperature are you able to read on the heater and/or external controller?
Aug 25, 2014 | Hayward H Series Pool & Spa Heater 400k...
Hayward H400FDN will not stay lit - Brand New install - NO Fault codes.
make sure wiring is correct especially if wired 120 volt read instructions inside panel
Jan 28, 2014 | Hayward Industrial Products H400FDN...
HAYWARD POOL HEATER FIRES FOR 5 MIN. THEN GOES OUT
Sounds like it is cycling on high limit; causes are related to water flow through the heat exchanger or a faulty high limit(doubtful given the heater cycles back on). Check the internal bypass for obstructions; has anyone worked on it recently? There are usually two high limit switches with different trip temperatures; installing the wrong one could also be the culprit. Does the heater "bang" before it goes off (a sign that the water is boiling inside the tube bundle)?
Jun 27, 2009 | Hayward H Series Induced Draft Abg 100,000...
Hayward heater not staying lit
possibly poor pilot adjustment or insuficient mv output from thermopile
Jun 19, 2009 | Hayward H Series Millivolt 250,000 Btu...
Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
I'm trying to start-up a Hayward H400 natural gas heater for my pool. It was brand new last season and worked perfectly. It keeps firing up for a little while (maybe 10 seconds on average) and then shuts...
if means ignition failure check that gas is on, check for fauilty igniter wiring or connections, inspect gas valve wiring measure voltage across gas valve during trial to ignition if 24 volt replace gas valve if no 24 volt replace control module
May 19, 2009 | Hayward H-series Electronic Gas Pool...
Hayward H Series Induced Draft Abg 100,000 Heater Logo
325 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
