Question about Kenmore Washing Machines
Front loading machine abnormal strong vibration on the spin cycle
Kenmore Elite front loading machine vibrates and shakes on the high spin cycle. This happened just few months ago. Never had a problem before. Technician said that outer tub with bearing is good but left without finding a problem but confirmed that the vibration is abnormal. What could be a problem?
  • 15,935 Answers
Check the tub rollers or wear plates.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
HE Kenmore washer vibrates quite strongly on high spin, which is the Normal default for the machine. I have had it adjusted for levelling, then had to have a new machine delivered when the vibration...
most of the kenmore front loaders is that way,, if it is on a pedestal or on the second floor it makes them worse,, lg samgung electrolux all shake to a extent but kenmore is the worst
Jan 23, 2011 | Kenmore Washing Machines
Kenmore Elite Model 44836
Check that the feet are level to the floor as this may cause the vibration. Also set the machine to wool mode this then knows what material you are putting in the machine then should cycle to that material.
Thanks J
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Washing machine shakes excessivley and the washing cycles are stopping mid use.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Jan 06, 2011 | Kenmore Elite 45986 Front Load Washer
The washer shakes to much and make to much noise
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Jul 21, 2010 | Kenmore Elite 45986 Front Load Washer
An extreme vibration in spin cycle. It makes the
Because front load washers are VERY HEAVY, they shake if you have a wooden floor. If your front loader sits on concrete and it still shakes, then you have to make sure all is balanced. If it still shakes, then inside the system there are shock absorbers that need to be checked.
Nov 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Washer drum shakes excessively during fast spin
y shaped piece that contains the spindle that attatches to the basket and allows it to spin is corroded and cracking. you can't buy just the spindle bracket, you must buy the basket too. you'll be buying the front part of the drum too, if you wait to long.
Feb 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Tub spins out of round
When that happens it is usually because of a drum bearing problem, have it replaced before this damages more parts.
Dec 31, 2008 | Kenmore Elite 45986 Front Load Washer
Abnormal shaking during spin cycle
THIS IS CALLED A BEARING JOB THE INNER TUB AND THE OUTER TUB HAS TO BE REPLACED THESE PART ARE USALLY UNDER THE MAN. WARRANT BUT THE LABOR IS PRETTY EXPENSIVE ON THIS JOB BECAUSE THE WHOLE WAHER HAS TO BE TAKEN APART
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite shaking during spin cycle
Moved a Kenmore Elite and when we put it back in place it vibrates loudly. We tried leveling it and that has not worked. Any ideas?
Sep 27, 2008 | Kenmore 24032\24036 Top Load Washer
Front loader vibrates and moves
You shd check the front legs - they shd be a maximum screwed up, that is the machine shd be tilting forwards. Then you adjust acccording to your floor level. The machine should not shake a bit when off, & you try to shake it with both your hands.
A little vibration is normal when the spin starts. Don't forget to rate me nice............
May 24, 2008 | Kenmore 46462 Front Load Washer
Washing Machines Logo
301 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
