Question about Whirlpool LER5636P Electric Dryer
Whirlpool dryer tested all heating elements show to be good cleaned lint trap but still want heat but runs fine. model -ler7648kqo
  • susieq44 Nov 15, 2007
    Whirlpool dryer LER7648KQO. Wont heat up. Brought new heating element....still not heat.Everything esle works properly. Any suggestions on what to try??
  • 248 Answers
    You need to check for 220 volts at outlet.  It's possible to have only 1 110 volt circuit.  May be a bad breaker. or outlet.  If you have 220 volts at outlet,  you need to have an ohm meter to check continuity of the thermal fuses and the heater.   Access by removing rear panel.  UNPLUG FIRST!!!!!
Posted on Oct 23, 2007
Power indicator lights up but there is no power
Remove exhaust hose. Clean out lint. Remove back of dryer. Clean lint out of air flow system including lint and heat unit(coils). Try dryer. Is heat element glowing red hot? If not, replace heat element. They burn out intermittently and need lots of air flow to have good life. Clogged lint traps shorten life cycles. Definitely a DIY project. See youtube for general process.
Jan 09, 2014 | Whirlpool Dryers
Clothes not getting dry
sounds like perhaps you are losing your heating element...could be electronic, but it's most likely the actual element needs to be replaced...
Apr 25, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryer will not heat up
A clothes dryer can go for years without any problems. We come to rely on our clothes dryer, and we can even begin to take it for granted. Then one day we attempt to use our clothes dryer and it has no heat to it. Now we have entered the world of clothes dryer repair, and it is a world that can get expensive. Before you call out the repairman, try some troubleshooting tips to see if you can get the heat flowing back to your dryer again.
    Lint One of the easiest fixes for a dryer that will not heat up is cleaning out the lint trap and cleaning out the lint from the dryer exhaust. The lint trap should be cleaned out before each usage. Not only does cleaning the lint trap prevent the possibility of a fire, but a lint trap that is filled beyond capacity will cause the dryer to not heat up. If the lint trap is clean, then inspect the exhaust hose and vent next. If the exhaust hose and vent are cluttered up with lint, then the dryer will not generate heat. You can use your hand to clean out the vent, and broom handle to clean out the vent duct in your house. The flexible hose can be detached and cleaned by hand as well. Thermal Fuse A dryer will run on for a very long time, and when the thermal fuse gives up then there will be no more heat. Finding and replacing the thermal fuse is not difficult, but in order to do it you will need the manual for your dryer. Each dryer model is different as far as how to open up the cabinet, and locate the thermal fuse. You may need to purchase the thermal fuse online from the manufacturer, or you may be able to get a universal fuse that fits your dryer from an appliance repair store. Contact the manufacturer of your dryer to see what kind of thermal fuse they recommend. Thermal fuses cannot be repaired, they must be replaced. In most cases it is easy to tell if your thermal fuse needs replacing as you will see the center of it is burned out. Heating Element Another main culprit to a dryer not heating up is the heating element. According to Repair Clinic.com, the heating element is a coil found in the back of the dryer that the dryer uses to create heat. The only way to tell if a heating element is bad is to check the consistency of the current it generates with an ohm meter. If you are unfamiliar with how to do this, you can either replace the heating element and assume it is faulty, or you can have a repair professional test your heating element for you.please comment on these solution by say how helpful.by rate or vote
Jan 10, 2011 | Dryers
Kenmore electric dryer, no heat model #417.83142201
You can check if you have a feed to the element with a voltmeter or a light bulb test lamp while the m/c is running if you have power its the heater element.
if not ,temporary short out the thermostat and run the m/c if this brings on the power its the thermostat.
You have well covered all the other possibilities so the best of luck
Mar 18, 2010 | Dryers
Dryer runs but no heat in it LGR4634PQ0
Check the simple things first - is the lint screen/trap clean? Is the exhaust hose free of obstructions? Can you feel air blowing out of the dryer exhaust when it is running?
If you answer yes to all of the above, you need to check the heating element. I would download a schematic from the Whirlpool website so you can check for continuity of the element and to see if you are getting power to the element. You will need to remove some covers from the dryer to make these tests.
Jan 11, 2010 | Whirlpool Dryers
The dryer runs fine, but there is no heat. I
You will find the heating elements on the driers are very robust. Normally what happens is there is either a build up of lint which has possibly blocked the air inlet grid,.or possibly being to close to the wall. This in turn restricts cooling airflow .There is a thermal protection thermostat which will activate and open circuit if temperature is exceeded at any time.Need to locate the thermostat and if lucky, you could simply press a button and it will reset. If not, you may need to replace that defective one. Typically the thermostat is at the back and close to the element.
Sep 28, 2009 | Whirlpool LER5636P Electric Dryer
WHIRLPOoL GEW9200LW1 RUNS BUT ONLY BLOWS COLD ON ANY SETTING.
if no heat , but all else is fine, means heating element needs replacing, most likely accesed from back panel of machine, about 25$ part
Aug 22, 2009 | Whirlpool GEW9250 Electric Dryer
My Whirlpool heats up, everything is clean. Clothes will NOT dry! Excessive moisture present when I open the dryer door after running for 120 minutes. Had this problem before and the ductwork was clog
Are you sure the fan is working . Also the heating element could be shorted to the heat element cover. Take an ohm meter and check from the heating element to the cover if you get ohms it is shorted if the meter don't move it is ok. If it is shorted you get half the heat not hot enough but still feels warm. Hope this helps good luck..
Mar 30, 2017 | Whirlpool 6.5 Cu. Ft. Super Capacity Gas...
Whirlpool Electric Dryer Model GEQ9800PW1 - No Heat
Well your high limit is blown. It mounts up top of the heat element chamber.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 31, 2009 | Kenmore 62602 Electric Dryer
Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Jun 28, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
181 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
