Question about Whirlpool Washing Machines
Whirlpool front loader door lock problem
I have a Whirlpool Duet Washer model=wfw9200sqa10. It's 15 months old. The washer doesn't "know" the door is closed. It doesn't seem to be the switch because if I hold it in (door open) the washer will start. If I press against the door with even pressure top, bottom, and latch side, presto wash will start. Is there a hinge adjustment or anything else that I can do on my own to help this problem?
    Problem Solver:
  • 6 Answers
Don't know if it is adjustable, but you may want to replace the switch anyway. I may be going bad or have a corroded/pitted/or dirty contact. I have had success with finding replacement parts at www.repairclinic.com. Hope this helps.
Posted on May 30, 2009
Control locked is lit up and not allowing me to start another load of laundry. What do I do?
Please avoid answering questions of which you know NOTHING.
This advice is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Frigidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your specific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
(tip courtesy JS Rock)
Thanks for using FixYa
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Duet front loader Washer approximately 6 years old. The control lock is on and I can't start the washer. How do I resolve this problem.
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer GHW9300PW4 .... The control lock is on .. I did get door to open, It will not shut off and none of the cycles will light up or start.. Please help..
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Unresponsive control panel- Whirlpool duet dryer 4 years old
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&^^^
Nov 03, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
My whirlpool duet 2004 front load washers door is locked, time is flashing and pump is on. Unable to stop or open door. tried to unplug. Control lock is not on. My wife tried to add clothes when the add a...
Sep 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet front loader washer Model WFW8300SW01 Whirlpool. The washer is not working it locks the door when you press start. We have replaced the door latch and the main control board. At one time it had a F28...
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
This should tell you all you want to know.
Sep 02, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Door lock error whirlpool duet front loader
DO NOT BYPASS A SWITCH UR HOUSE WILL BE FLOODED INS WILL NOT COVER IT. YOU NEED A DOOR LATCH, AN MMC AN PROB A BELLOWS CAUSE YOU WILL RUIN IT PUTTING THE SPRING CLAMP BACK ON. DO URSELF A FAVOR AN CALL A SERVICE TECH
May 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader duet sport washer door will not open
without complete f code hard to pin cause but suspect pump not pumping out remove bottom cover reach up to lock area pull small tab down to unlock door remove as much water as possible remove pump clean out by turning counterclockwise clean pump and connecting hoses reassemble and ck
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer fills with water by itself
sounds like a faulty water inlet valve, not seating properly after closing the valve.replacing the valve is the only solution to this problem, in the meantime you can turn off your water supply in between doing loads.
not a bad habit to get into!!!!
Mar 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
219 people viewed this question
Dan Webster
Dan Webster
Sal De
