Question about Mtd 22" Yard Machine Push Mower
Networked Canon imageRunner 2800 printer stopped printing right
I have a Canon imageRunner 2800 connected via ethernet to a modem and switch. My computer running Windows XP Pro is also connected to the switch via ethernet cable. After replacing a faulty modem the other day, the printer stopped working. I've tried reconfiguring the port, adding a new port, downloading a new driver, and I've finally got it to print out something, but it's gibberish on multiple pages. The advanced settings show the printer isn't communicating with the computer. I've also lost the scan function on the imageRunner. If you can help with this one, I'd be greatly appreciative.
  • Frank
    Frank May 11, 2010
    canon don't make lawmower.what are we talking about???canon printer of lawnmower????
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 89 Answers
Your modem was almost certainly your router and contained a static IP address for your copier. Check what IP address your copier used to use. In the Printer Properties/Preferences can't remember which there should be a TCP/IP port. What is the IP address for this?
Go into the copier, go to Additional Functions > System Settings > Network Settings > TCP/IP settings > IP address. Turn DHCP off (make sure DHCP box is filled with white). Enter IP address. Press Ok/Enter (if there is a button that says so, can't remember at the moment)
Turn copier off using main power switch on right hand side of copier then back on again.
Does it work? If yes, good.
No, check the IP address of your new modem/router e.g. 192.168.0.1. Is the IP address of the copier in the same range, that is are the first three out of four numbers the same (last number must be different)? If not, change the copier's IP address so that the first three numbers are the same. Make sure the copier uses the same Subnet Mask as the router/modem e.g. 255.255.255.0. For the subnet mask all four numbers must be the same.
Posted on Jul 24, 2009
Can I connect canoscan 4400f using ethernet cable
i believe is not possible to connect to a router. printers ar designed to be connected to computers via ethernet cables and bluetooth when both devices are bluetooth enabled.(must have a wifi bluetooth ethernet card installed or usb bluetooth installed via usb). is you want to have the printer to be used bye more than one computer at home or office. you must set up each computer to the printer as well.. in control panel look for printers.then set up the conections.if computer 1 is printing a document. computer 2 will have to wait. when done. then will print work for computer 2.
Dec 18, 2012 | Canon CanoScan 4400f MultiFunction Color...
Unable to scan document
try to add your printer so that you can scan, just click start of your computer then go to all program the add printer or scansoft then restart your pc to take effect
Jun 30, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Can't print or scan through USB port on Canon imageRUNNER 5070.
The port should be active. You can look for problems by right-clicking My Computer and then Properties. Under the Hardware tab, press the Device Manager button. Any hardware issues will show either a question mark or exclamation mark, disabled items with a red x. After the printer is connected, turn it on, then go to Start -> Control Panel. Here, go to add hardware. See if this finds it.
If not, have you added the printer after connecting it via USB under Start -> Printers and Faxes? What about inserting the installation CD before connecting the printer?
Apr 20, 2009 | Canon imageRUNNER 5000 Copier
When connected to Airport Express via USB, it will
Airport Express provides only a print server, not a networked usb hub so it can only print. I'm afraid you'll have to go back to wired for scanning.
Mar 06, 2009 | Canon PIXMA MP610 InkJet Printer
Transferring stored information to p.c.
If you do not have send function, you need scangear software.
From canon download site you can find software and manual.
Feb 13, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Canon Image Runner 2200 printer port appears to be disabled, How to you enable it from the printer console manager
You don't.
Go to Start|Printers| and then right click select your printer. Make sure there is an arrow next to the printer, and if not, select "Make Default Printer" in the properties drop down box.
Jan 22, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Networking imagerunner 2200
First, plug the printer into the network with an Ethernet cable. Then, go into the configuration page on the printer's display and print a configuration page. Look for the IP address. When you have that, go to the computers that need to connect to the printer. (Note that this tutorial is for Windows XP, I am not familiar with Vista but this should give you a basic overview.) Go to Start > Printers and Faxes. Click add a printer on the left hand side of the window. Select a Local printer attached to this computer, and unselect automatically detect. On the next page, click create a new port > TCP/IP port. Type in the IP address of the printer. Then choose the driver you are going to use, you should be able to find the IR 2200 driver under canon pretty easily. If not, go to canon.com and download their drivers. Once you do this, print a test page and it should print. You are then fully configured.
Please rate, Thanks!
Jan 21, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Help I can't get a Word doc to print on 11x17 on my canon Image runner 2200
guessing its the wrong print driver go to imagerunner ,com and look for different driver
Oct 29, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Problem printing PDF document
In Print settings if using PCL select Print as Image. Also Spool Printing. Use PCL5e or PS drivers.
Oct 23, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Drivers of canon imagerunner 400.
http://www.usa.canon.com/html/download/imagerunner330_400.html Check this list of drivers for Canon Imagerunner 330/400.
Jul 27, 2007 | Canon imageRUNNER 400 Printer
Mtd 22" Yard Machine Push Mower Logo
160 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
