Question about Fuji FinePix S2 Pro Digital Camera
My Fuji Finepix S2pro wont turn on
Two weeks ago the camera was working perfect. I don't use it too often. I charged the batteries and when I tried to turn it on the other day I get nothing at all. Any ideas what could be wrong?
    Problem Solver:
  • 11 Answers
Try getting new batteries.. sometimes the rechargable ones just lose the charge.. instead of rechargables try using throw aways. you can try and contact fuji but like myself and others they will just give you 5 differant numbers to call and the problem will not be solved
Posted on May 30, 2009
Fujifilm finepix s9500 won't turn on with new batteries works in picture viewer with power adaptor but as soon as I turn switch fully on to take picture the camera just turns off
Hello my FinePix S9500 will not power up, i have - Fixya
www.fixya.com/support/t4079670-finepix_s9500_will_not_power_up
Feb 8, 2010 - Question about Fuji FinePix S9500 Zoom Digital Camera ... Mine willswitch to 'picture view' but when I turn the switch to 'camera' it all just ...
Fugi 9000s camara fix( won't turn on) - YouTube
? 1:17
https://www.youtube.com/watch?v=Hb8jiWFfXQs
Jul 1, 2013 - Uploaded by wakohelliott
Fugi 9000s camara fix( won't turn on) .... FUJIFILM FINEPIXXP50 - Head's UP - My New Camera - Full HD - Water, Shock, Freeze, Dust Proof ...
fujifilm finepix s9500 wont turn on ' Fuji X Forum
www.fujix-forum.com/.../fujifilm-finepix-s9500-wont-turn-on.49929/
1 day ago - Hi I am new on this forum and new to bridge/DSLR cameras I have been given a fujifilm finepix s9500 and it will not power on I have tried ...
Jan 01, 2016 | FUJIFILM Cameras
I have a Fuji finepix j38 that is appox. 8 months old. When I turn the camera on, the lens comes out, immediately retracts, and "zoom error" comes up on the LCD. I can view pictures, but can't take any. ...
I thimk your problem is that you have sand betwin the lens mechanism and that cause the immediately retract.you can try to apply air pressure near the lens but with care
Oct 05, 2010 | Fuji Cameras
My nikon s2pro doesn't turn on. the batteries are full it just doesn't want to turn on. any tips
Make sure the flash batteries are good. I put new ones in and it started to work.
Apr 15, 2010 | Fuji FinePix S2 Pro Digital Camera
I have puchased 256 mb card, used. Will I be able
Yes, you should be able to use the 256mb CF card. The Fuji S2 Pro will accept CF cards up to 2gb.
Jan 09, 2010 | Fuji FinePix S2 Pro Digital Camera
Hello, I purchased a finepix s5700 about 18 months ago. It has worked perfectly until the last few weeks. I can turn the camera on if I hold the playback button and switch on the power, and can scroll...
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, it may be time for new batteries, or the camera may have a problem that requires professional repair.
Dec 29, 2009 | Fuji FinePix S5700 Digital Camera
Camera Won't Charge
my finepixz3 got wet. but after a few days it worked! but when the battery ran out it wont charge. is it the battery? it turned on a few sec when its in the cradle but it wont last after a few seconds it would turned off. is it the battery or the camera itself?
Sep 01, 2008 | Fuji FinePix Z3 Digital Camera
Fuji Finepix S2 Pro
Ensure the batteries are the correct kind and chemical makeup (yes it does make a difference!)
try using lithium or alkaline as oppose to standard =]
Otherwise there may be an issue with the camera itself, check for warranty? if it isnt under warranty, document the error message/number, consult the manual AND the support site for the manufacturer.
good luck! =]
Jun 13, 2008 | Fuji FinePix S2 Pro Digital Camera
Fuji 4800 camera
can anyone help or give a clue as to what this problem may be?
Mar 05, 2008 | Fuji FinePix 4800 Zoom Digital Camera
Black screen
This is a CCD sensor ( see pic below from Canon camera with same pixalage and specs ) problem : outputting too much noise or nothing at all so the sensor must be replaced ( not a big job but ha sto be done by someone with experience and the right parts ). Fuji will repair free of charge , if I am not mistaken, so you need to contact your Fuji agent .b16210b.jpg
Nov 25, 2007 | Fuji FinePix Z1 Digital Camera
Camera will not turn on.
Check the manual for indications of error. Look for a reset to factory settings option. Switch off and remove batteries Take the memory card out and carefully cleane the contacts, now wrap a piece of paper atround the card in such a way that you have a frip on the paper an insert it and work it up and down thus polishing the chamber contacts. No joy? Contact Fuji Technical help team.
Jun 11, 2007 | Fuji FinePix A350 Digital Camera
Fuji FinePix S2 Pro Digital Camera Logo
244 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
