Question about Rheem 30 Gallon FVR Propane Water Heater 6YR 22V3030FP
Burner & pilot went out, will not go without having a gap in the burner access door
I have an 80 gal gas Rheem water heater. burner and pilot went out, will not go without having a gap in the burner access door.Please help, need a shower
    President:
  • 1,902 Answers
Replace the pilot generator and everything will work again. It is a problem with it sensing the flame from the pilot and when the generator stops working it tends to knock everything out
Posted on May 30, 2009
Main burner comes on and one second later both main burner and pilot go off. Is this a lack of air - if so what do I do? A 2yr old 40 gal gas heater. garybyer@aol.com
What water heater do you have??
What Brand and model number, and what type of gas control valve?
You might have air in the gas line.
Copy following link to help troubleshoot by gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Aug 22, 2012 | Water Heaters
Water heater goes out
The burner needs to be adjusted
Mar 13, 2017 | Water Heaters
Rheem 22V50F1 pilot won't stay lit. Changed thermo couple & it lit, ran then went out. Let it sit overnight & it lit, ran then went out. What next? p.s. The unit is 5 years old. Thanks
If pilot lights and flame is robust and clear blue, and pilot goes out later, then some suspects can be excluded: air in gas line, low gas pressure, thermocouple is overtightened (finger-tight + 1/4 turn), thermocouple not positioned correctly in the flame, dirty pilot tube.
If flame is yellowish and small: then clean pilot tube and combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Remaining suspects can include: air in gas line, low gas pressure, bad gas control valve, tight house so household vent fans pull air down water heater vent that blows out pilot, hot attic with inadequate ventilation, water dripping down vent.
Open following links to read troubleshoot resources.
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 16, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a 5v40 hot water heater. I lite the pilot and burner work fine as long as i have the door open to get air. close the door and the pilot lite and burner goes out. starved for air. there looks like...
Probably don't have good news for do-it-yourself repair.
Richmond is Rheem.
Rheem gas water heater manuals say to call service technician if the combustion chamber FV sensor has tripped, or if water heater has flooded.
FV trip requires part replacement, and flooded heater has to be replaced.
I read one thread that might help:
http://www.diychatroom.com/f7/rheem-hot-water-heater-pilot-burner-not-staying-lit-65755/
I posted same question on pro water heater forums, and the plumbers will not man up and tell how to replace the part. They cite legal issue because gas water heater is dangerous, period.
They have a point, but I am still looking for a good DIY answer.
If repairs are more than $330, then buy a new heater at local box store and install yourself same day.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 17, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
It just stopped working last night. Gas kitchen stove works fine. Are there pilet lights on these things?
if its gas, it has a pilot light. the most likely thing is the thermal coupling is bad. if it is bad, burner flame will not turn on. it senses the tempurature to send gas to light burner.
Aug 06, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Have 2 Rheem 50 gal NG water heaters in tandem. Neither pilot will stay lit. They are 17 years old and never had this problem before
the most common problem is the thermocouple being busted. If thats not the case then the gas valve may be busted but that isn't very common.
Eitherway this required the burner being taken out so I wouldn't recommend anyone to do this who isn't a proffessional.
Jun 23, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
New gas water heater pilot light will not ignite
Hi .. if this is a brand new heater, then you probably need to have the gas line bled. This means getting all the air out of the gas line feeding the burner. This can be done by constantly trying to light the burner or poilot . or it can be bled down by a HVAC tech.
Apr 09, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
How do I light my Rheem water heater if my peizo ignitor switch isn't working
Remove the burner access cover under the control valve. Press the pilot light button (gas control) and hold it down. At the same time, light the pilot. Continue to hold the lighting button for a few seconds until the thermocouple heats up. Release the button. Twist the gas control knob to the ON position, and the burner should fire up after a few seconds. Replace the access cover. Good luck.
Feb 09, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
No Hot Water in morning
Remove the cover then the access cover, then you can see inside,
the pilot light is probably out.
If out turn the gas off, then get a long match, grill lighter,or piece of paper ready to light, you should be able to see the little thin
gas line that runs inside the tank and see where it connects to,that is where you need to light, now that you see where to light, turn gas knob to pilot, and press down and at the same time light the pilot.
( blow into the pilot area before putting match inside to make sure no gas has built up inside) Hold down the knob for a minute then release, if pilot goes out try again and hold down longer, if you hold it for 3mins and it does not stay lite, the thermocouple is bad and you will have to replace it.
Apr 14, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem 30 Gallon FVR Propane Water Heater 6YR 22V3030FP Logo
136 people viewed this question
Top Rheem Pool & Spa Experts
Steve Slater
Scott Corey-reid
David Spradling
David Spradling
Are you a Rheem Pool and Spa Expert? Answer questions, earn points and help others
