Question about Motorola Mobility RAZR V3
Phone can't charged & always being low battery & don't be switch on
My phone is now switch off and i can't charge it when i put it on charging it can't charged & what can i do for charing my phone
  • maniyar_nira May 30, 2009
    I CHECK PLUG POINT & TRY WITH USB BUT IT CAN'T CHARGED
    President:
  • 1,952 Answers
Check plug point and change the batteries then try to usb cable
Posted on May 30, 2009
My blackberry curve 8520 is at low battery and wont charge or show the charge lightning bolt
King, many times this happen, don't worry, put your device on charge 2 to 5hours it will solved, if problem persist, change battery, because this sounds me a only battery problem. there is one another way (if you are not sure don't try this) we call that direct charging
first take one charger who has light on head and then cut the charging connector of charger and then you will see two colours of wires separate the black and red wires (red wire is positive line and black is negative line) and then connect to current supply but make sure there wire are separated otherwise it will have a short circuit and then take battery and search + and - connector and then red wire connect on battery positive connector and black on negative connector if you connect properly you will see the charging light are getting dim. that mean it is charging, do direct charge for 10 min and then switch on your device with battery and put in charge normally. this will solve your problem. if my sugetion was helpful please rate it.
Jul 02, 2012 | RIM BlackBerry Curve 8520 Smartphone
Tip
How to get the most out of your cellphone battery. It is always a hassle...
It is always a hassle when your cellphone battery is flat and you can't charge it right away. So get the most out of your battery. Before you put your phone on charge, switch it off first. that way it does not used any energy when it's on charge. Also you can charge it during the night when you are sleeping. Most cellphones have the ability to let the alarm go off even though the phone is switched off. So your phone is fully charged at the end of the night. And you can enjoy your day without any worries.
on Jul 15, 2010 | Cell Phones
NC10 battery not charging. The charging light flashes as normal but battery wont charge, tried another battery with same result.
Allow 1hour to charge it, if did not charge check the input & output of the charger if its properly insert, if not again off your notebook & charge it, always check if it is charging,
Note: Charging test try on, off, & unuse it allow to full charge the battery before using..avoid low bat your battery when using.
Jun 03, 2011 | Samsung NC10-14GW Notebook
My nokia 2330c-2 is always low on battery even after I have charged it and it most at times hangs and goes off automatically
nokia 2330c calling time battery empty & when restart phone battery full plz provide me this problem's solution ....
Apr 20, 2011 | Nokia Classic 2330 Cell Phone
I have a battery low problem after 1 or 2 hours after charging my n73 battery, i tried to change my battery but the problem is always the same. help me please
just minimise the backlight timing, make off the screensaver, switch on the power saver, don't switch off/on the phone, and most important don't overcharge and put ur phone on charging whenever it shows low battery alarm and remove as soon as possible as the battery is full, your battery will give you more backup.
Jan 29, 2010 | Nokia N73 Cellular Phone
Nokia 6300 Switching off
Purchasing a new phone is easy and everyone is always in a hurry to use new phone but never go through the manual properly. You did the same you didn't put the battery on charge for 24 hours. Now to check your phone take another charged battery for nokia put it inside your phone and start it. It will deffinetly work. In order to revive your dead battery keep your battery on charge while the phone is switched off for minimum 24 hours. If it gets revived its ok or else purchase a new one.
Jul 25, 2009 | Nokia 6300 Cellular Phone
Battery does'nt charge, won't hold charge,& time,military,when bat. low fromstand
i took phone back,& exchanged for another, but need my time put on new phone,&would like to use my phone #, from cellular south. 228-861-1114,& need to complete instalation of new phone.
May 12, 2009 | Motorola Mobility i425e Pay-As-You-Go Cell...
Low battery won't charge,change battery,now dead won't charge????
I had the same problem so I got a new battery & separate charger to charge both new & old, then replace as required.
Nov 05, 2017 | Uniden Cordless Phone exai398i
Method of charging a 2004 Mercedes E320 battery
It is always safer to charge the battery out of circuit, Removal of one cable will insure you can safely charge without hurting electronics on board. Generally if your battery is already sufficiently charged it acts like a capacitor in the circuit and will prevent damage, but many battery chargers do not always put out a pure dc voltage and this can damage electonics.
Dec 14, 2008 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Motorola Mobility RAZR V3 Logo
87 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
