Question about Refrigerators
Is there a reset button?
Freezer frosting up, refrigerator up to 50 degrees. When I was removing food from the freezer, it cut off and now it won't run at all. The lights are working, so power is on. Is there a reset button on this model, or has the compressor finally blown? I thought perhaps a a failed defrost switch was causing the problem, but now, no fan, nothing.
  • 3 more comments
  • tootalltotan May 30, 2009
    KitchenAid KBRS22KG (1998)
    It has started running again, but I haven't had time to see if the temp is dropping at all. It doens't feel all that cold. I kind of guessed that the defrost thing was the culprit - and I guess that caused the refrigertor to get warm, too. Is it just one part or multiple parts? Do I need a repairman to do it, or is it something I dare tackle myself (56 year old woman, here).
    KBRS22KGAL00 - I have just printed the parts manual from the KitchenAid website. I have it here in front of me.
    http://shared.whirlpoolcorp.com/assets/p...
    What parts am I supposed to be looking at?
    Thank you!
    Thank you, thank you!
    President:
  • 1,136 Answers
Hi, there is no reset button. How long has it been off? If there is frost nuilt up in the freezer, the defrost cycle has gane bad. There are three parts in the defrost cycle.
If you could get me a model #, I can look this unit up and assist you further.
Vic
Posted on May 30, 2009
  • 1 more comment
  • Victor
    Victor May 30, 2009
    No, You can probably fix this. It will take a voltage meter to test the defrost parts ansd there are three parts to test.
    If you will get me the model # from the label in the fresh food section, I can assist you.
    Vic
  • Victor
    Victor May 30, 2009
    The defrost bi-metal and cefrost heater. Both of these are located in the freezer section behind the rear panel.
    The bi-metal is the most common part to go bad. You can test it for continuity to see if it is open (has to be tested while cold)
    If that tests ok, then test the defrost heater to see if it is open. If both of these test ok, then you will need to change the defrost timer.
    I hope this helps.
    Vic
  • Victor
    Victor May 30, 2009
    You are very welcome.
    Let me know if I can assist you further.
Yesterday morning I noticed that the unit was buzzing. The refrigerator door had been left open and the temperature inside was 70 degrees. The freezer temperature was 20 degrees. This morning, 24 hours...
Hi
You have condesation built up in your freezer whereby the evaporator fan or the vents are most likely blocked off.
Turn fridge off. Empty freezer and either put a pot of boiling water inside freezer or with the aid of a hair dryer try to defrost the freezer. If you are able to remove the back panel on the freezer that would be ideal as you can directly target the frost.
Good luck
Ash
Sep 06, 2011 | Refrigerators
Fridge won't cool below 60, freezer won't go above 20
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Refrigerators
Frost Buildup in Frost Free unit.
You will have to check the defrost timer to make sure it is turning if it is working properly and you are getting power to the defrost heating element below the freezer coil it should get hot if you have a 115volts or so to the element and it does not get hot then you have a bad element
Jun 10, 2010 | Kenmore 57029 Side by Side Refrigerator
Freezer fine, fresh food 55 degrees max cold
Check for frost build up in freezer section. If frosting up you will need to check the heater and bi metal. If it's a ge ref. could be thermister or main board
Feb 25, 2010 | Refrigerators
Freezer went crazy!!! help
I'm sorry but I cannot find an RF26V model could you double check the model? Sea Breeze
Nov 26, 2009 | Samsung Refrigerators
Top portion offreezer is warm bottom is cold
Sounds like the defrost heater is bad . Part number WR51X10055 . You will need to remove the 2 or 4 screws , holding the lower portion of the inside rear freezer panel . The heater , is attached to the bottom of the coils , held on by 2 screws . You should also replace the defrost thermostat , Part number WR50X10068 . This is the 1 " cylinder , clipped to the top of the coils , with a blue and pink wire attached to it . This bimetal (defrost thermostat) , cuts the heater off , when/if the temp behind the panel gets to 140 degrees , therefore , keeping the food from defrosting .
Oct 22, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
Refig set at 34 degrees and it might be about 45 degres inside what could be the problem
How about the freezer? Is it cold (about 0 degrees Farenheit). If so, there's probably ice build-up blocking air flow from the freezer to the fresh food compartment. Even though modern refrigerators are 'frost free,' they're really not. Over a period of time, frost can build up in areas where air flow is restricted (like the door that controls air flow between the freezer and fresh food compartment). Take everything out of the refrigerator and freezer and allow both to defrost completely. To avoid an odor problem, clean out any food residue that may have been masked when it was frozen. Be sure to LEAVE THE DOORS OPEN while you're cleaning and until you're ready to turn the unit back on and put your food back in. Hope this helps.
Jun 11, 2009 | Samsung RS2534 Side by Side Refrigerator
Refrigerator is barley cold, still makes ice, condensation inside of frostless freezer
Hi: The fact that it still makes ice tells me the freezer is a zero degrees. When you said condensation in the freezer did you mean frost? If your defrost heater fails it will cause the frost free freezer to build up frost. The frost will build up and block the vent that supplies the cold air to the fresh food. The defrost heater is behind the metal wall at the back of the freezer, at the very bottom. A glass tube with a metal coil in it. The coil can break and stop the defrosting. Replace that. Use a hair dryer to melt the frost from behind the panel. All of it top to bottom. You need to remove all the frost to free up the airways. I hope this helps, Jeff
Jun 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
FRESH FOOD SIDE OF FRIG NOT COOLING
i would take the back freezer panel off and see what kind of frost pattern your coils have.they may be frosted over and the begining of a defrost problem.
Mar 11, 2009 | GE GSH22KGM Side by Side Refrigerator
Left not transfering cold enough air to right side. doesn't get colder than 50 degrees, why?
Remove back panel of freezer (where you see the frost) and melt the frost with a hair blower. The frost blocked evaporator coils are not allowing air to pass over the cold coils, so no cold air is able to get to the fresh foods section. You will most likely need to replace the defrost heater at the bottom of the evap coils to prevent this from reoccurring in two weeks time.
Nov 04, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Refrigerators Logo
349 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
