Question about Canon PowerShot S2 IS Digital Camera
Wont take pictures says memory card era but i replaced the memory card
My powershot s2 wont take pictures says memory card era I turn on the camera and it says no memory card, when yet there is one. I have plugged in the memory card to my computer and it shows all the pictures so it must be the camera.
  • KEN LaPOINT
    KEN LaPOINT May 11, 2010
    what size is your card? and what's the max size capacity that your manual says can be used in your camera?
  • Canon Master
  • 4,924 Answers
Format the memory card in standard ( FAT)mode into your pc ....and try again ...also try to clean the plug and the card for any dust or so ....if the card is not the original one ...see if the camera specifications includes this card model and size as a compatible one ...there is the posibility that you used the card for something ...and the data on it are not being readed by the camera ...so ...try to format it clean ...
Posted on May 30, 2009
Cannon Powershot S2IS memory card slot will not work
What type and size memory card? The S2 works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Apr 12, 2013 | Canon PowerShot S2 IS Digital Camera
Can I use a 4gb sd hc memory card in a canon powershot s2 1s? the screen says there's a memory card error
The Max. Memory Size of ur camera is : 2048Mb/2GB.........That is reason for which it says that there is a memory card error.
Feb 17, 2011 | Canon PowerShot S2 IS Digital Camera
When I turn on the camera, I am able to take one picture, then the screen & viewfinder goes black, than I need to shut down power & restart again to take a picture, what is wrong??/
Try a different memory card, or check the one you have. I think it is struggling to write to the card which is faulty or needs reformatting.
Feb 02, 2011 | Canon PowerShot S2 IS Digital Camera
I have a 4GB SD HC card that works well in my Powerhot SD750 but gives an error code "Memory Card Error" and "Card Locked!" on my PowerShot S2 IS. Is there a fix for this? Peter
The S2 IS uses SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. While you can use SDHC cards with the SD750, you will have to use SD cards, 2GB and smaller, with the S2 IS.
Oct 21, 2010 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital Camera will not highlight the format option so I can format my new SDHC memory card
The S2 IS is designed to work with SD cards, not SDHC cards. While an SDHC card will fit into the slot, it is electronically incompatible and will not work. You need to stay with SD cards, 2GB and smaller.
Oct 06, 2010 | Canon PowerShot S2 IS Digital Camera
Canon s2IS when I turn the camera on in review mode the LCD screen displays pictures one after another. Cannot stop the picture review except to turn off the camera. In camera mode the menu button and...
Please do the followings.
1. Turn off the camera.
2. Remove the memory card.
3. Remove the batteries.
4. Wait at least 3-5 minutes.
5. Place the memory card and batteries.
6. Turn on the camera in any mode except review mode.
7. Take any ordinary picture.
8. Change the camera mode to review.
9. What happened now. Is everything normal. if not please write a comment to explain the situation.
Jun 03, 2010 | Canon PowerShot S2 IS Digital Camera
My Canon S2 IS works fine except the display will not provide picture viewing capability when I turn the camera on for picture taking. It will display photos from the memory card. The viewer is black for...
Your camera has the know issue of Stuck shutter, whichhappens after some time (weeks or months) thata camera is notused.
Unfortunately the repair of it requires a complete disassembly of the camera, including the lens, fix it, and then put back together everything.
Definitely requires th skills, tools and experience to do it, so it's recommended that a professional camera repair center is performing this type of repair.
If you look for a reliable and low cost repair service for it, you can look in ebay for such repair services.
Example, look for seller ID Great_items_2004 or with the keywords "Shutter black S2".
Best regards,
Jun 24, 2009 | Canon PowerShot S2 IS Digital Camera
Hi there
Make sure the write protect is switched off on the memory card, take the card out and unlock it, it will be at the side of the card like this 59a6de4.jpg .
Good luck and thanks for using Fixya!!
May 22, 2009 | Canon PowerShot S2 IS Digital Camera
Canon powershot s2 IS suddenly does nothing when powered on
There appears to be an issue with the S2 IS after two years.  See the reviews on Canon's website: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=322&modelid=11368#ModelDetailAct
If yours is two years old then you are probably out-of-luck.  It would probably cost more to repair than to simply replace.
You can at least save your photos by removing the memory card and reading the files using a memory card reader on a PC or MAC.
Apr 19, 2009 | Canon PowerShot S2 IS Digital Camera
Canon powershot s2 Is
I just fixed mine. Put your memory card into your computer. Right click on it. Choose format. Reformat the memory card. You WILL lose all pictures stored on it.
Before putting the memory card into your camera, do the following.
Go to MENU and choose RESET ALL.
Choose reset to original settings.
When camera is done doing so, turn camera off.
Reinsert memory card after it is done being formated in your pc.
Then your camera and memory card should work great again. I just did it on my Canon Powershot A620.
Oct 24, 2006 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
96 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
