Question about Dryers
I replaced the thermal fuse and it blow again. I checked the the exhaust tube it seems to be clear. Please help. Thank you ronny
I replaced the thermal fuse and it blow again when I turned the dryer on. Any other recommendations for me to check. Thank you Ronny
  • photograp686 May 30, 2009
    I have checked all wires.
    Do you anything about the thermalstats in the dryer. I understand there are 2. A high limit and a cycling thermalstat.
    President:
  • 1,902 Answers
Make sure all wires are not frayed or broken also make sure that all your grounds are securely fastened to the unit
Posted on May 30, 2009
  • Jeremy Reddick
    Jeremy Reddick May 30, 2009
    Yes, the high limit switches and low limit switches is what we call it in the field. You can check those with a volt meter. I dont believe that it would cause this problem. But you can check them anyways and see what hapens. Just a question have you checked the plug and plug wires to much sure the are good also?
The thermal fuse on my Whirlpool Cabrio keeps blowing. The exhaust vent is clean and clear, what should i check next after replacing the fuse again?
If you keep blowing the thermal fuse there is a air flow restriction some where disconnect the exhaust at dryer turn on you should have a good air flow exiting machine if not check the blower wheel for lint build up if good the it is in the exhaust exiting the house this is a rarity but the thermistor which cycles heat on/off could be bad hope this helps
Mar 31, 2014 | Dryers
Lg dryer is overheating blowing the thermal fuse
you have an airflow problem. Check the vent hose all the way out and the outdoor vent hood.
a simple verification can be performed by disconnecting the vent hose from the dryer and see if this solves the problem.
Mar 03, 2014 | LG DLE5977 Electric Dryer
My dryer keeps blowing the thermal fuse help
Check your lint filter, exhaust duct, and check if duct flapper is opening fully or not. Allow some time between loads and don't stuff too many clothes.
May 12, 2012 | Maytag MDE9700AYW Neptune 174 Electric...
I cannot afford a service tech right now to come to the house. I hope you can help me through this service. I have a kenmore elite clothes dryer model # 110.63012101 Dryer was not making any heat. ...
you're doing the right thing except for changing out the element without reading it out first.when you check the parts make sure the dryer is unpluged and that you pull at least one of the wires off the part you're checking. check the thermostats on the heater box part
279769 which is part 47,also remove the duct that the lint filter slides into and clean it,if you have a long vent line remove it from the back of the dryer and blow it out with a leaf blower and if you have a shop vac put it on blow and blow off the motor and blow all the lint from the back inside of dryer so it blows to the front and vac it up so you don't have to pull the drum if you don't want to.the thermal cutoff pops when it gets to hot in the dryer most likely from a back up in the vent line or the duct,also go outside and make sure the vent is clear,you should be fine
Sep 29, 2010 | Kenmore Dryers
Dryer has no heat
Check the entire exhaust venting sytsem. If lint is inside of the tubing it will cause a restriction shutting the burner off at all times. If the tubing is clear the moister sensor is at fault and needs to be replaced
May 09, 2010 | Dryers
My dryer takes a long time to dry the cloths
Hello Friend, You didn't state in your discription if you dryer was igniting or if heating element was actually coming on or not. But here is a possible solution to your problem. It sounds like your dryer is working properly, and your actual problem is a blockage somewhere in your 4 inch exhaust tubing. Check it and make sure it is not clogged up with excessive lint. Also if your tubing is clear you need to check your connection where it travels thru the wall etc. It would be a good idea to find the actual location where it exits to the ouside and check for good airflow. If you have poor or no airflow this is why your thermal fuse has blown out. Poor venting of dryer causes overheating and therefore blowes the thermal fuse. I Hope I have helped you, Tim. And please don't forget to give me your rating for my help. Thanks.
Jun 29, 2009 | Whirlpool Dryers
The dryer keeps burning up the thermal switches
Hello Friend, Your solution is simple. It sounds like your dryer is working properly, and your actual problem is a blockage somewhere in your 4 inch exhaust tubing. Check it and make sure it is not clogged up with excessive lint. Also if your tubing is clear you need to check your connection where it travels thru the wall etc. It would be a good idea to find the actual location where it exits to the ouside and check for good airflow. If you have poor or no airflow this is why your thermal fuse has blown out. Poor venting of dryer causes overheating and therefore blowes the thermal fuse. I Hope I have helped you, Tim. And please don't forget to give me your rating for my help. Thanks.
Jun 28, 2009 | Dryers
I am trying to fix my Kenmore 90 series electric dryer which is no longer heating. I tested the high limit thermal fuse on the heater coil housing and it was blown, so I replaced both it and the...
Jun 15, 2009 | Dryers
It is a gas dryer and I have had a tech out twice to replace a part to make it heat up and now it is doing the same thime again (not heating up).
Hello Friend, Your problem is very simple to fix. You need a thermal fuse, very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Your solution is simple. It sounds like your dryer is working properly, and your actual problem is a blockage somewhere in your 4 inch exhaust tubing. Check it and make sure it is not clogged up with excessive lint. Also if your tubing is clear you need to check your connection where it travels thru the wall etc. It would be a good idea to find the actual location where it exits to the ouside and check for good airflow. If you have poor or no airflow this is why your thermal fuse has blown out. Poor venting of dryer causes overheating and therefore blowes the thermal fuse. I Hope I have helped you, Tim.
Jun 05, 2009 | Kenmore Dryers
Hotpoint NVL333EY Electric dryer blows thermal fuse
I had the same thing happen, I replaced the thermal cutoff and made sure no lint build up. It lasted a week then blew again. I then replaced it again and got to thinking why it would blow. I then took apart the exaust inside the dryer running fron the drum to the motor and right before the motor was a build up of lint ane particals that was almost like compressed sawdust which was blocking half of the line. I cleaned this out and it seemed to work much better.
Jan 04, 2008 | Hotpoint NVL333EY Electric Dryer
Dryers Logo
65 people viewed this question
Top Dryers Experts
