Question about Hunter 20763 52'' The Stratford II Ceiling Fan
Fan won't turn on, dont know where switch is
I have a hunter ceiling fan in my new house and the fan will not turn on at the wall and there is no chain on the fan so how do I turn the fan on?
  • 192 Answers
I looked up the owners manual for your fan at the following site: http://www.hunterfan.com/search.aspx?search=20763
Click on the pdf file labeled owner's.This manual indicates there should be a pull chain for turning on and off the fan. Maybe the chain has broken off up inside the fan. You can follow the instructions in this manual to take the fan apart and replace the pull chain.
Posted on May 30, 2009
3 Suggested Answers
SOURCE: Hunter Douglas Ceiling Fan Does Not Work
have hunter douglas fan glass globe broke cant find repalcemants i have all the serial no do you no wher i can go to find 91/2 globe
Posted on Aug 20, 2009
  • 4 Answers
SOURCE: Hunter ceiling fan-just installed -possible speed control problem
It's a 3-speed ceiling fan that's for sure. I think the same a fixer1950 already said...
This page about <a href=http://www.ceiling-fan-wizard.com/hunter-ceiling-fans.html>hunter ceiling fans</a> might be interesting...
Posted on Oct 09, 2009
Install a hunter highland remote in a prewired house that has 2 lights on the same main switch
Prewired for ceiling fan (colors, installing, bedroom, lights ...
www.city-data.com > City-Data Forum > General Forums > House
Jan 29, 2009 - 10 posts - ‎3 authors
In my new house, there's 2 switches so I can do them separately. ... is there anything else I can do with that switch since the fan has a remote and I won't be using it much? TIA. .... Those same wires should be in that switch box.
Wiring on ceiling/fan light combo with remote and ... - Bob Vila
www.bobvila.com/.../82070-wiring-on-ceiling-fan-light-combo-with-re...
Oct 3, 2007 - I can have installed the fan/light (a Hampton Bay Veranda) without the ...My house wiring has a green ground and two black and two white wires. ... Fortunately I found a universal/all brand fan speed control wall switch made by Hunter. ... i havethe same problem . so you just did not used your remote?
Jan 19, 2016 | Hunter Dryers
Why my Hunter Ceiling Fan does not work?
Its unlikely that the fan is on a separate feed from the breaker box than the rest of the outlets in your room but you never know. It would not hurt to check all of your breakers. If the fan and its light are controlled by the same wall switch then the wall switch may have went bad. Within the fan there are separate wires for the fan and the light so both of them would not go out at the same time. It makes more sense that the problem is at your wall switch.
Jul 14, 2014 | Hunter 25872 Sojourn II Brushed Chrome...
Hunter fan model 25706 both the lights & fan have stopped working
mcdevito75 here, VeryGood question, very good, here we go, ------ First a re-set for the motor, I really don"t know but if there is it"s on the motor itself, you"d have to un-screw the cover just at the ceiling and let this cover slide down the chain Attached from the ceiling to the fan itself. and check the motor itself for a reset swtch, usually a red bitton. Now!! true, if the fan motor is bad it could affect the lights, here"s how, the wall switch supplies electricity to the fan motor and the pull chain on the motor turns the fan on, from the motor itself to the fan lights another wire also from the fan motor goes to the fan lights, SO!! if the fan motor is no good it won"t allow electricity to go on to the fan lights. Maybe you Fan motor is just stuck, specially if you haven"t used it in a whlie, with the wall swiotch on and fan speed on low try to gently move the fan blades them selves. If not you may have to repalace the fan.
Jul 18, 2010 | Hunter Ceiling Fan Light Switch Control
Hunter ceiling fan
The usual house wiring for a ceiling fan with two wall switches , is white to white, black to black, and red to the other wire, usually blue or black striped with blue. If this fan has a remote , then it usually only requires one power wire, black and the white neutral.
May 03, 2010 | Hunter 27187 Remote Control
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Jul 21, 2009 | Hunter Ceiling Fan Control Switch
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Ceinlg fan
If your house has only a black and white wire, than you need to tie the black, balack and white striped wire to the black of the hous. You than have to use the pull chains on the fan when the switch is on, to turn the fan or the fan light on or off. If youre house had a red wire than that would be tied in with the black and white striped wire and you would have two swithes on the wall to control the fan and light instead of having to use the pull chains.
Sep 27, 2008 | Hunter 23852 Classic Original Ceiling Fan
Quit working
first turn it off, then rotate the fan, half turn and try to turn if on again. if it start running again you have a faulty motor, and need to replace it. or if the problem continue, try replacing the switch in the wall.
Nov 24, 2007 | Hunter 23852 Classic Original Ceiling Fan
Hunter ceiling fan
Have you contacted Hunter? Have you turned off the wireless internet to see if fans work? You may have to try another internet brand or try moving to another part of the house.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 12, 2007 | Oasis Hunter 54' Ceiling Fan
Hunter 20763 52'' The Stratford II Ceiling Fan Logo
624 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
