Motorola Mobility RAZR V3m Cellular Phone Logo
Stephen Delzer Posted on May 30, 2009
Cannot format PNY 4gb microsd card
Cannot format PNY 4gb micro sd card on motorola razor v3m verizon prepaid cell phone
  • Stephen Delzer May 30, 2009
    it says unable to format. I just purchased it from a store and put it in my phone, and was trying to format it.
    i can format it on my computer fine, but when inserted into the phone, is still says unformatted and i am unable to format it.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 25, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1302
Points
I WAS TOLD BY MOTOROLA THAT THE V3M WOULD ONLY TAKE A 1 GB TRANSFLASH MEMORY CARD. I TO HAD A 4 GB MEMORY CARD AND IT WOULD ALWAYS SAY , CAN NOT FORMAT, TRY AGAIN? I BOUGHT THE 4GB AT THE STORE WHERE I GOT MY PHONE. I BOUGHT A 1 GB MEMORY CARD AND IT WORKS FINE NOW. I HAVE NO IDEA WHY THEY SOLD ME A 4 GB IF IT WOULDN'T WORK WITH MY PHONE . HOPE THIS SOLVES YOUR PROBLEM IF YOU HAVEN'T ALREADY .....
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on May 30, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
4153
Points
20
I could help if you provide some more information about the error message or something.
The most common cause is something might have corrupted the video card and its no longer usable
1helpful
Sandisk micro memory chip not working in my lg620g cell phone
The LG620g works with microSD cards. Your 4GB card is actually a microSDHC card. While it fits into the slot, it's electronically incompatible and will not work in this phone. You need to use microSD cards, 2GB and smaller.
1helpful
My PNY 4GB micro sd HC memory card for my cell phone says its write protected and won't let me transfer anything on to it. How do I remove the write protection. I already tried to switch it into an...
The problem might be that the card is password protected, i recommend you switch it to the unlocked position and then use a computer to format the memory card and do a full format not the quick format.
hope this helped.
Motorola SLVR won't format my memory card.
I am not sure this will work, just a suggestion
Try inserting the micro sd card in the larger sd adapter that will allow you to put it into your computer reader. Try formatting it there instead
2helpful
What is max size Memory Card for RAZR V3m?
MOTORAZR V3m microSD
Up to 1 GB MOTORAZR V3m (Sprint) microSD
Up to 2 GB
1helpful
V3x with 4 gb micro sd
yes that accept the 4 gb sd card .
kingston has the 4gb microsd high speed class4 memory card for motorola razr v3x .
rest you can check the price also for the 4gb card from :
http://www.cellxpo.com/SbBrand-Motorola-RAZR_V3x-Memory_Cards-SDC4GB2ADP_RAZR_V3x.asp
My computer nor samsung alias wont read my 4gb pny microsd chard
I doubt that your phone accepts the 4GB version of the micro sd card, try the 2GB
1helpful
Can't synchronize my motorola v3m with the PC
The only way to sync is if you have the sd card in,and you can only sync the sd card, if you did not have verizon,you could use motorola phone tools and sync everything, but verizon turned off transfer
in your phone because there thieves, but if you learn how to hack a razor you can use moto phone tools.
3answers
Micro sd card
yes 4GB is the maximun motorola specifiy using on the v3xx
Large sd micro cards than originally intended?
soda monster, first of all wuz up man? the answer is yes, i had a razor v3i pretty much same thing to urs, and i installed a 2gb micro sd and it worked, and later i replaced it with a 4 gb card and it worked too. but sometimes when u have to many songs and pictures the phone will become slow and at times freezes ur phone too much, u will have to remove the battery and turn it back on, thats the only bad part , so a 2gb micro sd is recommended.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
