Question about Kenwood KDC-MP628 CD Player
Face plate wont turn on
At one point the cd player ejectedt a cd that was in the player without the face being on at times when i put the face on the player sounds like it trying to read a cd but my amp is not turning on and the face plate is not on but the security light is blinking
    Sergeant:
  • 233 Answers
On the faceplate back, there should be some metal contacts. Take a white (not pink, red, purple, etc) pencil eraser and clean the contacts on the faceplate back. You can take a little rubbing alcohol and a q-tip to the contacts on the player itself...just use a little bit. Let it dry for about 5 minutes and try again. If it has a reset button, you may try pushing it, however that will most likely reset the clock, radio stations, and any eq settings.
Posted on May 30, 2009
Faceplate wont work
the new face plate needs to be coded to the deck. with the face on you need to press and hold presets #1 and #3 at the same time. keep on holding and press reset continue to hold #1 and #3 until the unit is in all lighting mode. press AM button one time. p-rom ok will display. press and hold #6 and reset at the same time. continue to hold until display comes on.
Jul 18, 2010 | Kenwood eXcelon KDC-X879 CD Player
JVC KD -S680 needs help
maybe short circuit or similiar problem inside since its geting hot, probably not a problem with the faceplate I would remove the cd player from your car and take it to a professional for a diagnosis / repair estimate. Can't solve this one with text only.
Jun 18, 2008 | JVC KD-S680 CD Player
My 9855 alpine will work when you take the face off / and put it on but the buttons don't work but you can control it with the remote,and when you hit the eject the face wont come down and it wont eject a...
had the same problem with my alpine, i was able to fix it once by, popping off the face plate and with fine grit sand paper (lightly) sand the connection points on the radio and the face plate, then put a little bit of dialectic grease on it . also doing a reset on the unit helped me from time to time...
May 02, 2010 | Alpine CD Player CDA-9855 LIMITED QUANTITY...
My 9821 Alpine faceplate is scrambled. I cannot read the stations or the time. The radio and stereo play alright. Whats the problem with the faceplate? Ive bought other ones and have the same problem with...
had the same problem with my alpine, i was able to fix it once by, popping off the face plate and with fine grit sand paper (lightly) sand the connection point on the radio and the face plate, then put a little bit of dialectic grease on it. also doing a reset on the unit helped me from time to time...
May 01, 2010 | Alpine CDM-9821 CD Player
Face plate wont light up but power is getting to it
make sure face plate is firmly put in place with no obstructions hindering the circuits behind face plate
May 20, 2009 | Car Audio & Video
Face plate buttons wont work
This is actually a common problem with more than just that radio. Sometimes the pins on the back of the face plate need to be cleaned. Take the face plate off, take a Q-tip and dip it lightly in some rubbing alcohol. Then use that to clean the metal pins on the back of the face plate. Make sure it is completely dry before you place the face plate back on. If this does not work, your better off replacing the whole thing.
Jan 20, 2009 | Alpine CDM-7874 CD Player
Annoying blue light on volume control.. can it be turned off?
The face plate is easy to take apart, just remove the face plate off the head unit and take the hex screws out and put a piece of tape over the bulb on the system board. Then put it back together again.
Nov 03, 2008 | Kenwood KDC-MP238 CD Player
Kdc 215s
its the face plate just need to take out clean with little rubbing alcohol these kinda face plates has a scrolling feature that i donot like very much face plate just needs to adjusted back on sterio mount
May 07, 2008 | Kenwood KDC-215S CD Player
My display has gone crazy
You might have a break in the flat ribbon cable that connects the faceplate to the mother board. Those types of cables often get a break in one or more to the traces (wires) that they are made of.
Jun 29, 2007 | Kenwood eXcelon KDC-X769 CD Player
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
Sep 25, 2006 | JVC KD-S680 CD Player
Kenwood KDC-MP628 CD Player Logo
163 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
