Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
Lawn mower needs new cord to crank the engine. how do i replace the cord
My cord broke when trying to start lawn mower. how do i replace the cord
  • 4 more comments
  • frankfaustin May 30, 2009
    how do i change a starter kit on my lawn mowe
    briggs & stratton
    its a 6 horsepower engine
  • Dwain Pippen May 11, 2010
    OK, it's a briggs engine. What is the model and type # stamped on the starter housing? It will probably be right above the sparkplug or on a horizonal tab on the side of it.
    What is the model and type # on the ENGINE?
    I don't know how else to ask you. I need the Model and Type #'s that are stamped on the engine. You will see where it says MODEL....TYPE....CODE. The model will be something like 124K02, type.0668-01 and then a longer number for a code that I don't need.
    Problem Solver:
  • 14 Answers
Remove the 3 bolts located on the flywheel housing.(should be 7/16") one in front and two on side.
Posted on Jun 19, 2009
Electric Mower zapped?
They should replace it. They broke it. If it was just a cut in the cable it should work again, but they have probably burnt it out. Change the fuse first also as that would have popped.
Jul 13, 2013 | Garden
Broken spring in recoil starter on lawn mower
While I have not done this on newer model lawn mowers, I have replaced recoil springs in the past. Here's what I did: First you need to pull the spark plug wire off so the engine will not start. Then block the flywheel with a piece of wood to keep it from turning. Then, using another piece of wood such as a short (6-8 inch) hardwood dowel placed against the ears of the recoil drive, and drive it in a reverse direction (clockwise) with a hammer to knock it loose. It may take several sharp blows to break it loose. The recoil drive is reverse threaded to keep it from coming loose when the engine is running. Once the drive is loose, remove it to get access to the recoil spring which must be replaced if it is broken. With a new spring in place, rethread the recoil drive counter clockwise until it is finger tight. Then, tighten it down with one sharp blow against the wooden dowel.
Jul 10, 2013 | Garden
Lawn mower recoil spring
Remove mounting nuts, pry recoil off fly wheel. Purchase new recoil assembly at mower repair store.
Pull cord broke of mower starter
Go buy part at Home Depot or wherever. Remove top cover. Remove pull cord housing. Install new pull cord housing. Replace cover.
Oct 09, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
I have a Toro Self Propelled lawn mower. The pull cord broke when I tried starting it. As I went to fix the cord I noticed that the spring to pull the cord broke. Is there any way to fix the spring...
You need to obtain the model number off the engine and go to a website that has small engine parts, and likely schematics. Enter the model number and find your engine and when you get a list of illustrated parts drawing select the one for the starter or recoil strarter or some such listing. This will give you an exploded view illustrated parts drawing and you need to find the broken parts. Take the number that identifies it on the drawing and look to the associated table. This will give you a part number and allow you to order it.
I hope this helps.
Jul 22, 2011 | Toro Lawn Mower With Toro Power Tools
We broke the pull cord and after pulling the cord won't recoil to proper position.
remove the cord assembly ,, either the cord is off track and needs to be rewound or it broke and needs replacement
Jul 16, 2011 | Toro Super Recycler Super Bagger Lawn...
Pulled the cord out of the mower trying to get it back.
you have to remove the top of the mower and you may need to buy a new spring depending if it broke or not, then wind the spring up and slide the rope back through the holes and tie a knont in the rope and let the spring wind the rope back in. reassemble the top on to the engine.
Jun 16, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
B & S 10D902 lack of compression when starting
may have broke crank newer mowers are not built as they use to be take out plug and place finger over hole to test for compression if none u broke more than likely the crank
May 05, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Pull start cord sticks, catches on something internally and I can't start the mower...brand new...
Make sure you hold the throttle bar firmly against the handle. If that doesn't work the cable from the throttle to the engine may need adjusting. The only other cause would be a damaged crank shaft.
Feb 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Self Propel Cord Replacement too loose!
measure it from the old cord thats the easiest way ?
Aug 26, 2009 | Toro Lawn Mower With Toro Power Tools
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
439 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
