Question about Toshiba 61HX70 61" Rear Projection Television
61HX70 61in. terribly distorted picture blinking red power light
I think i have been having the same problem as a few other people with the blinking red power light.  The only difference with mine is when i plug the TV in the picture  comes on but is very distored and you cant really make out any words on the menu screen or channel numbers that appear.  Then after about 30 seconds the TV turns off and the blinking power light comes on.  Just curious if because the TV actually turns on when plugged in if this could be a different problem then others may be having.  Is this something you can fix by replacing a fuse or something else simple or should i just call someone so i dont damage it further.
    Problem Solver:
First i had a problem with distorted picture and shot down - i replaced IC's and now i have another issue with the green and red bowing and not lining up on the screen - solution for both issues are discussed here -- replace the IC's -- but i did just that, neatly and carefully, IC's came from ebay
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=380042572843
is there anything else i should check/replace, try diferents IC's or does it need calibration?
http://www.fixya.com/support/t207950-picture_red_green_not_lining_up_toshiba
thank you all you gurus!
Posted on Jul 15, 2008
    President:
  • 4,402 Answers
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Posted on Feb 21, 2008
Why does my 4year old Panasonic plasma flat screen tv have vertical stripes and will often not turn on but red power light blinks?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
LED blinking codes to Plasma TVs too is given.
Mar 23, 2015 | Panasonic Televison & Video
Turned itself off. I turned it back on and the green power light blinks for awhile then blinks red for awhile.no picture or sound
Get rid of this TV. Had one and replaced the bulb and light engine many times. Just buy a Samsung or Vizio 50+ inch instead and be very happy. Those Panasonic projection TV's were terrible. You will find a 50 inch Vizio for around $500 bucks and it will blow your mind how great the picture looks.
Oct 16, 2014 | Panasonic PT-50LC14 50" Rear Projection...
The screen on our 50H81 Toshiba is blank, there is no audio and the red light by the power switch is blinking at a rate of one blink per second.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Toshiba 50H81 50" Rear Projection...
Sony model#kdf50e2000.turned it on a few days ag0 heard a few clicks, green light come on a few times then it gives me three red blinks stops then three red blinks again and again.no sound no picture.i...
Your lamp door switch or lamp switch (there are 2) may not be fully engaged or one may have failed. Try seating the lamp again, you may not have it fully installed.
Mar 17, 2010 | Televison & Video
Was playing a ps2 game when the PS3 suddenly shut off. When I try to turn it back on by the back, the light turns red. As soon as i press the power button it beeps once, I hear a whir, then it powers off....
does the light blink red?
if so you have the TERRIBLE BLINKING LIGHT OFF DEATH
you have a few options:
1.call sony, send in your ps3, recieve a refurbished ps3 for $150
2.find a local to fix it for much cheaper
3.buy a new console
Jan 02, 2010 | Sony Playstation 3 (PS3) Console
Toshiba 60HX70 distorted picture, blinking red light
You could have a Power Supply Regulator Problem. Many times these sets will not hold Horizontal sync when there is excessive High Voltage or a problem with the High Voltage Regulation. This is not a problem you want to deal with yourself. I would recommend a Toshiba Repair Facility to come out and diagnose it.
Hope this helps,
Skyassoc
Jul 22, 2009 | Toshiba 61HX70 61" Rear Projection...
Blinking red power light
I think Denon designed in a "bug" as mine just "went east" today
May 25, 2008 | Denon AVR-1906 Receiver
Toshiba TV 36AX60 power light blinks and no picture
I don't believe it this is a DIY project. I think this takes an experienced repairman for this project.
Apr 22, 2008 | Toshiba 36AX60 36" TV
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Toshiba 61HX70 61" Rear Projection Television Logo
145 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
