Question about Philips 47PFL3603D LCD TV
BLUE SCREEN ON LCD WHEN I CONNECT LAPTOP VIA HDMI CABLE
HAVING TROUBLE WITH PC CONNECTION VIA HDMI...HELP!!
  • beertenderbe May 31, 2009
    I am using an HDMI cable from an HDMI port on the Laptop. I contacted dell help desk and thru their tech support, they couldnt figure it out. they got the background on the screen but no icons or tray. then when tinkering some more, lost the pic. then we were mysteriously disconnected and never heard back!
  • dshan May 11, 2010
    What kind of cable are you using to connect the laptop and which port are you using?
2 Suggested Answers
SOURCE: When I connect my Laptop to a Philips lcd tv via
Hey FixYa
Thank you for your answer.
My problem is that my graphic board in my HP Pavilion Laptop dos not support sound from the HDMI output, only video. That was the reason
why i could not hear anything from my Philips lcd TV.
I wish you all a happy New Year.
Greetings from sgkbcl
Posted on Dec 28, 2009
Restart and blue error screen
Get a new HDMI Cable as that HDMI may have an internal short or disconnection
Aug 24, 2014 | Computers & Internet
Unable to Connect Laptop to Samsung LED TV
VGA is analog - HDMI is digital
if u have a cable w/o a converter it won't work unless your video card supports digital signal output through VGA port function. Please consult with your laptop's user manual for more information.
Dec 10, 2013 | Compaq Presario Notebook
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
Aug 03, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
Connect g60 to sharp 42" hdtv via hdmi
They both will need to have hdmi ports so that you can run a hdmi to hdmi cable between them. If not, you will need some type of adapter that connects between them.
Once you have them connected turn the tv on and press Select Input from the Remote and Select HDMI as the input (If you have vga connections there might be a PC or Computer connection for it).
Reboot the laptop and the video should be on the tv.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 11, 2012 | HP G60-235DX Notebook
How to i connect my laptop into television with high definition multimedia interface
First what you need is a HDMI cable.
Second look for HDMI port at the side of your laptop. (It may not be the model of your laptop.)
Third look for the HDMI port on you T.V. (It may not also the model of your T.V.)
After confirming those connection on your T.V. and Laptop, you can just the HDMI cable to connect you Laptop to T.V. Also you need to choose HDMI on your T.V. settings and for your Laptop you can just switch the display by pressing FN+F4 or F5.
Hope It helps.
May 14, 2011 | Compaq Presario CQ60-204NR Notebook
I have a dell dimension 3000, bought a new HP 2310E monitor with 3 ports. DVI, HDMI & display port. Told to buy a cable with VGA to connect to dell and DVI to connect to HP Monitor display port....
Hi sshorne9780,
I see that you are having a check input error on the Monitor/LCD that your are connecting to your Dell tower, please see steps below.
  • On your HP 2310E make sure that your HP is set to the input/source that you are using and make sure that you only use one type of video cable for the issue.
  • I see that you mentioned that you have a VGA cable and a DVI cable, you can only use one type of cable for a video connection.
  • VGA would be the Blue tipped cable connecting to the tower and going to the LCD monitor.
  • DVI this is a black cable connecting to a white port much bigger than a VGA port and is rectangular in shape unlike the VGA
  • and on your LCD monitor check the input type to see video from the tower.
  • everything seems to be OK you just need to change the input of your LCD monitor for the video to show up on the screen.
  • also if you are using HDMI for the video u will need to change the setting of your Audio and set HDMI as the Default to have Audio come out from the HDMI connection together with video, the HDMI viedo will automatically be detected as long as the LCD monitor's input is set to HDMI.
I hope that this will able to help resolve your concern.
Thank you for choosing Fixya,
mvincentc
Apr 18, 2011 | Dell Dimension 3000 PC Desktop
How do i connect aspire 5810t vista home pre 64b laptop to samsung lcd hdtv via hdmi
As long as you have an HDMI port on each hardware, just insert the HDMI cable into the ports and it should work fine.
Hope this helps
Mar 23, 2011 | Acer Aspire AS5530-5824 Laptop
No image on hdtv
First off, is the tv set to use the hdmi input? if not, change tv to hdmi input and try again. If still no good, you likely need to tell the laptop to use the hdmi connector. Try this:
  1. connect hdmi from laptop to tv and select hdmi input on tv.
  1. while holding the blue fn key (bottom left side of kbd) press and release the F5 key. This will toggle the laptop between the laptop lcd display, external connectors (vga/hdmi), or both simultaneously. Let me know if this works or not.....
Aug 08, 2009 | Acer Aspire 6930-6455 Notebook PC
Connect lcd LE10 32'' model to laptop
connect them via HDMI. Audio and video from your laptop will go the TV. You need an HDMI cable for that connection.
cheers!
Jul 11, 2009 | Panasonic Viera TC-32LZ800 32 in. LCD HDTV
Having prob connecting my laptop to a TV via hdmi
try playing around a bit with the display settings, there are not many laptops that are setup to automatically adjust to the dual screen setup with an lcd tv. Also, iv found that Not using the lcd as a duplicate of the main screen is a good idea, set it up as a separate screen...if you know what i mean, if you do it right you will see only yourbackground on the tv and no start menu bar or icons.... In this configuration you can set the resolution to the max for the best quality possible for your television.
Nov 25, 2008 | Computers & Internet
Philips 47PFL3603D LCD TV Logo
224 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
