Question about Mantis 4-Cycle Tiller
Mantis 4 cycle (brand new): oil leaking out, smoking soaking air cleaner, quits running..
Oil is leaking out and soaking foam air cleaner and dripping onto machine, smokes alot when under a load, runs for 15-20 minutes, then quits. what type of oil should be used? how much oil capacity? where can i purchase owners manual. thanks jt in illinois It's not necessarily worn out, because mine is doing the exact same thing (except that it doesn't quit) - and mine is brand new!. Oil leaks out on the right-hand side, dripping onto the "fender". This is associated with a lot of smoking and low power. Then it clears up and runs OK. Perhaps I have overfilled the oil? I had used the machine for a few hours (they filled the oil where I bought it), checked the oil, and thought perhaps it could use a little - only put a small amount in, but that is when this dripping started. Hope someone can help.
  • treeherder May 30, 2009
    The first part of that last post was by "jt in Illinois", who was having a similar problem. Somehow it got appended to my post. Sorry!
  • treeherder Jun 11, 2009
    Hi Jim!
    Thanks for your input and sorry for my delay in replying. Actually, my machine was not prone to stalling, but it was smoking, boggling, and oil was dripping out of it. I took it to the store where I bought it, and they found the oil reservoir had been overfilled by the technician who assembled it.
    All is well now. Thanks again!
    ~Wendy
  • 1,040 Answers
Sounds like your gas tank is not breathing properly. try this: the next time you run the tiller and it begins to stall out, try loosening the gas cap. It should start running again. This means that the gas cap is clogged. Unclog it or purchase another one.
Jim
Posted on May 31, 2009
  • Jim Parker
    Jim Parker Jun 06, 2009
    Did this solve the problem?
    Jim
  • Jim Parker
    Jim Parker Jun 12, 2009
    That's quite alright. I'm just glad you got the problem resolved.
    If you should ever have any questions about "Drywall Finishing/Patching, or know someone who does, put your questions to Category: "Tools- Building & Power- HAND TOOLS" at FixYa.com
    Jim
    Problem Solver:
  • 6 Answers
SOUNDS LIKE MUFFLER SCREEN IS STOPPED UP WITH OIL.
REMOVE MUFFLER SCREEN AND TRY RUNNING TILLER?
Posted on Sep 08, 2009
2 Suggested Answers
libaredneck
  • 119 Answers
SOURCE: mantis gx22: oil leaking out soaking air cleaner, quits running..
i hate to tell you but it sounds like the motor is wore out
Posted on May 05, 2009
I added to much oil it leaked out of the carb now when I strat it up it smokes white smoke for a minute then stops and runs fine
If you are concerned, you can remove some of the oil. Place a pan under the mower and loosen the oil pan bolt but do not remove it completely. Drain a few ounces of oil out and then tighten it up. Be sure to take the wire off the spark plug before you do this. The lower oil level should stop the smoking.
May 18, 2014 | Mantis 4-Cycle Tiller
Hard to start and oil soaked air filter, smokes and loses power
It sounds like it got tilted on its side. The air filter needs to be cleaned or replaced and the carburetor needs to be removed and cleaned.
When the tiller gets tipped over toward the air filter, oil will run out into the filter and the carburetor.
If the filter is foam you can clean it with gasoline, if its paper just buy a new one.
The carburetor is between the air filter box and the engine, it should come off with a few bolts, just remember where the springs hook up.
Open it up, take it apart and spray everything with carburetor cleaner from your local auto parts store. When you put it all together it will run like new!
Jun 08, 2011 | Mtd Craftsman 4Cycle Mini Tiller
Mantis starts and runs but lacks power and is slow to rev up
Check the air filter and ensure it is clean, replace if necessary.Foam filters can be washed in hot water and detergent, paper filters need to be replaced.
Ensure the throttle cable moves freely and the choke is turned off after starting.
Mar 08, 2011 | Mantis 2-Cycle Tiller
Mantis tiller starts but will not stay running
Carburetor problem. Two stroke engines use oil mixed with gas. Old fuel or setting over the winter will cause varnish and sludge in the Carburetor. Start by buying a can of carburetor cleaner and mixing a new can of fuel.
1) Dump the old fuel and check replace it with new.
2) Remove the air cleaner.
3) Pump the prime bulb 3 or 4 times, set the choke, spray the insides of the carb with the cleaner and then try and start it . It should sputter and run for a few second but chances are it will take a few sprays to clean the jets
Jun 06, 2010 | Mantis 2-Cycle Tiller
Four cycle mantis/honda engine gettting oil in carb and smokes
Honda GX25 GX35 manual on PDF.
http://www.smallenginewarehouse.com/images/manuals/GX25-35.pdf
May 26, 2010 | Mantis 4-Cycle Tiller
White smoke honda mantis rototiller
You're okay the white smoke is the oil burning off the muffler. In time it will stop, just park it somewhere and let it run until it's done. If the problem persists check your air filter and make sure it's not stained with oil, if so you can wash the foam part with soap and water but the paper will need to be replaced. (DO not put foam back on unit until dry.) The oil level should be up to the bottom lip of the dipstick access when the engine is evenly horizontal.
Apr 03, 2010 | Honda 25cc 4-cycle Mini Tiller
Mantis gx22: oil leaking out soaking air cleaner, quits running..
May 05, 2009 | Mantis 4-Cycle Tiller
Oil In the air filter
Back pressure. You will need to tear into the mantis and replace all the gaskets. You can do it the cheaper way by going to Kragen and just buy a tube of gasket sealent, or you can go to mantis and order the rebuild kit. I recommend the gasket sealent for me that has always worked better
Apr 25, 2009 | Mantis 4-Cycle Tiller
Mantis 4-Cycle Tiller Logo
1,820 people viewed this question
Top Mantis Garden Experts
Mike Squire
Matt Olenzek
Matt Olenzek
ray gallant
Are you a Mantis Garden Expert? Answer questions, earn points and help others
