Question about Nvidia 64MB GeForce3 AGP Video Card with TV-Out Graphic Card
Geforce 3 analog output: I have horizontal, blurred/faint lines scrolling from bottom to top of display, spaced 6 inches apart.
  • dennissewell May 30, 2009
    Monitor (Acer X193W) works okay with another PC. This Video card worked for years in another PC; I just installed it in another PC that also ran okay for years (with a different Video card). I will have access to a monitor with DVI input soon to try the DVI output of the card. ??????
  • 63 Answers
What kind of monitor? Have you replaced the cable? Try the pc on another monitor. You need to see if it's actually the monitor or the video card. replace the broken or defective part.
Posted on May 30, 2009
Why does screen have fuzz and black lines a few inches apart from top left area down to the right bottom area?
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Mar 20, 2016 | Sony FD Trinitron WEGA KV-32FS210 32" TV
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
How to fix horizontal lines across screen and black bar at bottom?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes are given with illustrations. You can get an idea about the fault to an extent. Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Oct 22, 2015 | Sony SLV-695HF VCR
Black horizontal lines across pages
If they are the same distance apart every time then suspect the problem to be caused by the components in this order First the drum that is in the print or xerographic module, the charge and cleaning roller are located in that module also. So I suspect that first.its .Located above and to the right of the toner cartridge. Secondly it could be the roller on the toner cartridge, that would occur probably every 1 1/2 to 2 inches apart, the drum would cause the defect about every 3 inches. It less likely could be coming from the fuser, and if the fuser was causing that you should also have a lot of jams. There is also a transfer roller on the right hand door that could be causing it, but that would be exceptionally rare.
If the lines are random and have no consistant spacing, I would suspect the power supply then the laser.
Oct 28, 2008 | Xerox WorkCentre M20i All-In-One Laser...
JVC AV-K21TR
The faint white lines at the top of the screen is the warning that the pump-up capacitor in the vertical output circuit is going bad and the output itself is about to short out. When the TV stops working, the vertical output IC has finally shorted out. Replacing the vertical output IC, the pump-up capacitor and possibly a small value resistor next to the flyback (B+ for the v-out) should bring the set back to life.
Jan 26, 2008 | JVC AV-27230 27" TV
Very poor picture
  • your problem is called picture with retrace lines.
  •  your problem is in video output circuit
  • as you are saying that it was off for a year that means there is possibility of loose contact in that section.
  • plz check the following
  • supply to video output absent or loose print.
  • loose connector in crt base.
  • crt base loose
  • voltage on screen control or g2 absent or wire loose.
  • screen control located on flyback transformer mistuned.
  • hope this will help
  • good luck.
Oct 19, 2007 | Proscan PS32125 32" TV
White Horizontal Lines near the top of my Screen
this symptom is what we called vertical fold-over. vertical fold-over is characterised by a white horizontal bar on the bottom or top of the raster due to the concentration or compression of the trace lines. it an image is present, the bottom or top portion is fold over. this is caused by a vertical deflection current with poor linearity, which compresses the trace lines at the bottom or top of the screen. this symptom is is caused by a defective sawtooth wave genetator circuit, or improper biasing or defective feedback circuit of the vertical drive or vertical output transistor/ic. the negative feedback circuit in vertical deflection circuit compensates for the linearity of the trace portion of the sawtooth wave. a decrease in the capacitance of the sawtooth generator capacitor is usually the trouble. but if you do not understand anything what i have written here, better bring it to a qualified tv technician for your own safety also. good luck!
Mar 01, 2007 | JVC TM-2703SU 27" TV
Nvidia 64MB GeForce3 AGP Video Card with TV-Out Graphic Card Logo
371 people viewed this question
Top Nvidia Computers & Internet Experts
Terry
David
David
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
