How much water does it need in order to start working
Can't find manual. How much water is needed after draining the pan so that it won't start leaking. Everstar MPM1-10CR-BB6
    Sergeant:
  • 340 Answers
Enough to fill the trap 1 -2 cups
Posted on Jun 17, 2009
3 Suggested Answers
co7196
  • 3433 Answers
SOURCE: looking for bottom drain plug for MPM1-10CR-BB6
This is a window unit? If so the unit should not be level. Should be lower on outside end. You may have to drill a hole in a vcorner outside to allow drainage. Good Luck
Posted on Jul 01, 2009
  • 50 Answers
SOURCE: i have an everstar mpm1-10cr-bb6
check the condensate tank to be sure it is empty and installed correctly, also make sure the unit is level.
Posted on Jul 21, 2011
What can cause water in my fridge
dont know what kind of refrigerator you have but this might help:
http://ask.metafilter.com/68706/Why-does-my-fridge-create-a-pond-inside
Frost free fridges in correct working order do not need to be defrosted, not even once a year. This problem is also completely fixable with at most a couple hours labour.
Water in the bottom of the fridge is caused by three things:
  1. plugged drain tube.
  2. plugged or frozen defrost pan.
  3. some other defect in the drain system.
Your drain pan is located in your freezing compartment of your fridge. It collects the condensate that is melted off the refrigeration coil by the defrost heaters. It directs the water to the drain tube system which takes it to the outside of the fridge where it is evaporated, often with an assist from the waste heat from the condenser.
If your fridge is equipped with a pan heating element and the element fails ice will form on the pan and eventually block the drain. This would account for the cyclic problem cured with a manual defrost that kat and nimsey lou report. The same symptoms can present themselves with a partially blocked drain (corn kernels are a common drain blocker). A secondary symptom of this condition is clear solid ice in the bottom of the freezer compartment. If a manual defrost doesn't clear a blocked pan the blockage is full and not ice and disassembly will be required to clear the blockage.
At the top centre back of your fresh compartment you'll usually have a small cup of rubber or plastic. If that cup has water or ice in it the problem is actually a blockage of your drain tube. Because it is a narrow spot the blockage is often at the exit of the cup or on the outside of your fridge where the tube takes a 90 degree bend down to the evaporator pan. If you can remove the cup do so and clean it out otherwise you might need to remove the tube/90 from the back; it's about 75/25. Sometimes a flexible piece of plastic, like a zip-tie, can be used like an drain auger to clear the blockage. Why does my fridge create pond inside
Jan 02, 2015 | Refrigerators
Were do i get the manuel for model number ph3 12r03 is the model number were or how do I drain the water and can you send me a manual
Here is the link to the manual:
http://s3.amazonaws.com/szmanuals/b0348062b23e23cd40550b61e1dc5f43
Here are those particular instructions:
Compressor Indicator
The " " icon will light up on the control panel display when the compressor turns on. The " " icon will turn off when the compressor shuts off.
Emergency Condensate Holding Tank
When the room temperature is low and the indoor humidity is high, the air conditioner may not be able to evaporate some of the moisture fast enough. When this happens, the water will accumulate in an emergency condensate tank inside the unit. Once the emergency condensate tank is full, the unit will automatically shut off and the " " will appear on the control panel display. To empty the condensate tank, unscrew the screw plug at the bottom back of the unit. You will need a small pan, approximately 1" high to catch the water coming out of the condensate tank. Once the condensate tank is drained, the unit will begin working within a few minutes. The emergency condensate tank holds approximate
ly 1.5 Liters of water.
Another option is to purchase a small hose from a hardware store that can fit around the 5/8" drain plug on the back of the unit and drain the unit into a gravity drain or larger pan for continuous drainage.
To resume operation quickly, empty the water container according to the following steps:
1. Turn the unit off. Do not move the unit when the water container is full.
2. Place the drain pan accessory under the drainage port at the back of the unit.
3. Remove the screw plug from the drain hole. The condensate water will drain out automatically. When the drain pan is full, screw the screw plug back onto the drainage hole to stop the water flow. Empty the drain pan. Repeat until all the water is emptied.
Once the water container has been emptied, screw the plug back onto the drain hole. Do not allow the
water to drip continuously into the drain pan, as it might easily overflow.
Jul 13, 2014 | Soleus KY-34 Portable Air Conditioner
My Blomberg dishwasher wont stop drain cycle
A common cause of this condition results from water in the base pan. This may result from a leak in the dishwasher or the drain hose (to the sink drain) backing up. First check the base pan (the very bottom assembly that all other components are mounted within) for any moisture - this can be difficult as there are only narrow openings between the tank and the base pan; a mirror can help or you might have to pull the unit out from the cabinet to access the sides. If there is moisture in the pan this problem must be corrected as the unit is just trying to protect against water damage from a leak. If the base pan assembly is dry, look at the float assembly (behind the water fill valve) as insects or rodents can sometimes interfere with the proper operation of this sensor. That causes the control to think there is a water leak. When this fault occurs everything is turned off and the drain pump runs continuously to eliminate any water from inside the dishwasher.
Apr 06, 2013 | Blomberg DWT14210
Changed water pump on rav4 and now it won't start due to immobiliser how do I reset that
With the engine off and cold, open the hood and locate the vehicle's radiator and water pump. Remove the radiator cap.Install a pressure tester on the radiator. Apply the pressure indicated on the radiator cap or in the owner's manual. Inspect the water pump for leaks. Remove the pressure tester. Place a drain pan under the radiator. Open the drain valve or remove the lower radiator hose to drain the cooling system.-----------------------------------------------------------------------------------
CARPROG FULL V4.01
Jan 28, 2013 | 2009 Toyota RAV4
Hi. I have an older York air handler (Model N2AHD14A06C) with an A-coil installed (G+HC036AA) that seems to be draining inside the bottom of the air handler more than the drain tube; as I have water on the...
There is no manual that can be obtained but if you google York/Johnson Controls to find your local supply house a new pan can be ordered, but your pan could debris build up down the sides or underneath where the coil meets the pan that is causing the water not to devert back to the condensate drain line connection. Also you could block off the condensate drain line and fill condensate pan with water to check for cracks or deteration in the pan itself.
Jul 05, 2011 | Heating & Cooling
Aprilaire model 560 pan keeps filling up with water - what adjustments do I need to do?
Here's a link to the manual for your Aprilaire model 560 humidifier you can download and print for free.
According to Aprilaire, it is normal for there to be excess water going into the drain pan. However, the drain pan should have a drain line connected to it so the contaminents from the humidifier can be flushed down a drain and away from the unit. (see page 2 Principle of Operation).
They further state that the water valve should only be either fully on or fully shut off and do not attempt to regulate water flow with the inlet supply valve.
http://www.aprilaire.com/themes/aa/en/manuals/Humidifiers_Owners_Manual.pdf
I would give the unit a good cleaning of the pan, locate the drain connection and attach a drain line to your unit as is required for proper operation and function/
Hope you find this Very Helpful - Best regards!
Aug 19, 2009 | Aprilaire Humidifiers
Leaking water inside fridgerator
You need to manually defrost then let sit over night .Pour warm water down the drain hole if does not go down fast than you will need to clean drain tube out with wire start at the rear of the unit and there will be a drain tube going in the drip pan good luck :)
Sep 10, 2008 | Whirlpool ET1FHMXLQ / ET1FHMXLT Top...
Evapoative air conditioning
sounds like the flaot switch is stuck in the up position. this will be like the drain pan is always full of water. You may need to take the unit apart and check the flaot in order to reapir this problem.
Jan 24, 2008 | Heating & Cooling
Order in drain pan
its supposed to have water in it heat from the compressor evaps the water you may poor a little bleach in it to kill the algae or bacteria to help with oder
Jan 15, 2008 | Frigidaire FRS3R5EMB Side by Side...
Heating & Cooling Logo
466 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
