Question about Magnavox DV225MG9 DVD Player VCR
WHILE RECORDING ON DISC ERROR MESSAGE COMES ON CANNOT RECORD ON THIS DISC IF IT DOES RECORD THROUGH A DISC OFTEN I GET THE SAME MESSAGE WHEN TRYING TO FINALIZE DISC
3 Suggested Answers
SOURCE:
  • 246 Answers
SOURCE: my VCR-DVD magnavox ZV427MG9 A i get recording error, can't record +VR mode E 45
this is a similar problem with the same code http://www.epinions.com/review/Philips_DVDR3545V_37/content_464296251012?sb=1 The person in this says that the plastic "tab" on the back of the tape was broken off to keep from recording over it, but was unable to use it in a combo like you have. he put tape over the hole and it worked...Is this similar to what you are trying to do? let me know
Posted on Jun 11, 2012
  • 4 Answers
SOURCE: Recording Error- can not record on this disc. E 4 54039000
Having finally found my manual, I discovered I cannot use my outboard editing software to erase disc prior to re-use. Not at home presently & don't have net at home (rural area Alaska). Still not certain as have only been using SONY brand +RW disc, tho manual states this brand as good for this machine (not same as yours). Still investigating. Have probably in excess of 50 discs like this. Some will no longer even work with my premium editor.
Posted on Feb 02, 2013
Emerson EWR10D5 DVD Recorder/Player - using 16x DVD-R I get an error while recording
Sounds like a bad disc. You may also want to clean the laser lens with a cleaner disc just to be sure.
Sep 07, 2017 | Emerson Televison & Video
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Mar 28, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Won't record on blank disc.
Bulk disc that comes in cylinder case are some time faulty and loses quality because they packed on each other. The lens of the disc are sensitive so if disc is scratch or dirty will get error message "no read". Turn the unit off then unplug ac power cord for more than two minutes then reconnect and try disc again, if issue still exist purchase disc that comes in individual case.
Sep 15, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
Sony dvd recorder rdr gx7 sending disc error message
The laser readerwriter is most likely burned out, it is the most common failure. The option of repair is not really feasible as the cost of new is really low.
May 25, 2017 | Sony RDR-GX7 DVD Recorder
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Emerson EWR20V4 that wont record DVD's
Sure, My suggestion is to call 1-800-605-8453, They will be glad to help you with that error code!
Good luck
Jan 29, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Emerson EWR10D4 DVD Recorder
try mr dvd-r discs from poundland.
They work with the funai machine.
Its worth a try.
Dec 24, 2007 | Emerson EWR10D4 DVD Recorder
Will not playback get error message Please Check Disc
i have a r136 , have you got the dvd discs u need ? i had the wrong format .
eg, dvd+rw needed dvd-rw
if not and there re-recordables they dont work after a few recordings and u need a new disc.
Dec 05, 2007 | Samsung DVD-R130 DVD Recorder
Toc error problem
HEY,
t is not the topic, but I'm for al long time searching for the sharp md-mt20h and I see that you buy a new md player? Were can I buy him?? thanx
Sep 20, 2007 | Sharp MD-MT20 Personal MiniDisc Player
Magnavox DV225MG9 DVD Player VCR Logo
21 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
