Question about Refrigerators
'04 Kenmore side by side, refrigerator part maintains 60 degrees.
I just bought this refrigerator off of craigslist for 600 bucks. When I went to look at it the freezer part was 0 degrees and the refrigerator part was 36 degrees. Loaded it up, never laid it down on it's side, put it in the house, plugged it in, 10 hours have gone by and it's only down to 60 degrees in the refrigerator part. The model # is Kenmore 25354622402.
Kenmore 106 56703500 Freeze is cold refrigerator is not
The problem could be an intermittently defective temperature control.
May 16, 2014 | Refrigerators
Freezer is at 0 degrees and my fridge is at 60 degrees
Keep 3 to 5 degree temp setting. And check defrost cycling is properly done. Due to frosting formed behind the freezer could restrict the function freezer fan which throw freeze air to refrigerant compartment. Unplug fridge till defrosting all frosting, and then plug it again. Thanks.
Feb 05, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frig too warm, freezer works great, but frost on back wall
It sounds like the fridge is not going through the defrost cylce due to a faulty defrost thermostat.
Aug 29, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Kemore Refrigerator MODEL# 2535808789A is not cooling.
Thank You for having your model number ready, Could you remove the grate on front and bottom of refrigerator to expose the defrost timer. In the opening on front turn the timer slowly turn clockwise until you hear a click or change in operation of refrigerator. Let me know, Sea Breeze
Mar 21, 2009 | Kenmore Refrigerators
Refrigerator is freezing at the bottom and 60 degrees at the top
probably the fan is not running
take the fan housing off and you may find a buildup of ice preventing the fan from running
Nov 29, 2008 | Kenmore 53642 / 53644 Side by Side...
Side by side not getting cold
Hi. Thanks for The Question.Did You Check, The Fan in the freezer. Check that. Also Frost Build Up In Freezer. Also Pull Fridge From Wall Remove The Back Panel. Clean All Coils Thanks The Appliance Doc
Sep 05, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Freezer works but cooler isn't cold
Try unscrewing the light, bulb mine did the same thing I couldnt figure it out. It turned out to be the light switch! Everything is fine now.
Aug 20, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Side-by-side refrigerator
try unplugging it for 5 min and plug back in?
Jun 29, 2007 | Kenmore 57029 Side by Side Refrigerator
Freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Jun 20, 2007 | Kenmore 44109 / 44102 Side by Side...
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
