Outside fan runs all the time
Fan runs even when the unit is off. It still cools though.
  • Bill Long May 11, 2010
    Has the fan been replaced or unwired recently? If it has, it sounds like the wires are on the line side ( L1 and L2) of the contactor and they should be on the terminal or load side ( T1 and T2). They should be on the opposite side of the power wires on the contactor.
    If not is the compressor running also?
  • ROLYAHS69 May 11, 2010
    IF YOU CAN GET ME THE MODEL NUMBER AND SERIAL NUMBER OFF OF THE SIDE PANEL ON THE OUTSIDE CONDENSING UNIT I MAY BE ABLE TO HELP YOU. USED TO WORK FOR A/C CONTRACTOR. IF I DONT KNOW, I AM SURE HE PROBABLY WILL.
  • 614 Answers
Fan wired wrong to contactor. defrost board bad if it is a heatpump. outside fan relay is on board. Rusty
Posted on Jun 04, 2009
2002 4 ton Bryant air conditioner shuts off, fan still runs but not cooling is problem in the controls in the attic or in the AC unit or both?
With a non heat pump it is a simple 24 volt AC control circuit. In the attic there is a relay that is actuated via the fan control wire directly from the thermostat. On the thermostat there is an auto/man switch that controls the fan. Manual the fan runs all the time. Auto fan turns on and off with the outside compressor.
If the system is not calling for cool and the fan continues to run the fan relay is sticking. common problem. Sometimes after running for several days the relay will stop sticking if not, replace relay.
If the system is calling for cool and the compressor stops I would still expect the fan to run until thermostat tells the A/C to off. Some compressor units include a safety switch or high-pressure cut-out switch A blocked internal valve bad control board or external fan in outside unit defective no air flow in outside unit.
High pressure cut out not good,
Suggest turning temp max cool and observe. If acceptable cool and the compressor runs without interruption all is good, except for the blower in the attic. Safely check relay in attic blower circuit.
Hope this helps.
Jun 28, 2017 | Bryant Heating & Cooling
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
Why is a fan in the engine compartment is turning on
this fans turns on in order to cool your radiator and cooling system, it will also come on when the air conditioning switch is turned on, if this is running all the time then you should have this checked out by a mechanic, if its coming on and off this is perfectly normal
Feb 03, 2014 | 2008 Hyundai Tucson
AIR BLOWING LIKE IT'S ON FAN EVEN THOUGH IT IS ON COOL
close vent for outside air.....if not then probably lost its chaerge.
Oct 11, 2017 | Heating & Cooling
My American Standard Heritage 11 unit was not working properly when i came home from work and the temperture in the house according to the thermostat show the temperture in the house to be 85 degree&#
the dual run capacitor is bad located in main panel of unit size of small red bull can it will be swelled up on top indicating it bad get on at electric motor or electric supply house most ac stores wont sell it has a rating like 35/5 370
Aug 27, 2012 | Heating & Cooling
My ac unit outside runs when the tempeture gets above what it is set on, but the fan blower keeps going on and off. I switched the theromstat fan to on from auto and it does the same thing, on and off in...
the fan control is not for the fan on the top of your outdoor unit. that is for the blower, you have 2 fans. Im guessing you have a split system, 1 unit inside and 1 outside?? Does the outdoor fan continually run??
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Feb 06, 2018 | Ingram GMS90904CXA Heater
I installed an RTH2300 this winter to replace an old mercury thermostat. It worked fine for the heating season. I turned it to Cool for the first time today and my AC and furnace blower will not turn...
Maybe turn selector switch to off.see if every thing shuts off.if yes. turn FAN selector switch from (auto) to (on) mode.does the outside unit come on or does just the furnace blower only run ? the inside fan should be the ONLY thing on.if not, reverse the (G) & (Y) wires inside the new thermo.
Jun 07, 2011 | Heating & Cooling
I'm having trouble figuring out the programming on our thermostat; comfort-set 90 series premium; universal multi-stage heat pump digital 7-day progammable. The fan runs all the time even though it's set...
Low voltage wiring problem.check wiring diagram/converson chart carefully as the termnal letters vary by brand of unit.make sure color code is correct btween each appliance itself.good luck!
Mar 15, 2010 | Heating & Cooling
Rheem outside a/c fan won't turn off
I would probably start at the thermostat and see if 24 volts is continued to be applied to the yellow wire which calls for unit activity even though you have called this off. Shorting the cool (yellow) wire to the return (red) wire will cause the HVAC system to begin cooling and the fan will be turned on automatically.
Aug 23, 2009 | Ruud UAMB042 Air Conditioner
Heating & Cooling Logo
79 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
