Question about Kenmore 24 in. 15689 Built-in Dishwasher
Dishwaser does not fill
Kenmore Ultra Wash Quiet Guard 3. Verified water is available. Ran what I think are a form of diagnostics on control panel. No change. How do I verify that the fill valve is working and with the float valve can I pull this out to clean out without damaging/
    President:
  • 1,136 Answers
Hi. You can test the fill valve for voltage. If it is getting 120V and n water is coming in, change the valve.
Some models you can pull the float out.
When you lift it up and down, can you hear it clicking?
Please let me know if I can assist you further.
Vic
Posted on May 30, 2009
My kenmore quiet guard My partially fills and therefore does not clean. any suggestions
Possibly low water pressure; possibly a clogged inlet screen on the inlet valve; possibly a bad inlet valve (replace it).
Nov 14, 2014 | Kenmore Dishwasher With Ultra Wash And...
Could you please help diagnose problem...dishwasher consistently stops washing in the middle of wash/sensing cycle. 2005 Kenmore Ultra Wash Quiet Guard 3
most likely the water is not hot enough,,it trying to heat the water,,when it starts to sense open the door and just test the water,,careful may be hot ,,but i doubt it...another easy way to tell is what is your hot water heater set on,,if you have a lot of soap residue is a good sign..
Sep 02, 2011 | Kenmore Dishwashers
I have a Kenmore Ultra Wash Quiet Guard washing machine Model No. 6651601. I am trying to find out how to reset my dishwaser as it keeps flashing the "clean" light but will not run.
No there is no reset button you could disconnect the power by turning off circuit break for at least 5 minutes turn it back on and see if that clears it
Gene
Aug 01, 2011 | Dishwashers
My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Jul 30, 2009 | Dishwashers
Kenmore 665.17539. fills but does not wash. makes
Kenmore 665
My dishes on the top rack are no longer getting clean. I don't think any water is going to the top. The dishes on the bottom get clean but have a soap residue on them.
Jul 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore ultra wash 665 dishwaser wont start. blinking light
The control panel is most likely defective, take it back.
Aug 22, 2017 | Kenmore Dishwashers
No water going thru washer arms
remove the pump screen and, clean the pump
you probably have broken glass preventing the pump impeller from moving
May 29, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Smelly dishes from Kenmore Ultra Wash
If you post the model number of your dishwasher plus its approximate age (in years) I can help more.
But the most common cause is a weakening pump motor. On many dishwashers, the wash pump motor is also the drain motor. Replacing that motor / pump assembly will solve the problem. While you are replacing the pump, check the heating element to confirm that it is not shorted out or broken.
For now, add a cap full of bleach to the water _after_ the initial dishwasher fill cycle ends and the wash cycle begins. White vinegar would also work, but this will not fix your problem.
Good Luck!
May 04, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 24 in. 15689 Built-in Dishwasher Logo
273 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
