Question about Plustek OpticFilm 7300 Film Scanner
Negatives scan as negatives and not as pictures with the plustek 7300
Our plustek scanner 7300 work when scanning negatives into pictures in quickscan, yet with the higher res on intelscan we still get back a negative. Anyone with an idea why?
  • 256 Answers
In the Twain driver for your intellscan, there should be a selection for the type of scan. It should be set to "black & White Negative" or "Color Negative". The program you use to edit the scanned file should be able to change it to a positive if the scanned result is still negative. Programs such as Photoshop, Paint shop Pro etc can use Twain to have the scanner scan directly into them. There the phot (negative) can be edited and saved.
Posted on May 30, 2009
SOURCE:
HAVE A REV SCAN 192001 BUT COMPUTER WILL NOT CONNECT TO SCANNER I DO NOT HAVE INSTALLATION DISC
Disconnect the scanner from your computer and go to Plustek's website (http://plustek.com/)
Download the driver that matches the scanner model and the version of Windows you are using.
Double click on the driver file you downloaded and connect the scanner when prompted or when the driver finishes installing.
If this helps please vote for my solution.
Nov 30, 2010 | Plustek OpticPro UT12 Flatbed Scanner
Can't scan PLEASE HELP!
SOLUTION: Download the latest version (v 7.7.2) of the HP software from the HP website at www.hp.com. Uninstall the previous software and then reinstall the downloaded software. WORKAROUND: Follow the steps below:
  1. Load the slides or negatives in the TMA and place it on the scanner glass.
  2. Open Image Zone and click on Scan Picture to scan everything.
  3. After the scan is completed, change the settings from glass to scan slide/negative from TMA. The unit will scan again and show the four slides or negatives in the preview.
  4. Click on the first picture in the scan preview and make the following changes:
    • change the dust and scratch removal/sharpness to none
    • change the resolution to 72 dpi
  5. Click on the second picture in the scan preview and make the same changes described above.
  6. Click on the third picture and then the fourth picture and make the same changes.
  7. Click Accept . The correctly scanned slide or negative images will be saved in the Gallery.
May 21, 2009 | HP Photosmart 3310 All-In-One InkJet...
Scanning Size
Do not try to change the scan size, change the resolution. The window that appears when you want to scan should have a resolution (DPI) area that can be changed. IE: 300 DPI to 800 DPI. This changes the picture size.
May 16, 2009 | BenQ ScanWit 2720S Film Scanner
Plustek wont scan
no the problem is check the path u mentioned in the scanner preferences and settings i mean the folder mentioned to store the scanned images after the scan , scanner is given a path to store these images by default check and change that path to other location on hard drive and everything will be ok if the problem persists then update ur driver from plustek website
Feb 24, 2009 | Alestron OpticSlim M12 Path-Through...
Convert scanned slides to dvd
Has the scanned slides each been given a File name and saved on the Hard Drive? If yes , burn the files onto a disk from the hard driver using the file names to burn.
Feb 15, 2009 | Plustek OpticFilm 7300 Film Scanner
Hunting negative holder tray for Plustek 7200, can't find one anywhere
Plustek Tech support gave me the following website for parts:
http://www.plustek.com/usa/part/main.asp
You have to print the form & fax it.
Oct 02, 2008 | Plustek OpticFilm 7200i Film Scanner
Software hangs
Tell Plustec this seems a common problem- perhaps there is a patch
Jun 22, 2007 | Plustek OpticFilm 7200i Film Scanner
Plustek OpticFilm 7300 Film Scanner  Logo
384 people viewed this question
Top Plustek Office Equipment & Supplies Experts
Thomas F. Schneider
Chris Medina
Are you a Plustek Office Equipment and Supply Expert? Answer questions, earn points and help others
