Question about Kenmore Refrigerators
Ice maker is frozen and does not deliver ice out of ice maker. Cannot get ice maker off. Help! Kenmore Elite Side by Side Model # 106.58976702
  • Patti Macalolooy May 31, 2009
    Ok, fixed my own problem. Opened compartment, took all the ice out of the caddie, got a large "bowl" placed it under the side door, and ran hot water from inside the caddie and it came out front, thus releasing the frozen up ice that was caked all around. Waited 24 hrs and voila! Ice in the ice maker, and running beautifully. Should clean this out every couple of months to prevent the freezing up in the door panel, and that should be keeping it running smoothly.
  • Patti Macalolooy Nov 28, 2009
    I used a hairdryer to unfreeze the ice cube holder where the ice is delivered into your holder. I emptied out all the ice first, then blow dryed it. When it became runny and warm it started to move and I was able to release it and rinse it out in hot water in a sink to release all the congested frozen ice. Dried it off, placed it back and waited 24 hours and it voila, I had ice again and no more problems. Easy care solution: take it off once in a while and rinse it off to take off hard ice that is wrapping itself around the carosel that delivers ice. It works!
  • 92 Answers
SOURCE: ice maker not working
make sure its turned on check the wire connector is seated and check to make sure there is nothing jambed in the tray if all that is ok call for service
Posted on Feb 10, 2008
duby1990
  • 367 Answers
SOURCE: ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Posted on Nov 20, 2008
  • 14 Answers
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Posted on Apr 04, 2009
  • 351 Answers
SOURCE: Kenmore Ice Maker Not Working
Probably need a new ice maker, whirlpoolpartssurplus.com
Posted on Jun 23, 2009
  • 36 Answers
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Posted on Jul 24, 2009
Kenmore Refrigerator Elite Mod # 106.55602400 is not making ice
Is the food frozen solid in the freezer? Does the ice maker get any water to it? Do you see any ice buildup in the freezer?
Jan 19, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore elite side-by-side ice maker creaking!
Look behind the freezer rear trim panel for frosted/iced evap. coils and thaw if necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker stoped working
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 07, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore elite, will not make ice, but it does dispeanse
Dear tnsmarchini
You said, Kenmore elite, ice maker in door...........................???What????????
And we need more detail than Ice maker in door.
What does your ice maker do?
Sep 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore fridge ice maker
I used a hair dryer for about 5 minutes. It took a while to verify because a tray of ice had to fill and freeze before I knew my problem was fixed. No repairman!!!
Aug 18, 2008 | Kenmore 52642 / 52644 / 52649 Side by Side...
Kenmore elite side by side refrigerator
do you hear the little click of the switch when you push the paddle?? Its likely that the microswitch had broken from its plastic mounts. Pretty common on this refrig. ill need the model # to be sure what kind it is.
Nov 19, 2007 | Whirlpool ED2FHEXN Side by Side...
Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
Nov 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
88 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
